Question about HP Pavilion a1630n PC Desktop
SD Card is stuck in the memory stick slot - HP Pavilion a1630n PC Desktop
    Scholar:
  • 70 Answers
If your Memory Card reader is internal remove from the system and then remove the face plate for the Memory Card Reader. Then remove it. if it's external then do the same disassemble and then remove it from the card reader.
Posted on Oct 05, 2011
My memory card won't lock in place therefore I get a "no memory" card message.
Unfortunately it sounds like the locking clip inside the SD card slot is broken or some how stuck? If you can try to look inside the SD card slot in the camera with a flash light, there should be a small clip like plastic to the left sticking out. That is what locks the SD card in place. See if anything is stuck in between like debris, you might gently poke that clip and see if it is stuck? That is what locks the SD card in place, if it is broken or missing, that will require some work to replace the plastic lock.
May 25, 2014 | Canon PowerShot SX10 IS Digital Camera
How to remove/load sd card stuck in Huawai M860
The SD memory card slot is spring loaded, to insert the memory card insert the card into the SD memory slot with the SD card contacts going in first and gently push it in until it locks in place. NOTE if the SD card does not slide into the slot easily then the SD memory card has been inserted back to front, turn the SD card around and insert it again.
To remove an installed SD memory card, press the SD memory card and it will pop out slightly then you can then pull out the SD memory card.
Mar 12, 2013 | Cameras
HELP!
Paper clip preferable plastic I'll help the card out, or some fine pair of tweezers will work perfectly.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Dec 11, 2011 | Brother DCP 115C All-In-One InkJet Printer
I just cant put in the sd memory card into the slot...the slot is slightly bigger and u just cant feel the memory card clicking in...once it kinda fell into the slot and got stuck inside... does this mean...
I know that HP sucks but if you insert the card into the correct opening it will work. If you are incapable of doing so, have someone else do it for you.
Sep 01, 2017 | HP Pavilion dv5000t Notebook
Have an HP L7680 all-in-one Just received a Panasonic Limuix camera and cannot read the SDHC memory cards in the SD slot - Printer posts an error
No, it's not possible, it'll never read SDHC in the SD slot. SD slot will only read SD, Mini SD (with adaptor) and Micro SD (with Adaptor). If there's no SDHC card slot, then it doesn't support SDHC Card. The lists of supported memory card are listed below:
CompactFlash™ Type I and II,
Secure Digital/MultiMediaCard/Secure MultiMediaCard (SD),
xD-Picture Card,
Sony Memory Stick®,
MagicGate Memory Stick,
Memory Stick Duo,
Memory Stick Pro
I hope this clears your doubt.
Note: SDHC and SD are different Memory Card types.
Good luck.
Thanks for using FixYa.
Sep 21, 2010 | HP Officejet Pro L7680 All-In-One Printer
Sony memory stick is stuck in SD slot on my HP Pavilion dv7-1279
First, with the battery removed, a tweezer or thin paper clip.
Sep 22, 2009 | HP Pavilion dv7-1279wm Notebook
My Memory Stick does not register to my Macbook Pro. I have put it in the the SD slot countless times every way.
memory stick pro duo slot is different from SD slot. get a inexpensive card reader which supports memory pro duo cards.
Aug 07, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
The sd card is stuck in the slot and wont come out
You tried to put a Sony Memory Stick into an SD slot? It will probably need as much force to pull it out as it took to jam it in there!
I'd power off, and start with tweezers... if that doesn't work... i'd break out the needle-nose pliers. You may break the reader while trying this... but a card reader is all of $10-20... and you're kinda stuck anyway. ;o)
Apr 19, 2009 | Compaq Computers & Internet
Have a dell Inspiron 1525 notebook with memory card reader, compatible with Memory Stick Pro - but i cannot figure out how to insert the memory stick into the memory card reader - an SD card slots in...
the MS pro may need an adapter if it's the mini kind. then that will plug into that slot. it still won't fit the same way as the SD card, so insert it carefully. there should be an indented area for the MSP card to insert.
Aug 18, 2008 | Computers & Internet
Acer aspire 7004 flash card slot
Your computer doesn't support compact flash cards. Your SD slot is a 5-in-1 card reader, supporting Secure Digital (SD), MultiMediaCard (MMC), Memory Stick® (MS), Memory Stick PRO? (MS PRO), xD-Picture Card? (xD). The big slot is for PCMCIA devices.
Jul 12, 2007 | Acer Aspire 3000 Notebook
HP Pavilion a1630n PC Desktop Logo
152 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
