Question about Scunci 52067 Handheld Steam Vacuum
Scunci steam cleaner not spraying steam
I have the scunci hand held model (looks somewhat like a tea pot) it has been very hard working and loyal, however, suddenly it does not spray any steam. I checked all the nozzle vents, etc. & although it does heat up & the indicator lite works, nothing happens when i push the power button.
Thank you in advance for any suggestions,
Liz
  • 3 more comments
  • cilli Jun 09, 2008
    I have the same [problem - what do I do?
  • sladesmaid Jun 14, 2008
    Thanks for all your comments re:scuncii handheld steamer.
    I have cleaned the nozzle & hoses to no avail ! It still builds up pressure and the steam will come from the top if I unscrew it, but no steam will spray when I push the thumb button! SO frustrating because it gave NO warning, and I really did use it alot. I will try the vinegar trick & pray for steam !!
  • majdorsey Sep 03, 2008
    SCUNCI STEAM CLEANER HAS ONLY BEEN USED ONCE. IT HEATS UP BUT DOES NOT SPRAY ANY STEAM.
  • fcitymusic Sep 03, 2008
    My problem is the same of many. Calcium deposits after only one or two uses. I would like to take it apart and clean it but one of the bottom screws requires a special tool. Any ideas? I have tried CLR to no avail and am now trying Draino....there's got to be a way to clean this thing...any ideas?
    ---Zack fcitymusic@gmail.com
  • kathyh Hess Feb 19, 2009
    having the same problem here but i have hard water what can i use to clean this? hand up in air!!!
Unscrew the screw on the handle and remove handle. Remove rubber where top screws on. Remove two screws and the top and now unscrew the black pipe where the steam comes out. Now remove the button and see the small metal protrusion on the pot where the button was. Hit it with a hammer a few times softly to remove the scale buildup until the metal starts moving in and out again. I also sprayed it with a little silicone spray. Now put everything back together again. My steamer now works beautifully again!
Posted on Jan 11, 2010
  • Robert Bruce
    Robert Bruce May 23, 2012
    It works! Thanks...my only problem is that the button is now stuck in...I will redo...
  • Holly Jul 27, 2012
    THANK YOU!! I hadn't used my unit for maybe 4 years, and I got inspired today! After I dumped about 1/4 cup of dried deposits and rinsed the unit about a dozen times, I turned it on, only to have the button not depress. I removed the parts, put some WD40 on the button, lightly hammered it to loosen it, and put it all back together again. I also sprayed some WD40 on the lid treds and it's much easier to loosen and tighten. NOw it's all back in working order... only distilled water for me from now on. Thanks Vloedram!
I had the same problem with the 1600 Scunci Floor model...It seems that steamers are prong to calcium deposits. This is especially true if you have hard water. I tried everything....I even opened the unit up...I don't suggest you do that but you can fix the problem by buying a new hose...just google Scunci Accessories....I actually got my working but I don't trust my home made remedy....I'm just gonna buy a new hose....I learned also that you should put CLR and vinegar in the steamer before each use to avoid the calcium deposits.
Posted on Jun 12, 2008
  • alphonsium Jan 28, 2011
    clean parts and tank with full strength cleaner and boiling water. shake solution in tank with cover on tight. this will free mineral buildup, be careful not to get burned . spray inside and outside of button which is under trigger with WD40. should work fine. use only distilled water.
If you've used this product before, did you use regular tap water or distilled water? I've had my Scunci for years and have no problem with it.
Posted on Feb 22, 2010
I have the same proble it dode not heat up or spray what can I do
nonnav@aol.com
Posted on Jan 19, 2009
Use a very small flat head screwdriver and use any sort of a grinding tool to cut a small slot in the center of the blade. Works like magic and enabled me to filx my steamer
Posted on Nov 15, 2008
I had the same problem . I have some of the best warter there is. It is filtered and it has a magnatie on it. So my warter does not leave hard warter spots or anything like that much. So why does this steamer not work. I have a floor brand by shark and it works great. But Liked this one so I got it. And it will not work after one use. My husband works on all kinds of applainces. And for the life of him he says it should not be this way after one use. Thanks In Texas
Posted on Nov 03, 2008
I have a scunci ss 1000 hand held steamer cleaner. Its been used and given to me from a friend. The steam comes out the trouble is the steam is not hot, just luke warm. how can I fix it myself.
Try descaling it with CLR. Add CLR and water, turn it on but not fully to produce steam, just get it hot. Leave it for an hour. Empty that out and out some more in. Get this up to steam for 10 minutes, switch off, leave it for an hour and empty it. Fill and rinse out twice. Fill with water and see if it is fixed.
Nov 09, 2015 | Scunci SS1000 Handheld Steam Cleaner
Why would appliances trip breaker
Without seeing it it is impossible to be 100% sure but generally this will indicate a short in the motor. If it is within warranty I would return it to place of purchase for replacement. I work as a service tech for vacuumspot and if it were out of warranty I would probably replace it as steam cleaners are a pain to repair (generally)
May 22, 2012 | Scunci SS1000 Handheld Steam Cleaner
Need owner manual for Scunci 52033 canister wet/dry vac
Hi citykitttyka...
I could not find a user manual, but I found a webpage explaining how to use your Scunci...
Please take time to rate me
http://www.ehow.com/how_5601648_use-scunci-steam-cleaner.html
Aug 17, 2011 | Scunci 52033 Canister Wet/Dry Vacuum
I need replacement parts for my Scunci SS-1000 Steamer
hi i need this part for my scunci steamer model ss-1000 this is internal parts inf to dannacielcr@hotmail.com thanks
Jun 04, 2010 | Scunci SS1000 Handheld Steam Cleaner
Need a manual for the hand held Scunci steamer
Try this:
http://www.ehow.com/how_4811845_use-scunci-steamer.html
May 15, 2010 | Scunci 52000 Handheld Steam Vacuum
MY hoover steam vac hand held hose cleaner leaks profusely
try taking a sharp knife and shaving a little off the edge of the plastic, or a small file if you can get to it, see if it is getting binded. If its getting stuck internally, you will have to replace the switch instead of risking takin it apart.
Jul 09, 2009 | Hoover F5810 SteamVac Upright Vacuum
My scunci steam cleaner has a white build up and is clogged. How can i clean it?
I had not used my scunci for a few months and now it is completely clogged. I tried vinegar over night and removed a lot of sediment, but it is still not working. My last shot was going to be to use lime-away. Any suggestions. All parts look in mint condition, but it just doesn't work.
Sep 28, 2008 | Scunci 52067 Handheld Steam Vacuum
Euro-Pro Shark hand held steam cleaner model #sc618hd
Your heater in the cleaner is either plugged or has quit working, make sure you are getting a good ground for the cleaner. you may want to check the ground pin on the cord and make sure it is not loose or broken.
May 26, 2008 | Euro-Pro Shark SC-505 Handheld Steam...
Scunci 52067 Handheld Steam Vacuum Logo
5,284 people viewed this question
Top Scunci Vacuums Experts
ray gallant
Are you a Scunci Vacuum Expert? Answer questions, earn points and help others
