Question about Sanyo Vizon LCD-15A2 Television
Sanyo vizon tv black screen
Tv turns on but there is no picture the screen remains black after an initial white flash My SANYO VIZON turns on but i can only here sound, no picture only black screen. CAN THIS BE FIXED?
  • 4 more comments
  • LANDO210 May 29, 2008
    Sorry model# was wrong it's a sanyo vizon ht30744. Should repair cost still be the same.
  • Anonymous Mar 12, 2014
    como desbloquiar los botones
  • Anonymous Mar 15, 2014
    TV has no sound or picture. Screen is black. Power supply appears to be ok.
    What else can I do
  • Anonymous Mar 17, 2014
    I purchased an Element Electronic model number ELEFT326 in December of 2013. Shortly after I purchased it the screen would have little glitches where it would go black, but after turning it on and off, the screen would remain on. This happened only a few times so we didn't think much of it. It suddenly started going black constantly and now the picture won't come on at all. Is there anything I can do from my end to fix this or is it something inside the television that can't be fixed by a novice? Any help would be appreciated!
  • Anonymous Mar 20, 2014
    can I manually reset it?
  • Anonymous Mar 24, 2014
    Santos Vizon
    Filmmaker:
    Uploaded 5 video answers.
  • 150 Answers
Hiiiiiii here shivam
i want to tell you that that same problem is occuring my computer but now it is fixed
but your problem is of tv don't worry is this is help full to you--
this problem is common on this model. your vertical output circuit has gone bad. but i am sorry to say that a repair cost is to much for a tv this age. a cost would range 100-150. i say invest this into a newer tv. this model was good for 10-12 years and you have got better than that.
good luck :)
let me know if you need more info?
Posted on May 24, 2008
  • shivam raj
    shivam raj May 24, 2008
    or sir this can help you
    http://en.allexperts.com/q/TV-VCR-Stereo...
    i am rate full if this is helpfull to you
  • shivam raj
    shivam raj Jun 01, 2008
    the price depend upon function tell me the function of you tv
    but according to my opinion sell old and with that money buy another one
    because this type of prob hasn't any solution
  • 2,335 Answers
How old is your LCD?
It can be fix. if you are handy with tools like a soldering iron, multimeter and capacitance meter; is easy repairable.
Most failures like this one are located in the power supply section.
You should measure the 5 volts when the LCD is on, if you get less then 3.5 volts, you should inspect the capacitors that filter the 5 volts DC for bulging or leaky conditions.
Let me know if you need further assistance.
  • Jaime Hernandez May 29, 2008
    If the repair will cost you 1/3 of the price of the TV, is a good price.
    Genius:
  • 1,665 Answers
Have a look at link .Type in your model to see if a service manual is available.
https://www.manualsparadise.com/MainSearch.do?brand=312&model=15a&elementChanged=Find&registerButton.x=34&registerButton.y=4
  • Kleanthis Mavropoulos
    Kleanthis Mavropoulos May 24, 2008
    TROUBLESHOOTING
    General
    A general guide to troubleshooting a flat panel display system it is worth considering the system as separate elements, such as:
    􀂾 Controller (jumpers, PC settings)
    􀂾 Panel (controller, cabling, connection, PC settings)
    􀂾 Backlight (inverter, cabling, backlight tubes)
    􀂾 Cabling
    􀂾 Computer system (display settings, operating system)
    Through step by step cross checking with instruction manuals and a process of elimination to isolate the problem it is usually
    possible to clearly identify the problem area.
    No image:
    􀂾 If the panel backlight is not working it may still be possible to just see some image on the display.
    􀂾 A lack of image is most likely to be caused by incorrect connection, lack of power, failure to provide a signal or incorrect
    graphic card settings.
    Image position:
    􀂾 If it is impossible to position the image correctly, ie the image adjustment controls will not move the image far enough, then
    test using another graphics card. This situation can occur with a custom graphics card that is not close to standard timings
    or if something is in the graphics line that may be affecting the signal such as a signal splitter (please note that normally a
    signal splitter will not have any bad effect).
    Image appearance:
    􀂾 A faulty panel can have blank lines, failed sections, flickering or flashing display
    􀂾 Incorrect graphics card refresh rate, resolution or interlaced mode will probably cause the image to be the wrong size, to
    scroll, flicker badly or possibly even no image.
    􀂾 Incorrect jumper settings on the controller may cause everything from total failure to incorrect image. CAUTION: Do not
    set the panel power input incorrectly.
    􀂾 Sparkling on the display: faulty panel signal cable.
I have a Sanyo Vizon DP42647 that was given to me. Everything seems to work great except it looks like red Kool-Aid was poured on the screen. Can it be cleaned or just pitch it
I think it is more than a Kool-Aid stain. likely it was some kind of heat applied to the screen causing physical damage. How does it appear when the screen is white?
Aug 20, 2014 | Sanyo VIZON Multisystem 42" LCD TV 110-220...
When turned on, screen goes black, but power light stays green
It sounds that the main digital board to this TV is faulty. Contact any service technician.
Jun 26, 2013 | Sanyo LCD-42CA9S VIZON MULTISYSTEM 42" LCD...
On a Sanyo Vizon HD TV where is the headphone jack?
Panasonic handle Sanyo TV Support now, Here are their contact numbers: Repair:-0871 3321711
Product Help:-
0844 335 2230
Apr 04, 2013 | Sanyo VIZON Multisystem 42" LCD TV 110-220...
Sanyo vizon liquid spilled on back & will not turn on now
You can attempt to recover it by either filling up a tub of white rice and leaving it sit there for a few days to a week, or you can put it near a heater to try and evaporate any remaining liquid. These steps will only work if the spill is very recent. It is possible that an internal circuit has been shorted, or an internal fuse blown. If either of these have occurred you will need to have it serviced by a professional. Contact Sanyo to locate a nearby location.
Mar 06, 2011 | Sanyo Vizon LCD-15A2 Television
Dark cloud on screen of lcd tv sanyo vizon 42''
sanyo is a junk tv, and I will NEVER purchase another....less than 5 years old black clouds on the screen, repairs are cost more than the cost of a new tv.....
May 06, 2010 | Sanyo Vizon LCD-15A2 Television
27' vizon tv black screen
It seems to be a PSU (Power Supply Unit) problem. When you unplug it and replug, the screen comes on for a moment. That means that the capacitor does not hold charge for long. Open the back and look for bulged or burst capacitors on the module where the power cord meets inside. Replace the whole module if you can not replace the capacitor with exactly the same specs.
Nov 07, 2009 | Sanyo Vizon LCD-15A2 Television
My friend T.V. it blinks when you turn it on he has a sanyo vizon it's a L.C.D. flat screen
Probably overheated. Inadequate air circulation. Nothing you can do now. If it's less than 1 year old Sanyo might replace it w/ a refurb. I'd contact them. http://us.sanyo.com/
Oct 01, 2009 | Sanyo Vizon LCD-15A2 Television
Replace 12v ac adapter ( if you can find one ).
Nov 30, 2007 | Sanyo Vizon LCD-15A2 Television
Televison & Video Logo
658 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
