Question about Disney Hannah Montana HM1500LT TV
Lost remote to tv and cannot change the input on the tv to av without remote. Universal remotes do not have a code for this tv.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 100 Answers
Contact the manufacturer? They may have a lead for you.
Posted on Sep 28, 2010
Lost remote for tv.can it work without?
Without the remote, you should be able to perform basic tasks, such as:
-change volume level
-change progamme
-turn the tv on/off
-possibly access AV or other inputs
if your tv has a MENU button on it, then you will be able to perform more complex tasks and you may even be able to tune it in etc.
Alternatively, you can purchase a universal remote control that can be programmed to use with your tv.
Aug 27, 2011 | Televison & Video
My sylvania tv wont change inputs. I lost the remote so is there another way to change it to av.
You have to have the remote to change inputs on this set. Probably a universal remote will work good.
Oct 15, 2009 | Sylvania 6419TC 19" TV
Lost sponge bob tv remote control
Get the RCA 4 device universal remote from radio shack. model #RCR4383N $10.00. It wouldn't work using the emerson codes in the manual. Let it find the code automatically. input button on bottom will switch to and from AV input.
Oct 10, 2009 | Emerson SpongeBob SquarePants TV
Phillips 19 inch TV/VCR combo --no remote--can't change channels
I cannot be sure of the exact model but... Press and hold the TV's volume up and volume down buttons simultaneously. On many older televisions, this opens the device menu without the use of a remote. Otherwise, use the menu button, which you can navigate in a similar fashion.
Also, somewhere should be an input button. Press it multiple times times to switch between various inputs (the input must match whatever input you are using). Usually after these menus are opened you can use vol up vol down to change things.
Jul 13, 2017 | Philips CCC193AT 19 in. TV/VCR Combo
How can I turn to AV without a remote control (Samsung TV/VCR 19in Combo)
you might try going to channel 00
If you cannot just dial the number 00, go to channel 2 and then channel down.
Does not always work, but without the model number of the TV it is hard to advise further
Mar 12, 2009 | Televison & Video
Lost remote
Actually I found there are several remotes that work. The first is the Bright House networks remote, the larger one...The second is The Universal Remove Control by GE. It's numbered 24944 in the upper right hand corner of the paper. It's sold for $4.94 at Walmart in the checkout area...
I found that manually inputting the code for the remote doesn't work. You have to do a search for the code using their method...on this particular remote from Walmart, its hold the setup button down until it lights up, then press and depress the TV button...then press channel up until the TV changes channels. It worked once, but I just kept going, the 2nd time it worked, then I pressed the mute button [to keep the code] and it works...you simply press input and it switches to AV.
I have to admit I thought it was ridiculous that you can't use this particular TV without the remote, but I was happy that I went through the effort the first time to keep trying remotes...
This is the first kids TV that I have found that you can't find the AV channel by going through the channels AND you can't hook up two items to the AV outlets because you have to disconnect the back or front ones, to use the other....PLUS it only comes with a dual AV outlet, instead of the 3 plugs [red, white, yellow] only has the white and yellow.
A disappointing TV to say the least.
Feb 11, 2009 | Emerson SpongeBob SquarePants TV
Universal remote works for basics but won't change input
Rich,
good day , what button can you see infront of your TV screen?
Not familiar with this model but if you'll manage to locate a button marked as "TV/AV" or "AV" press this button until it the display switch to A/V mode (audio/video). Or if this is a really old model, from Tuner mode or channel model. set the channel station to 1 then press the " - channel " button and see if it will change from tuner mode to A/V mode
cheers,
mark
Jan 31, 2009 | Toshiba 32A33 32" TV
Teenage mutant Ninja turtles 13 inch TV
My son has a TMNT tv and the remote is broken or just the button to turn it to the games. I bought a universal remote and it does work some so that he can play his games but it doesn't let him enter two digit channels to change them so he has to scroll through them to get where he wants. It is an RCA - RCR312W remote and is universal but I had to go through the steps for the auto code search which was a little confusing and took a little while. The remote only cost about 8.00. All of the features don't work and I am sure that with a little playing around I could figure out the brand from the code but I haven't yet. Hope that this helps and if anyone else has a better solution please let me know.
Thanks!
Jun 16, 2008 | Emerson SpongeBob SquarePants TV
I had this problem with my TV/VCR combo unit (Samsung CXC1972) after losing the remote while in the dorms. I tried a few different universal remotes and dozens of codes before I tried the Philips 3 device universal remote as pictured below with code 037 programmed into the VCR/DVD button. I can't change the volume with this code but the input key switches between line in and tv. You can also change the channel, access the menu and operate the VCR functions with the code. I bought the remote for less than $10 at Walmart so it might be worth a try, and if it doesn't work you can always bring it back. Hope this helps.98fe8a9.jpg
Feb 18, 2007 | Samsung CXJ1964 19 in. TV/VCR Combo
Disney Hannah Montana HM1500LT TV Logo
414 people viewed this question
Top Disney Televison & Video Experts
Jaime Hernandez
Chris Goulet
Are you a Disney Televison and Video Expert? Answer questions, earn points and help others
