Question about Dell E198FP LCD Monitor
My monitor getting white when i turned on the system....and every thing is not visible.....please tell me the solution
  • 11,361 Answers
If you get white glowing screen like the example in my troubleshooting guide, then you need to check the ribbon cable between the logic board and the LCD panel's T-CON board, it can be that the fuse is blown on the T-CON board or the logic board is not sending the 5 or 12vdc to the T-CON board. You need to do visual inpsection for bad connections, caps, etc.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Replacement board: http://www.lcdrepair.us
Posted on Sep 28, 2010
Monitor on my dell Inspiron one i019-1818bga does not come on. Power button is white.
Check with an external monitor. That will tell you if the monitor is faulty or the mother board has issues.
Aug 07, 2015 | Dell Computers & Internet
Computer screen is white and blank..the last thing i did was run a disk defrag and now its completely white...i dont know how to reset the monitor and i hook it up to my laptop to a double monitor options...
Not sure what you mean by resetting the monitor but pulling the power should get it back so you can see the Onscreen menu. If you can get inot the menu there is usually a reset or factory reset option.
As for dual screen w/laptop. The hardest part is telling the laptop to use the extra monitor. On my laptop the Function Key and F8 cycle the external monitor. You also need to tell windows if the new monitor sits to the left or the right of the laptop so the mouse works correctly.
Mar 08, 2014 | eMachines E17T4W 17" Monitor
The monitor will not show a picture the led is flashing green
* If the issue is visible in the monitor STFC (Self-Test Feature Check), the monitor is defective. * If not, the issue is with either the video card driver or the video card.
* Turn off both your PC and monitor * Disconnect the monitor from the PC (either the white DVI or the blue VGA. They should never be connected at the same time to one PC) * Turn the monitor on * The floating Dell red/green/blue/white dialog box should appear on a black background * Check for the issue
Mar 02, 2011 | Dell E173FP 17" LCD Monitor
White screen on lcd nothing visible but output ok
i think you should try Fn-F5 not F6 hold the button down a while
Dec 21, 2009 | ASUS Eee 4G Notebook
KDS K22WDb Monitor with white screen
There are some brands of caps that will blown with no visible damage, also some will blown out the bottom so you can't see the damage. I would replace the caps in the power supply all except for the 1 very big cap on the input side. I would be that this fixes the problem you are having.
Buddy
Sep 07, 2009 | KDS K226WDB Monitor
I have horizontal lines on the top of gateway computer monitor, the blue line at the top is barely visible and the close, minimize, and restore buttons can not be seen, can this be easily fixed with a free...
This could be one of two things:
It could be the monitor that is going bad. If it is, it would be best to replace it.
Second, It could be the Video board or the system memory. Which can be repaired.
If you have access to another monitor or a friend's system,try your computer on it. This will tell you whether it is the monitor or the computer.
Post the findings here, and we can continue to T/S it.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 16, 2008 | Computers & Internet
Heavy white lines accross the screen
change the ram and viedo card agian
Jun 07, 2008 | Computers & Internet
Envision EN 780e Monitor Vertical Problem
u just give reset... the menus must be half visible atleast...
or just see the same type in option in other monitor and just write down how much time u must press navigation and iother buttons to go to reset option & to give reset...
once if u have done wit resetting ur screen will come normal to size then u can adjust height and width....
Feb 03, 2008 | MPC Computers Envision EN 780e (White) 17...
Toshiba Satellite L25-S119 White Display Screen
First, hook up the laptop to an external monitor. Turn it on and try to get into the bios.
How compressed was the air you used to blow out the heatsink, and when you blew it out, did you have it unplugged and the battery removed? When you spin the heat sink fan, it creates current, like a little generator.
I gotta tell you, just removing memory won't cause the problem you're describing.
I've had several Toshibas with lcd issues, mostly caused by the onboard video modules on the motherboard getting hot.
Good luck.
If you can get video to an external monitor, let me know.
Thanks
Jan 23, 2008 | Toshiba Satellite A105-S4004 Notebook
Picture problems
What are normal things like text files and the desk top like? If it only photos that are problematical then it won't be the screen. Have a check around the system and a little think through- them come back
Jul 09, 2007 | Philips 170C4FS 17" LCD Monitor
Dell E198FP LCD Monitor Logo
Alun Cox
