Question about Kenmore Elite 45986 Front Load Washer
F-11 code error.
I have the Kenmore HE Qiet Pak 4 front loading washer and nearly every time I do a load of laundry, I get this error message and then fight with the machine to start up again or give my clothes back. I've looked around and followed lots of tips form here. I found one solution that suggested running the test cycle, so I did that. But I only made it to test C:05, and then it just never moved on. The drum kept spinning. I eventually stopped it after 20 or so minutes and tried to do another load... So far it seems to be working, but the machine should have made it to C:08 before finishing. Does this mean there is another problem with my machine? Or does the C:05 test really take that long to complete? Should this also solve my F-11 problem?? Any help would be greatly appreciated!
  • 725 Answers
Sound like a control problem
Posted on May 27, 2008
F-24 error code so I ran a clean washer cycle, and the laundry room is now flooded.
what's f24 code? - Kenmore Elite HE3 Washing Machine ...
https://www.ifixit.com/Answers/View/85549/what's+f24+code
iFixitAug 21, 2015 - Aiman, The F24 error code indicates a water temperature sensor reading that is ... The Kenmore Elite HE3 is a washing machine by Kenmore.
F24 Error Code on My Kenmore Washer ' eHow
www.ehow.com > Home
F24 Error Code on My Kenmore Washer. Kenmore washing machines have several high-tech features, such as a stain treatment option, reduced energy and ...
Kenmore HE2 Plus Front Load Washer F24 error code ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
...error code F24 I have a Kenmore HE2T washer and I keep getting an F24 error on it.. I have no idea what is means can't find the manual help!!! The "F24" error ...
I have a Kenmore HE2T error code F24 - Fixya
www.fixya.com/support/t3608391-kenmore_he2t_error_code_f24
Dec 9, 2009 - Posted on Dec 09, 2009.
Dec 06, 2015 | Kenmore HE2 Plus Front Load Washer
Kenmore elite will not finish a wash. every load no matter the size has a UE code. Please advise.
the ue code indicates that the control detects an unbalanced load in the washer that cannot be redistributed. press the start/pause button and try to redistribute the load. here are some problems that can cause this error code
the washer is not level or not stable. make sure that the washer is leveled properly front to back and side to side. press down on opposing corners to make sure that all 4 feet are firmly on the floor. adjust the leveling legs if necessary.
WASHING TO SMALL A LOAD
laundry can sometimes gather to one side. redistributing the load manually can resolve this issue.
try running the washer without any items added and see if it will spin properly. if not, you could have a problem with the control board or the hall sensor on the motor that detects motor speed.
uE error code 79631512210 Kenmore Elite Washe
May 17, 2015 | Kenmore Washing Machines
My washer shows me the F 11 message and it won't start up right away I pushed the start botton then wait and it will start back up but it will spin then it will show me that F 11 message again. Also it...
The shaking probably shook a harness connection loose.
F11 Serial communication error
Communication between the Central Control Unit (CCU) and the
Motor Control Unit (MCU) cannot be sent correctly.
Possible causes/procedure:
1. Unplug washer or disconnect power.
2. Check wire harness connections to the MCU, the motor, and
Central Control Unit (CCU).
3. Check the drive system for any worn or failed components.
4. Plug in washer or reconnect power.
5. Verify CCU operation by running a Diagnostic test or any
cycle.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
8. Check that the serial harness at the MCU is not mounted
upside down. The wires should be to the left when facing the
MCU connectors. Your tech sheet is in the bottom behind the service panel.
How to get into the machine
Dec 28, 2010 | Kenmore Front Load Washer
Error "F6" on my Smartwash Quite Pak9
I believe the F6 code is a motor failure. I suggest you call a pro to come out and look at it.
Sep 22, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore smartwash quiet pak 9 is leaking
The lint is likely from the drum seal rubbing over time.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 07, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite quiet pak 4 ''suds'' error
I also gots suds error and then "F"?
my clothes were soaked....i can't get the machine to drain now????
Nov 17, 2008 | Kenmore Elite 45986 Front Load Washer
F22 code appears on Kenmore Elite Front Load washing-?
communication error between control board and panel. Make sure both are replaced together. common problem
May 27, 2008 | Kenmore Elite 45986 Front Load Washer
Duet washing machine
f-11 is a motor control unit error.
These codes and more details are printed on the service technician diagnostic manual that is affixed to the inside of the washer's front panel.
Unplug your washer, and unscrew the three 1/4" socket screws at the bottom of the washer. The manual should be taped to the back of the panel, and the code and some recommended procedures will be right inside.
May 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore elite front load washer
look for an error code on those washer it will be and f-02 something like that or HF FH it will have an f keep an eye out for that
Mar 19, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
205 people viewed this question
Sal De
fordexpert
Robert Rankin
