Question about Karcher FactoryReconditioned 1400 PSI 13 GPM Electric Pressure Washer K
No power going to the machine - Karcher FactoryReconditioned 1400 PSI 13 GPM Electric Pressure Washer K
    President:
  • 512 Answers
A few things to check, the GFI plug has tripped, the machine has safety switches under cover, could have gotten wet and froze. Take cover off, plug machine in, with a electrical tester start where power enters machine and test all switches till you find bad one.
Posted on Sep 28, 2010
My Bosch 1244E will not go on I plug it and no power?
Washing Machine Won't Start - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jun 21, 2013 - If wall socket & fuse are OK but washing machine won't start ... didn't work - so I tried plugging my Hoover washing machine into another plug and all systems are go! ... I have a bosch washing machine which is 16 months old.
Washing Machine Fault Diagnosis - How to repair
www.how-to-repair.com > Home > Washing machines
Nov 11, 2014 - Washing machine will not start, no power. ... So begin at the plugand make sure that there is power to the socket and that the fuse is okay ... I have aBosch washing machine which is leaking from underneath and the water is coming out the front at the bottom. .... It washes but won't go into rinse or spin.
Washing Machine Will Not Start - What To Check - How To Fix
removeandreplace.com/.../washing-machine-will-not-start-what-to-check...
Apr 10, 2015 - Be sure the washer is plugged into the electrical outlet in the wall. ... If the lid switch is faulty, then the washing machine will not start. ... If the lid switch is being pressed but no power is being supplied to the washers motor, ..... October 28, 2014; Bosch Washing Machine Error Fault Codes October 28, 2014 ...
Dishwasher Will Not Turn On - How To Fix ...
Jan 19, 2016 | Bosch Washing Machines
Kubota troubleshooting
Check the cables going to the battery. Make sure you have a good ground and a good connection to the starter.
Jun 07, 2017 | Cars & Trucks
Whirlpool 6th sense 7.5kg washing machine. My machine has lost all signs of power. Ive checked the power points, cleared the lint catchment and taken the top panel off but no signs of cables burnt or...
you need to check if power is going all the way to the board. The only way to do this is to trace the power cable to the board. When you have located now comes the tricky part. You will need a current tester. You will need to put the probes of the tester into the power cable (one on each side) and switch the power on to the machine. I would only recommend doing this if you are very competent in electrics. If you do this and find a full 230 going to this plug then it means you're board is dead and its new machine time if you are not covered by your parts guarantee. If there is no power going to the plug then you need to recheck back down the line
Oct 16, 2013 | Washing Machines
Machine has no power, it is plugged in and the fuse has been changed, there is power to the socket,
IF there is no power going to the machine.possible fuse not properly mounted.Try to check using a tester if power is flowing to machine.From the socket,use an extension wire and check if power is flowing within the circuit if it is the problem is in the machine.Did the machine blown out?
Jun 21, 2011 | Washing Machines
No power going to the wahsing machine
CHECK THE SWITCH BOARD WITH TESTER IF SUPPLY IS COMING IF IT COMES THEN CHECK IF THE POWER CORD IS ALRIGHT THEN OPEN THE MACHINE AND CHECK IT INSIDE
Jun 10, 2009 | Fisher Washing Machines
My washing machine is blacked out even when i swtich on the powear
WHITE WIRES ARE USUALLY NOT HOT. THEY ARE NEUTRAL
Apr 13, 2009 | Washing Machines
Won't power up, after cleaning????
There is a switch that shuts the machine off when the door is open, Be sure machine is on and all components in and press the switch manually and see if it comes on. Some times the switch gets cocked to one side and the activator on the door misses it. Let me know
Sep 05, 2007 | Saeco Vienna SuperAutomatica Coffee...
Karcher FactoryReconditioned  1400 PSI 13 GPM Electric Pressure Washer K Logo
258 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
