Question about Garmin nuvi 1300 Car GPS Receiver
No sound on Garmin Nuvi 1300 - Garmin nuvi 1300 Car GPS Receiver
    President:
  • 1,514 Answers
First press the speaker symbol and check that the volume is not down fully or that the mute box is not ticked. If it is press the mute box to untick it or increase the volume. Otherwise follow the instructions below.
1. Press Tools, then press Settings (or Locale on some models), then press Language. You will see a bar for Voice. Press Voice and select a different voice. If this doesn't solve the problem it's most likely because the voice file has become corrupted. To replace the corrupted file.
2. Download webupdater from http://www8.garmin.com/support/collection.jsp?product=999-99999-27 and connect your satnav to your computer. Install webupdater and your satnav will look for updates. After it's finished it will give you an option to download voices. Click the ones you want and press next. The voices selected will be downloaded to your satnav.
When you have removed the satnav from the computer you'll need to select a voice again as described in para 1 above.
Posted on Sep 28, 2010
  • 5 Answers
SOURCE: My Garmin nuvi 1300 brightness problems
I spoke to Garmin Support about this issue. There are 2 settings for contrast on the nuvi 1300. You need to set the contrast while it is plugged into the vehicle, and also while it is unplugged from the vehicle. The reason for the 2 settings is to save the charge of the battery while it is not plugged into the vehicle or power source.
Posted on Jan 14, 2010
SQUIRESXX
  • 486 Answers
SOURCE: Garmin Nuvi 1300 couldn't reach satellite!
THERE ARE A NUMBER OF SOFTWARE UPDATES IN THE LAST FEW MONTHS CAUSING PROBLEMS GO TO WWW.GARMIN.COM/SUPPORT
DOWN LOAD NEW SOFTWARE UPDATES
Posted on Dec 12, 2009
emissionwiz
  • 77544 Answers
SOURCE: register my garmin nuvi 1300
go to this link to register the GPS
https://my.garmin.com/mygarmin/registrationGettingStarted.htm
Posted on Jun 09, 2010
  • 6 Answers
SOURCE: i need to change the language on my my garmin nuvi
Garmin uses picture icons for most of the settings. When you forst turn the unit on you will see a magnafine glass map speaker and wrench. the wrench is tools press that. the next set of icons you will see another wrench that is settings press that. The next set of icons there will be a pair of lips that is language press that. The next screen is harder this is the language screen the upper left blue button is voice, the spoken directions, the upper right is text, the one you need to change, the lower left is keyboard. Select the text button, the languages are alphabetical so scroll up to american english, the screen will refresh then press ok.
The other solution is to do a hard reset. It sounds like you got this unit used or a floor model that someone changed the language on. It might be in your best intrest to reset to clear all saved info that others have input.
Posted on Jun 25, 2010
news775
  • 699 Answers
SOURCE: when I turn on my garmin nuvi 1300 nothing to see
Try doing a reset on device.
press and hold power button on (from off) and hold the screen in bottom right corner.
it is quite important where you touch screen (not right in at the very edge).
you may have to do this a couple of time for it to work.
Please dont forget to vote this answer was helpful
Many thanks
Posted on Feb 14, 2011
The garmin nuvi 1300 series comes on and then says loading maps and does it over and over and will not load maps
A Garmin Nuvi 1300 that freezes on 'loading maps,' or is acting erratically is symptomatic of having corrupt firmware.
To correct this, I recommend backing up your favorites, clearing all user data, and if it still is stuck, then updating your Nuvi firmware.
Follow these three steps to take to get your Garmin Nuvi 1300 running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_______________________________________
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
Garmin Nuvi 1300 Webupdate
May 21, 2010 | Garmin nuvi 1300 Car GPS Receiver
Tip
Download Garmin Nuvi 1300 Manual
Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245 , Nuvi 1250, Nuvi 1255, Nuvi 1260
Models: Nuvi 1300, Nuvi 1300, Nuvi 1310, Nuvi 1340, Nuvi 1350, Nuvi 1370, Nuvi 1390
Models: Nuvi 1410, Nuvi 1440, Nuvi 1450, Nuvi 1490
Have you lost your Owner's Manual for your Garmin Nuvi 1300 GPS?
Would you like a digital copy of the Garmin Nuvi 1300 Users Guide for easy searching of terms and quick reference?
The Nuvi 1300 manual is available free in pdf format, just follow the photo link below:
I hope that helps.
________________________________________________
on May 13, 2010 | GPS
Tip
Download Garmin Nuvi 1300 Quickstart Manual
Have you lost your Owner's Quickstart Manual for your Garmin Nuvi 1300 GPS?
Would you like a digital copy of the Garmin Nuvi 1300 Quickstart Users Guide for easy searching of terms and quick reference?
The Nuvi 1300 Quickstart manual is available free in pdf format, just follow the photo link below:
I hope that helps.
1300 nuvi screen comes up loading maps and stops
I hope that helps.
May 19, 2010 | Garmin nuvi 1300 Car GPS Receiver
Tip
Garmin Nuvi 1300 Favorites Backup and Restoration Procedure Models: Nuvi 1200,...
Would you like to back up a copy of your Garmin Nuvi 1300 Favorites and Waypoints?
Backup and Restoration Procedure for Favorites:
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After a hard reset or loss of data, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
I hope that helps.
on May 13, 2010 | Garmin nuvi 1300 Car GPS Receiver
Tip
Garmin Nuvi 1300 Webupdate Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
Does your Garmin Nuvi 1300 GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
Nuvi 1300 squeal
A Garmin Nuvi 1300 that won't start, freezes on 'loading maps,' or is acting erratically is symptomatic of having corrupt firmware.
I hope that helps.
Jan 06, 2010 | Garmin nuvi 1300 Car GPS Receiver
Tip
I hope that helps.
Tip
I hope that helps.
Garmin nuvi 1300 Car GPS Receiver Logo
2,142 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
