Question about Pentair 3hp Whisperflo Pool Pump In - Ground
2 speed pump makes a buzzing sound and will not turn on when called to run. replaced capacitor, same problem.....
  • 44 Answers
Unfortunately your motor has shorted out and needs to be replaced.
Posted on Sep 28, 2010
Runs fine on low speed hums on high speed (turns slowly) is it a capacitor problem, internal windings or controller?
Motor itself is the culprit.
Capacitor helps the motor to start spinning from a dead stop, so NO, it is not a capacitor problem.
Probably high speed windings. Means - New Motor needed.
Another possibility, is the controller could be sending power to "Both" sides of the windings: High speed & Low speed at the same time. But normally when this happens, you hear a loud buzz type of sound, motor will spin slowly - if at all.
Good Luck
Mar 11, 2015 | Pool & Spa
Emerson 1081 pool pump makes buzzing noise when i turn it on wont start
Either something blocking the impeller / shaft, from turning or the motor failed.
You can try to manually assist the motor, by removing the small cap at the back of the motor, getting a flat blade screwdriver, and right when you flip the switch (get a helper) turn the shaft clockwise while it buzzes. If it takes off - possible Bad Capacitor? Try a couple times if it doesn't take.
if bad capacitor, make sure you get the exact replacement, or 'Slightly Greater' will work - and I refer to the MFD number. Don't go smaller!
May 29, 2014 | Emerson THREADED SHAFT UP RATED - 1.00 HP...
Pump makes a humming sound but will not run
Don't run it hot or it will stop working.
Sounds like start capacitor has gone bad.
Copy following link for motor troubleshoot resources:
http://waterheatertimer.org/Color-codewire.html#motor
Add a comment
May 27, 2013 | AO Smith Centurion 1081 2 Hp Standard...
Is it normal for the fuel pump to run when engine is running, It makes a buzzing sound
if the pump runs continuously after the ignition has been turned off, then the pump is malfunctioning. Some after market pumps do make odd sounds, unlike the factory original.
Dec 22, 2012 | 1998 Dodge Avenger
Hi my 3/4 hp 230/115 centurian is buzzing and i smell burnt electrics.....what do i need to order to fix?
If the motor can be turned easily by hand then sometimes the starting or run capacitor can be replaced with the same value device and the pump will run. If a new capacitor is installed and it doesn't run then the motor needs to be replaced. If the motor does not turn easily then usually the bearings are bad and the motor needs to be replaced. I hope this helps. The burned smell is either overheated wiring in the motor or a bad capacitor, etc.
Aug 05, 2011 | AO Smith Pool Pump Motor Hayward Swimming...
My Whisperflo was making a buzzing noise while pumping. I turned it off to clean the strainers and now when I turn it on it makes a loud buzzing noise and the motor does not spin. The impeller moves...
it's a bad start/run capacitor. It's under the hump on top of the motor. DO NOT touch the terminals with your bare hands in case the capacitor is charged. You can replace it with an exact match.
Sep 06, 2010 | Pentair 1.0 Hp Whisperflo Pump
Tv tries to turn but makes a buzzing sound then
If it was the CL030 capacitor which is a gray rectangle .0087uf 2000V capacitor. The deflection board will most likely need the flyback and the HOT replaced as well.
Jan 01, 2010 | GE D52GW12 52" Rear Projection HDTV-Ready...
THE MOTOR IS MAKING LOUD NOISE BUT DOES NOT RUN. IS IT POSSIBLE THAT THE RUN CAPACITOR IS BAD?
It is the capacitor but a capacitor usally goes out because the motor is going out. Time for a new motor, You might want to look at replacing the whole pump with an energy effiecent variable speed pump.
Aug 23, 2009 | Hayward 2HP Pool Pump Motor A O Smith...
My 2 speed jandy pool pump is over heating
you may either have a bad start/run capacitor for the high speed side or bad supply voltage feeding the high speed side. If there are no loud bearing noises, it should just be either of those two problems.
Aug 15, 2009 | Jandy PlusHP Pool Pump EE Dual Speed - 2.0...
Kenmore microwave making loud buzzing sound.
Mar 05, 2009 | Kenmore 62622 Microwave Oven
Pentair 3hp Whisperflo Pool Pump In - Ground Logo
105 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
