Question about Ingersoll Rand - Rand Type - 30 Reciprocating Air Compressor - 5 Hp, 230 Volt 1 Phase, Model - 2340L5
Air leaking from air pressure switch - Ingersoll Rand - Rand Type - 30 Reciprocating Air Compressor - 5 Hp, 230 Volt 1 Phase, Model - 2340L5
    President:
  • Ingersoll Master
  • 1,383 Answers
Most pressure switches use a diaphragm to activate the contacts that may leak, however, air leaking from the unloader after compressor reaches cut-out is result of in-tank check valve. Easy to check. Turn off power to unit and remove 1/4" tubing at the check valve (follow 1/4 tubing from pressure switch to check valve). If leaking remove from tank and clean debris under seat or replace with generic from www.grainger.com Good luck
Posted on Sep 28, 2010
Error code 13. Turned water on to machine and it leaked.
Try this link
it says the following:
E13 Condition Water leak in the tub or air leak in pressure-switch air hose Check/Repair The washer fills for too long without the water level pressure switch tripping to indicate that the washer is full. Check for a leak in the wash tub. If the tub is not leaking, check to see if the washer is overfilling. If it is, check the air hose and water-level pressure switch for problems.
Shop Parts Outer wash tub, Air hose, Water-level pressure switch
Frigidaire Front Load Washer Error Codes Sears PartsDirect
Jun 09, 2015 | Frigidaire Washing Machines
Bostitch compressor
If air continues to leak from the pressure switch after cycle is indication that the check valve is not sealing or the pressure switch diaphragm has failed. Easy fix. Follow the 1/4 inch airline to the tank and remove the line from the brass valve(check valve). If air is leaking at the brass valve, remove it and attempt to clear debris under valve or replace as needed. If no air is leaking from the checkvalve, then most likely diaphragm is leaking. You could replace the diaprhagm or the whole switch. Generic switch is available thru ebay about 18- $20
Oct 29, 2011 | Air Tools & Compressors
Air leak coming form the pressure switch
Air leaking from the pressure switch indicates that the in-tank check valve is leaking. Follow the air discharge hose from the compressor to the tank. The brass valve at the tank is the check valve. With air in the tank remove the inlet hose from the checkvalve and spray soapy water on valve to check for leaks. If leaking, remove the valve and check for debris under seat or replace. If the check valve is not leaking then pressue switch is leaking from within switch(spray soapy water below switch) . Good luck
Sep 23, 2011 | Dewalt 2 Hp 4 GAL Air Compressor
Craftsman 5 HP MO-6436 Unit will run, pressurize, and hold pressure pretty good. But, after use has decreased pressure to the cut-off point where it should kick back on, it does not. Well, it turns...
If the unit does not unload properly the motor will have difficulty starting. Make sure that the intank check valve is not leaking air back out of tank (with pressure in tank, remove hose from compressor at tank checkvalve and spray soapy water). Replace as needed if leaking or try to repair. If the valve is not leaking then issue my be unloader valve at the pressure switch. Follow small airline from checkvalve to pressure switch. Small valve stem at the pressure switch should release air in line when pressure switch cuts off. Listen for small amount of air to be released when unit shuts off, if air continues to leak out, then check valve is leaking. Replace with generic parts making sure of fitting size. Good luck
Mar 08, 2011 | Craftsman Air Tools & Compressors
How dose the unloader work on a T30 compresser ? T30 compresser has small air leak sound comming from intake ? Is there a flow chart of how ther air is compressed T30 ?
There is no unloader on a 2340N5 compressor. However there is a pressure switch that cuts the motor on an off. Located inside of the pressure switch is an air bleeder. When the pressure switch is opened the motor is shut off. A small lever in the pressure switch pushes down on the bleeder valve which lets the air on the compressor head to be released. This allows the the compressor to start up freely. There should be some air heard bleeding off at the pressure switch. If air continues to bleed off all the time the tank check valve is leaking.
If air is leaking back thru the compressor an air leak sound coming from around the air filter (intake) you have a valve leaking allowing trapped pressure to escape thru the air filter (Intake).
I would search the web for a flow chart. I have not seen one.
Nov 16, 2010 | Ingersoll Rand Type 30 Reciprocating Air...
Leaking air
When the Pressure switch shuts off, the little air valve in the pressure switch vents the copper line from the compressor, to blead the pressure from the compressor so it's easier to start the next time. If it continues to leak, the check valve between compressor and tank must not be holding.
Jul 16, 2010 | Ingersoll Rand - Rand - Ir 2545K10FP Type...
Air leaks from pressure switch
The safety over-pressure valve is leaking and needs to be changed.
Nov 05, 2009 | Dishwashers
Coleman Powermate Model Number BV6548049, pressure switch leak.
Usually, a leak at the pressure switch unloader valve is caused by the checkvalve in the tank. The unloader valve at the pressure switch bleeds out the air from discharge tube after compressor reaches set pressure. This only takes a few seconds. If air continues to leak then air is leaking back into the discharge tube past the tank checkvalve. Follow the air discharge line from the compressor to the brass valve at the tank. The brass valve is the checkvalve that holds the pressure in the tank. There are usually two connections at this valve. One is the unloader tube to the pressure switch. Simple test for leaking checkvalve, with pressure in tank unplug or switch off the compressor and remove the small unloader line at the checkvalve(brass valve) and look/listen for leak. If leaking, remove the checkvalve and examine seat/check for debris keeping the valve slightly open. If it cannot be cleaned, order generic replacement from www.grainger.com. It will cost less than the factory checkvalve. Just pay attention to the thread sizes for easy fit. Good Luck on your repair and email if you have questions.
Mar 25, 2009 | Coleman Powermate 60 Gallon Air Compressor
Makita MAC2200 runs fine (with new Manifold Switch and repaired power cord) but there is an air leak under the new manifold switch that seems to be a feature of the switch. When set to automatic, the...
I have worked on many makita compressors and have run-across this problem on a few of them. Your compressor has a check valve that is supposed to hold tank pressure after the switch reaches set pressure. There is an unloader valve built into the pressure switch that releases the pressure in the discharge hose after the unit shuts off. The unloader allows the compressor to restart with-out any pressure in the discharge line. If the brass check valve is leaking pressure back into the system, air will leak out of the unloader valve. Follow the discharge line to the tank and you will see the brass check valve. To test valve for fault, run the compressor till it builds around 80 psi and unplug the unit from the wall outlet. Remove the 1/4" hose connector from the check valve and check for air leaking out of the valve. If it is leaking you can order form www.toolpartsdirect.com. or call the makita 1-800 number. The price is about the same. Good Luck on your repair.
Mar 18, 2009 | Makita Air Tools & Compressors
Ingersoll Rand - Rand Type - 30 Reciprocating Air Compressor - 5 Hp, 230 Volt 1 Phase, Model - 2340L5 Logo
243 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
