Question about Apple 15" PowerBook G4 Aluminum 1.67 GHz LCD Display (p/n 1002587) (661-3749 1002587) Mac Notebook
Pram battery has been replaced. Battery has been replaced with a new one. Battery isn't charging. Powerbook G4 1.67Ghz
    Problem Solver:
  • 30 Answers
That's a motherboard problem.
Tech from http://www.computerstar.ca/datarecovery.html
Posted on Oct 02, 2010
  • Poppy Chulo
    Poppy Chulo Oct 17, 2010
    NO, not a motherboard problem. If you work on Macs then you know its the power/sound board that has failed or you need a new charger.
Powerbook G4 12" 1.5 Aluminum will not boot. Apple logo and spinning wheel appear, sometimes eventually changing to a blue screen, sometimes remaining, until stopping with on/off switch. Aside from that,...
try booting with disk select option.
hold down option key and power up. Try resetting pram.
Look up key commands on apple support.
Try safe boot with holding down s key
etc....
Aug 28, 2013 | Apple OS Computers & Internet
Powerbook g4 will not start on battery tho battery is fully charged. Will start on AC.
Are the contacts for the battery on the laptop good, no corrosion or anything?
Jun 04, 2012 | Apple PowerBook G4 Mac Notebook
Powerbook 1 67ghz 17"
This computer sounds like it has died. You can try to see if Apple will fix it for you, but I doubt that they will. It may be time to buy a new computer.
Feb 11, 2012 | Apple Powerbook G4 17" 1.67 GHz SuperDrive...
My g4 is bouncing back and forth between the adaptor and the battery and is not charging
This is often due to a knackered battery. Lithium batteries have a life of about 2yrs.
Download Coconut Battery from here (http://www.coconut-flavour.com/coconutbattery/) and this will tell you if it's fine or not.
If the battery is fine, do a firmware reset, then reset the PRAM & NVRAM.
If that doesn't do it, get apple to check out the motherboard.
Dec 08, 2009 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Powerbook g4 12 internal battery... does it exist? Or is it a capacitor? I have been trying to get it to stay switched on. It was perfect until I left it for 2 months off charge, then it started going...
There is no internal Battery. As you said its a capacitor to hold Pram settings while you change the battery.
Replace your battery (or borrow one) that should solve your problem
Nov 04, 2009 | Apple Powerbook G4 Logic Board 1.5GHz...
Mac Powerbook Pro is fully charged, but the hard drive doesn't seem to be engaging--leaves just a blank white screen. We're 300 miles from the start-up disk, any immediate fixes that you can suggest?
when it is off (sounds like all the time now!) remove battery and then try to start, this will reset the Pram,refit battery and start, if ok good if not try starting with the left side shift key depressed, this should cause it to start in safe mode, it disables a lot of start up options and does some housework.
Aug 02, 2009 | Macally Screen Protector for Apple...
G4 1.67 power book. The only way I can get it to boot up is to run the battery flat vie fan motor and then leave it on charge until fully charged. It will then boot up. But if try and restart it will not...
Apple laptops are designed to run properly from AC with no battery installed at all. Physically remove the battery, plug in the AC adapter, and it should run fine.
If it does not, reset the power management unit as described here:
http://support.apple.com/kb/HT1431
If this doesn't work, you have a hardware issue that a repair tech would have to address.
May 05, 2009 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Battery for iBook 14inch not recognized by iBook
you could try resetting your pram..?
Resetting PRAM and NVRAM
  1. Shut down the computer.
  2. Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously in step 4.
  3. Turn on the computer.
  4. Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
  5. Hold the keys down until the computer restarts and you hear the startup sound for the second time.
  6. Release the keys.
Your computer's PRAM and the NVRAM are reset to the default values. The clock settings may be reset to a default date on some models.
Resetting PMU on PowerBook or iBook computers In some troubleshooting situations, if resetting PRAM does not resolve an issue, resetting the PMU may be the next appropriate step. For information on when this is appropriate and for instructions on how to reset the PMU in your PowerBook computer, see Resetting PowerBook and iBook Power Management Unit (PMU).
Mar 20, 2009 | Battery Technology for Apple iBook 14in
PowerBook Aluminum 17" not restarting after SLEEP MODE.
It does, but its not a fault, its a component. You may need to zap your pram or reset the pmu. when the power cable is plugged in, does the battery light flash on the bottom fo the machine confirming its charging? When you press power, does the caps lock key light up after being pressed? if your battery ( extenal ) is faulty, your machine should still power off the auxilary cable. the power cable bypasses the battery when plugged in. Do you keep youpower cable plugged in for extended times regularly, that kills batteries. make sure youre cycling properly.
http://guides.macrumors.com/Laptop_Battery_Guide
http://docs.info.apple.com/article.html?path=Mac/10.4/en/mh1959.html
http://docs.info.apple.com/article.html?artnum=2238
http://docs.info.apple.com/article.html?artnum=14449
Nov 16, 2007 | Apple 3-Year AppleCare for iBook/MacBook...
Apple 15" PowerBook G4 Aluminum 1.67 GHz LCD Display (p/n 1002587) (661-3749 1002587) Mac Notebook Logo
171 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
