Question about Samsung HLS4676S Television
DLP tv was having problems turning on it seem to be the lamp and ballastat so i got new parts. The tv finally whent out, what could be the problem
  • Samsung Master
  • 5,138 Answers
DM module or Light Engine .
Go to Encompass Parts Distribution and type in your model #
1-800-638-3328
Posted on Sep 28, 2010
Samsung dlp tv picture turns off sound stays on
Hello
Check whether the lamp life hours are going to be out. Refer to its user manual for details. DLP chips fault is very rare; unless you have handled them very carefully. Check the lamp and BALLAST baord that supplies voltage to lamp.
Picture of the ballast baord to your TV is attached.2_29_2012_10_35_36_am.jpg
Feb 29, 2012 | Samsung HLR5087W 50" Rear Projection HDTV
TV turns on but lamp never comes on. Seems to try 3 times then all 3 led's on front start flashing. I tried to replace the lamp but problem remains.
If the Lamp has been replaced then problem will be either Lamp Fan or Ballast board .
Ballast board connects to Lamp and it is what powers Lamp on.
Check out Encompass Parts Distribution type in your Model number for a List of Parts/Prices and Part Numbers.
Samsung Parts 1-800-627-4368
Jun 23, 2011 | Samsung DLP HL-P5663W 56" TV
I have a Samsung HL-R5678W DLP TV that is acting up. When I first turn it on everything works, after 5 minutes it shuts itself off. After 2 minutes it will come back on without sound. It will do this a...
U turn tv on hear any squiling,grinding or motor noises?Picture show up before it shut down picture have flashes of black&white within the picture?Yes,to all of these,this tv have a colors wheel and it dead,require the colors wheel replacing.No,none of these problems.The tv projection lamp,if in this tv like a 1 1/2 or 2 years,tv ben on an watches like 4 or 5 hours a day?The "LAMP" LED light indication lite up or flahes,the projection lamp life is over.Require a new projection lamp.
Oct 22, 2010 | Samsung DLP HL-P5663W 56" TV
My tv was accidentally unplugged while it was still on and when i turned it back on there is audio no video and the green light just flashes next the to the red light and the tv turns on and off by itself...
Hi
Thanks for using FixYa. From what you have described it seems to be a shutdown circuit problem, and a problem in the section of the TV that provides High Voltage to drive the raster creating circuitry. Usually the issue is with the bulb going bad however, as you have already replaced the bulb few months back, so in your case this would also be the DLP related circuitry which includes the light engine (white light bulb/Color wheel drive circuitry or LED array, DLP chip and associated circuitry). If you want to do the repair yourself then it is highly recommended that you should have knowledge of internal circuitry of the TV, if not then it is always better to take assistance from a qualified repair tech. The cost of repair will be around $300 including labor if you get it done by a professional.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 17, 2010 | Toshiba 52HM95 52" HDTV Projection...
Toshiba 52HM84 DLP TV with new bulb but the lights keep blinking
They exact way the lights blink are telling you what the failure is. If the tv is firing the lamp and the lamp is bad, you will hear a buzz sound for about 1 second. The tv tries 8 times before it gives up and spits out the lamp error. Check the user manual for led diagnostics. If you put in a new lamp but still have issues, you've likely got a bad ballast (most common on this model) or colorwheel (less common). Both are part of the optical block (light engine) and I don't believe they're available as individual components from toshiba.
Nov 28, 2008 | Toshiba 52HM95 52" HDTV Projection...
Samsung DLP HLM-617W/XAA
with lamp out (door closed) the ballast should "strike" or give an arc sound, trying to fire the lamp. If it does not do that maybe the color wheel is not spinning up - has to do that first.........then the set will try to fire the lamp
Jul 18, 2008 | Samsung DLP HL-P5663W 56" TV
Issues with replacing Ballast
I have some proble dlp tv I put new lamp;put the problem didnt whant away
May 05, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Black screen with a Blinking lamp in the front
Hi..if your lamp is on but no picture, then your lamp is good. Your problem is the DMD board (digital mirror display board) is bad. This is very common with Samsung DLP.
Mar 27, 2008 | Samsung HLR5667W 56" Rear Projection HDTV
Hewitt Packard high definition DLP tv Product #EX543AA#ABA need part, hp no longer carries them.
I have a brand new L2114a lamp for sale. I paid 299 plus shipping on ebay but it turned out to be the wrong one (despite what the manual says). I ordered the correct one I needed from HP. I am willing to part with it for 200. I can send pictures of the lamp and the box and the reciept. This is a BRAND NEW LAMP.
This lamp works in the following televisions and replaces the lamps listed below:
HP Pavilion md5020n 50-inch High Definition DLP TV L1735A
HP Pavilion md5820n 58-inch High Definition DLP TV L1736A
HP Pavilion md6580n 65-inch High Definition DLP TV L1737A
HP Pavilion md5880n 58-inch High Definition DLP TV L1798A
Jan 28, 2008 | Televison & Video
Open Questions:
Samsung HLS4676S Television Logo
115 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
