Question about Goodman CKL42AR42 Air Conditioner
That unit takes first the one of outside or within the house they goodman aruf364216ba / gsz130421ab
  • 306 Answers
SOURCE: Goodman air conditioner will not turn on outside
When ever you hear a buzzing like you are hearing means one thing one of the fuses on the outside disconnect box is bad. Only getting 1/2 the power. Find the bad fuse and get the same size and will be good to go. ken
Posted on May 02, 2009
  • 340 Answers
SOURCE: I have a Goodman air conditioner. My outside unit
If you are sure of the power then ya have a control problem thermostat set correctly? could be open low pressure switch I would call for service. Tom
Posted on Jul 03, 2009
co7196
  • 3433 Answers
SOURCE: Goodman Air (outside unit)
was there any refrigerant loss? "bumping" that results in movng usualy causes a leak.If the system is totally empty, It shouldn't start.. If it did major oh nos! will appear. Does it not start all? and was it running when it got thumped? May have to call a tech out on it. Sorry.
Posted on Jul 29, 2009
SOURCE: goodman mini split unit condensating and leaking
Hi, your evap. drain is block, i know you are smart, we can do this, remove front cover of evap.(indoor unit) check for location of screws, look carefully you will see drain connection and tray, try to clean, use mild cleaning solvent, or practical way push something flexible into tubing, also clear your air filter, and you'll be in good shape, also check leveling of evap(indoor unit), with spirit level, should be horozontally leved. good luck.
Posted on Aug 10, 2009
kingbrizzle
  • 407 Answers
SOURCE: have Goodman model CK36-18 outside a/c unit that
There could be a number of problems why. Some would include:
Faulty thermostat-
Test by pulling of the cover and jumping the R terminal to the Y terminal and if it works then, you have a faulty thermostat.
Faulty capacitor-
This is located on the outside unit in the electrical compartment. It is a round or oval shaped cap with wires coming from the top and can only be checked if you have a multimeter that has MicroFarads available. If so, you pull the wires off (remembering exactly how they were hooked up) and put your test leads to the Herm and Com terminals and get your reading. Then you look at the label and see if your numbers match up. IMPORTANT: Disconnect the line voltage before opening the electrical compartment on the condenser!
Faulty Electrical Board-
Located on the inside unit, most models have boards that will give you a code with a flashing LED light now. The code list is usually on the back of the furnace doors. If you dont have a board at all, then the furnace is an older model and the trouble-shooting could get a little more difficult. If it has the board, try locating a fuse on the board and checking if its blown, if it is, replace and see if thats the only problem.
These are just a few things that you can check. I hope it helps somewhat. Good Luck!
Posted on Jun 26, 2010
We have a Goodman AC Unit and the pipe continues to freeze.
either the inside coil is dirty or system is overcharged.
May 14, 2014 | Goodman CLQ36AR49 Air Conditioner
Goodman AC unit
It doesn't look like the other 4 were used. Unless when it got "yanked" it also got cut. I am betting you don't need them though.
May 14, 2013 | Heating & Cooling
Air condition jsut 10 month old ... not keeping up whith cooling
If it's only 92° outside and the unit won't cool the house, then the unit is either to small or it's low on refrigerant. They are designed to cool a house with outdoor temperatures up to 115° to 120°.Usually you need one ton a/c for every 400 square feet of house, but, you have to take into account for average outdoor temperature and humidity, windows, doors, especially sliding glass or patio doors and which side of the house they are on, insulation in walls and attic.
The air leaving your duct work going into the rooms should be about 20° lower than the room temperature, if you have a 80° room then the air leaving the duct should be around 60°. if it is then the unit is probably to small if, everything is working properly.
Jun 07, 2010 | Goodman CLQ36AR49 Air Conditioner
Not cooling, water is leaking around the outside unit. plus ice has formed around hose on the unit outside. goodman model number gsh130421ac.
take a garden hose and wash the unit real good,if the unit outside cant breath this will cause it to freeze up
May 16, 2010 | Goodman CKL36AR36 Air Conditioner
Where is fuse located on goodman ckl60-1 ac unit?
I'd be surprised if you had a fuse in either the outside or inside unit. Typically the fuse(s) are mounted in a gray electrical box (on the house) near the outside unit.
You can usually - easily see the fuse box but if you don't just follow the electrical conduit from the outside unit - to the fuse box.
good luck!
Apr 30, 2010 | Goodman CKL60AR60 Air Conditioner
The air conditioning unit outside is running but there is no cold air coming into the house. I hear the inside unit turning off and on but no cold air. I also smell a burning odor. I have turned off the...
if unit is going on then off within a few minutes needs service can be needing freon,outside dirty causing overheating,power supply if 220 not getting full power ,to compressor going bad
Sep 26, 2009 | Goodman CLQ36AR49 Air Conditioner
Goodman CKL42AR42 Air Conditioner Logo
67 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
