Question about Hoover U5194-900 Mach5 Multi-Chamber Cyclonic Vacuum Cleaner Bagless Vacuum
Hoover Mach 5 turns off after 5 minutes of using. Can you advise the problem?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 100 Answers
5 minutes everytime? If so, raise brush all the way, and vacuum next to nothing. in fact, tilt vac up so the brush touches nothing. wait 5 minutes. If it doesn't shut off, your brush is set too high. if it does, the motor is over heating. make sure bag is empty, no debris in brush, filters clean and make sure you're not plugged into an outlet that a breaker on the outlet can pop too.
Posted on Sep 28, 2010
2 Suggested Answers
SOURCE: Hoover mach 5 turns off after 10 minutes of use
I have had problems with the belts on my Mach 5 overheating (smell of burning rubber) and also with the motor overheating and shutting down.
I learned the hard way that one of the issues might be that the roller/brush on the bottom of the unit has a metal bearing inside the roller/brush that can become clogged with hair (both human and pet hair) which effects performance of the unit.
Another item to check is if your dust filter is not plugged up which is located behind the removable dirt cup. This is the cup that you remove that collects the dust/dirt/hair from your floor. Take the removable dirt cup out by depressing the gold button and then look behind where the dirt cup sits for filter. This can be cleaned out by washing it with soap and water in the sink but make sure you let it dry overnight before placing it back in the machine. This probably causes some of the overheating when not enough clean air is passing through the machine.
It’s fairly easy to fix.
Lay the vacuum on the floor so that you can see the roller/brush. Then remove the phillip head screws that hold the protective plastic plate over the roller/brush. (There are about 6 screws that hold this plastic protective plate in place) Also, you will be removing the (1) screw that also holds the plastic plate over the belts. There are (2) belts that you can remove and when in doubt replace these (2) belts for around $9.00.
Once you have the protective plastic plate off that covers the roller/brush disconnect the belt is around the roller. Take the roller and cut off any hair that is wrapped around the roller. Next, grab the roller by each end and twist the ends caps and (1) of the ends will unscrew. Once you have unscrewed one of the ends remove any hair or dust that is trapped under this cap. (Be careful not to lose the small metal washer that sit on top of the bearing)You will notice under this cap is a metal bearing that can become clogged and jammed with hair. The hair should come out fairly easy and allow the brush to spin fairly easy once you have screwed the end caps back in place test that it spins freely. If it doesn’t spin freely replace the roller/brush with a new one for about $23.00.
When you put the belts back on the thick rubber one (Belt # 40201-271) has probably become stretched and should be replaced for about $3.00. The small diameter belt that goes over the roller/brush probably does not usually need to be replaced and does not usually fit very tight. I have heard that people will take the small roller/brush belt and turn it upside down to get a better fit.
I just did this on my Mach 5 and it runs like a new machine. I did end up replacing the roller/brush head.
Hopefully you will find this useful.
Posted on Dec 29, 2009
It is a Hoover mach 5 runs a few minutes then shuts off no power laglass@sbcglobal.net
This sounds like a thermal limiter issue, usually caused by restricted air flow. Investigate until you find a blockage.
Dec 12, 2010 | Hoover U8145-900 Savvy Bagless Upright...
While vacuuming with my hoover mach 5 it all the sudden shut down
Hi, If it is warm to the touch, and it just shut down all of a sudden, I would say that the motor has an internal over load switch that is normally closed, and opened to stop from burning this vac out. It is a built-in safety. I would look at the roller for anything that may have hung up, but steady use for an hour just over heated the motor. Let it cool way down. Try and start it. Also, check the plug to see if you may have lost power there also. Let me know please so I can be of any help you may need.
Sincerely,
Shastalaker7
Nov 08, 2009 | Vacuums
I have a Hoover Wind Tunnel Supreme mach 3.9. It
Check the filter above the dirt tank. If you take out the dirt cup and look where in slides into the machine, there is a filter that is probably dirty. It can be cleaned or replaced
Oct 08, 2009 | Hoover Vacuums
Our Mach 5 turns off after running for about 5 minutes and smells hot!! Help!!! We have 3 kids and I need to Vacumn.
Hello:
Go here
Then find the clean filter section and clean all the filters especially the secondary filters. i think this will solve your problem.
Jul 07, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
Hoover mach6 the brushes don't turn
Replace the skinny belt, but here's the kicker. turn the belt inside out so that the writing is on the inside and sits against everything. Thats what I did and I have used it once and it worked well, Lets hope it'll keep working.
May 20, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
My hoover mach 5 stopped during use and will now not turn on
If the machine overheats, a breaker trips. Most breakers reset themselves after they cool off. You may have a manual reset button to push on your model. The machine will overheat if the bag is too full, or if the exhaust port is clogged. The reset switch is usually on the back of the motor housing, near the footswitch.
Dec 22, 2008 | Hoover Commercial C1660-900 Bagless...
How to put on the flat belt on hoover mach 5
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=681386
Generic problem for all Vacuums
How to put on the
Posted by jamescook76 on Jun 18, 2008
How to put on the flat belt on Hoover mach 5
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Usually there are 2 to 4 screws on the bottom of the vacuum and then the top cover will come off in order to change the belt or the bottom plate will come off and then you can get @ the flat belt. It’s one or the other. A suggested flat belt change is recommended every 4 to 6 months for the best cleaning and to store the extra belts in a Ziploc bag in the refrigerator.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 18, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
I HAVE A BRAND NEW HOOVER MACH-3 CYCLONIC THAT CUTS OFF EVERY FEW MINUTES. IT IS DRIVING ME CRAZY! IT'S LIKE AFTER 5 MINUTES OF VACUUMING IT HAS TO SIT FOR A LEAST AN HOUR THEN YOU CAN VACUUM FOR ANOTHER...
If it were mine and it was brand new I would bring it back and exchange it. It sounds like the motor is over heating and shutting off automatically. Does not sound good. My advice return it.
Mar 16, 2008 | Vacuums
Hoover mach 5 only used 3 times
If the filters are ok, and there is no clog in the hose or dirt inlet down by the brushroll, then the motor protector is probably bad.
Mar 13, 2008 | Hoover Commercial C1660-900 Bagless...
Mach 5 hoover turns off
Just got a solution off another website. There is a pre motor filter about the dust collection container. I opened mine and it was very dirty. I washed the filter and you are supposed to let it dry out for 24 hours. Hopefully this will work. Another guy said it worked for him.
Dec 29, 2007 | Vacuums
Hoover U5194-900 Mach5 Multi-Chamber Cyclonic Vacuum Cleaner Bagless Vacuum Logo
488 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
