Question about Kenmore 54599 / 54592 / 54594 / 54596 Side by Side Refrigerator
Ice maker door chute freezes. How do you fix the door flap that could be causing this?
icansurf
  • 72 Answers
SOURCE: ice maker thru the door
usually due to rust or crud build-up. try lubricating moving parts with WD-40, or possibly removing accessible screws/bolts and manually cleaning it up.
Posted on Jul 11, 2007
watugot
  • 290 Answers
SOURCE: GE Icemaker flap door won't open causes ice jam in chute
There is an electric solenoid that opens the door. If you look up inside the dispenser you can see the solenoid. Either the solenoid is bad or the dispenser module that puts power to it is out. You will need to remove dispenser front and check for voltage to solenoid. If you have power from module, replace solenoid, if no power, replace both parts. It is common for solenoid to short out and damage the module so that both must be replaced. If solenoid is shorted and you replace module, new part will fry.
Posted on Oct 02, 2007
fanny
  • 146 Answers
SOURCE: ice maker failure
1) Check the filler tube which allows water to enter the dispenser through the back wall of the freezer. This tube may be frozen inside. You can pull the tube out gently and clear it.
2) The inlet valve may be faulty/blocked. Where the water connects to the water valves behind the fridge, try to swap the plugs around from the one valve to the other. They should be colour coded. Then try dispensing water. If water runs into the ice-maker then the ice maker valve is faulty/blocked.
Posted on Oct 30, 2007
  • 3422 Answers
SOURCE: Kenmore Elite side by side - Icemaker chute freezes up, no ice
To make sure I am understanding you correctly, are you saying that after a normal fill, water continues to drip into the ice maker and freezes in the fill chute?? If yes, than replace the water valve.
If not then:
does the flap shut all the way? Sounds like you are drawing moisture from the chute. The flapper should seat so that no air is being drawn in. I have seen a number of these Kenmore where the pin and spring retainer has broken off from the dispensor housing causing this problem. They use to replace the whole freezer door because the dispensor housing is not a servicable part. They have now come out with a kit to address this problem. This is not a fun job for a first timer. You may want to contact Kenmore and inquire about the aforementioned. If this is your case, there is a good chance they will cover it.
Goodluck,
Please don't forget to rate me as fixya..
Posted on Feb 08, 2008
pride applia
  • 232 Answers
SOURCE: My Kenmore side by side ice dispenser on the door freezes up!
need complete model #
Posted on Jul 02, 2009
The ice does not dispense from the chute. The chute freezes up and the ice can no longer travel down the chute and out the dispenser. Can this be fixed?
Yes the flap is supposed to close completly to stop the moist kitchen air freezing in the chute and blocking it
Sep 19, 2014 | Refrigerators
If not then:
Goodluck,
Feb 08, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker works fine but ice will not vend out of the storage bin. Ice freezes in the vending area
Check the door flap where the ice comes out into the dispenser. The number one cause of the ice build up in the dispenser chute is caused from warm air leaking into the freezer and clashing with the freezer air.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 30, 2012 | Refrigerators
Ice sticing in ice dispenser chute
only use ice from the ice maker, some frost is normal, but , lower temp in freezer
May 19, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice cube flap door
try this site...input your model # and look for the ice door parts. Maybe a bad spring. They are also very helpful with their chat and phone assist., video repair etc. Make sure to get the model # though.
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Refrigerator/62-5-1414685-/Whirlpool-Refrigerator-ice-maker-overflowing-WRX735SDBM00?r=%2fShop-For-Parts%2fa4b5c21i2659d1414685%2fModel-WRX735SDBM00-Whirlpool-Refrigerator-Gasket-Seal-Door-Gasket-Parts
Best to you.
Oct 22, 2017 | GE Refrigerators
Whirlpool side by side ice maker freezes up. can't get ice out of
Can you give more details?
If the ice chute is frosting up, chute door is not sealing, air , with moisture, is getting in and freezing. An ice cube getting trapped by the door will cause this also. Either case, replace door and delay mechanism.
May 01, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Icemaker - flap won't open, cubes collect in chute
the actuating paddle that you are depressing to dispense ice actually pushes the door open at the top of the dispensor, soundsas if thered an issue withthe actuator arm
Nov 18, 2008 | Frigidaire FRS26R4A Side by Side...
Bottom of ice maker/dispenser frosting over
Open the freezer door and look down the ice chute while you shine a flashlite up the dispenser cute from the outside. If you see light around the chute door, it needs to be replaced or something is wrong with the mechanism. The problem you describe is almost always air leakage around that flap.
Post back if you need more help.
Nov 17, 2007 | Whirlpool GC5SHEXNS Side by Side...
Oct 02, 2007 | GE 17.2 cu. ft. Top Freezer Refrigerator...
Whirpool Side by Side Ice Dispenser Freezes up
Think you have it figured out. Just had a similar problem. The flap leaked air (moisture) up into the area which then froze. Then the customer chipped it out with a knife and not only damaged the flap seal worse but also made the chute area rough from the knife tip "burrs" in the plastic chute. A new flap door with factory seal along with sanding down the burrs cured the problem. Spraying something food grade like Pam cooking spray (very lightly) will aid in the ice cube/crushed ice to slide down the chute better. With any refer, keep the moisture out or it WILL freeze up stuff.
Nov 02, 2006 | Whirlpool ED0GTKX Side by Side...
Kenmore 54599 / 54592 / 54594 / 54596 Side by Side Refrigerator Logo
43 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
