Question about Electrolux EW1200i Front Load Washer / Dryer
I have an electrolux ew1200, it wont fast spin, it starts to then gives up it tries this 3 times before stopping. I have cleaned out a very dirty filter on the bottom left. Please could you help thanks
5 Suggested Answers
fanny
  • 146 Answers
SOURCE: Clothes wet, doesnt spin fast
Check the drain spigot, where the drain hose attaches to the drain trap under the sink/tub.There may be a blockage in the spigot which is causing the water to drain very slowly and therefor not allowing the machine to spin at normal fast speed.
Posted on Oct 31, 2007
mattozan
  • 555 Answers
SOURCE: washer will get as far as spin cycle and never complete
Try resetting the wash cycle
Posted on Aug 05, 2008
  • 867 Answers
SOURCE: Electrolux EWFLW65HIWO front load washer error code E21 I checked on the bottom front of my washer and there are not 3 screws or a panel how can I access the pump/filter thanks in advance for any help
The pump is behind the lower plastic kick panel, simply grab hold and gently pull outward.
Posted on Mar 11, 2012
  • 10 Answers
I had the code E21 error (not draining) on my 2012 Electrolux EWFLS70JTS0, which I'm guessing is similar to a Frigidaire Front Load Washer. After reading about the potential causes being related to drain or pump obstructions, I decided to try forcing compressed air into the drain hose at the rear of the washer to see if I could push out whatever got into the system. So I moved the washing machine out from the wall, and pulled the drain hose out from its wall inlet. No disassembly required. Then I placed the trigger air nozzle from my compressor into the drain hose that's connected to the back of the machine, and held it in place with my hand so that most of the air pressure would go up the hose and into the machine.
Once I pulled the trigger to start the air flow it only took a few seconds to see bubbles appearing in the washer's tub. At that point it seemed any obstruction was now pushed out (where it went, I'm not sure. Somewhere in the standing water in tub I suspect).
I suppose it would be just as effective to use a garden hose with water (if you don't have an air compressor), but a little more messy. Anyway, as soon as I put it in "quick wash" mode (which starts with a drain cycle), it drained fine. 100% problem solved! No more error code. And no repair bill!. I just hope that whatever was restricting the drain flow does not find its way back into the system again. It's been a couple of days and so far, so good.
Posted on Sep 29, 2013
Hi I have an Electrolux EW Aqualux 1200 in a rented property no manual for the programs would you be able to email me one if available Many thanks rachel
rachel you will find it here if its model number is ew1200
http://www.manualslib.com/download/46075/Electrolux-Ew-1200-I.html
Jun 21, 2016 | Electrolux Washing Machines
Electrolux icon duel fuel range racks red light wont stop flashing even though I removed all racks, so oven will not start self clean cycle
Good Morning Andrea,
I see that you are having trouble with your Electrolux range, model# E30DF74GPS, and getting it to go into the self-clean cycle. I would suggest giving it a hard reset. First make sure the racks are in. Next, cut the power at the circuit breaker and leave it off for 2-3 minutes. After the time has elapsed cut the power back on. Start the self-clean cycle with the racks inside the oven. We're trying to get the oven to recognize the racks are inside. Once it states the racks are in, cancel out and take the racks out. Now, with the racks out start the self-clean cycle again. If you are still receiving the red light blinking, I suggest contacting the manufacturer or your local authorized technician. Hope this has been helpful.
-Best Regards-
WP
Mar 23, 2014 | Electrolux Icon E30df74gps 30" Pro-style...
Won't read any kind of disc it spins and stopped like 3 times and doesn't move anymore
Sounds like you later lens has been damaged or is dirty. There is a cleaning kit at Walmart. If that doesn't work, google a local repair shop.
Feb 16, 2013 | Video Game Consoles & Games
Hi can you tell me which programme is the short wash and spin please
I think I have the same type of washing machine as you do. Wash is when all the clothes get agitated or mixed with soap and water (ever look in there when its washing? the water can get pretty gross looking!) So in my washer, the rinse cycle is when all that gross water is drained, and the washer spins while spraying clean water over the clothes to get rid of the dirty water and soap. I think mine does this 5 or 6 times in the cycle. Next is the spin cycle, which is when the washer spins REALLY fast to **** as much water out of the clothes as possible, so that the clothes aren't sopping wet when you put them in the dryer.
It sounds like your mom has a newer washing machine, probably a front load one, and they do seem to keep using clean water, instead of just agitating the clothes in dirty water.
May 17, 2011 | Electrolux EW1000i Front Load Washer
We have just moved to a house with an electrolux ERF2831 fridge freezer. The fridge appears to be working OK, but sometimes the green pilot light and the amber fast freeze light flash alternately. When...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 17, 2011 | Electrolux ERF2831 Bottom Freezer...
When i put a disc ...the screen goes black and then it says error reading disc please press the eject button and turn the console off. what do i do?
The cause here is the Drive itself is ether dirty or showing signes of intermittency now the folks at www.videogamerepair.com can take this into consideration and have it repaired for you if its under warranty or not give them a try. Otherwise you might need to have nontendo get involved.
Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 03, 2010 | Nintendo Wii Console
Playstaion 3 games wont load how can it be fixed. the clock (loading icon) stops. no errors appear no disk shows up.
listen for the disc to start spinning
if the disc spinns then its prolly just a dirty laser lens and if it doesnt spin could be a bad laser i doubt its the blu ray logic boad cause the ones i have seen that were bad the disk reading icon never stops, this has also happened on broken lenses where it never stops. ussually if it stops its bad motor or dirty lense.
Sep 22, 2009 | Sony Playstation 3 (PS3) Console
My ps3 is acting up
Dirty lens on BluRay? Clean by opening Rom tray and BLASTING it with air. DO NOT TURN CAN UPSIDE DOWN or SIDEWAYS you will ruin the drive with -75degrees (crack glass lens) TKeep can of air upright and move PS3 around
Hot? Make sure you have airspace all around it
P/Supply fan not spinning? Could be packed with dust and causing fire! Give it a big blast too, but DO NOT ALLOW to SPIN FAST for long time - you will burn out bearings and ruin it. I hold it still (Power off) with long thin chinese skewer stick so it do not spin ;-)
Jan 18, 2009 | Sony Playstation 3 (PS3) Console
Frigidaire washer
spin the option button around fast several times unplug it and try it again ......occasionally the connections inside get dirty or somethin it worked for me.... spin it fast!!!! cleans the connections
Oct 25, 2008 | Frigidaire Washing Machines
Electrolux EW1200i Front Load Washer / Dryer Logo
Top Electrolux Washing Machines Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
