Question about Radio Shack Pro-2018 Scanner
My pro 2018 scanner wont pick anything up where i live could there be something wrong with the scanner or do i need a better antenna i live in holmes county ohio
    President:
  • 2,761 Answers
First try picking up the NOAA Weather broadcasts. They're transmitted on seven frequencies (162.400, 162.425, 162.450, 162.475, 162.500, 162.525, 162.550) and at least one should be active in your area. To check reception, just press the WX key on your scanner. If you can pick up one or more of the frequencies, you'll know that the scanner is functioning properly. If not, your scanner is likely in need of repairs - a questionable move due to its age.
If the scanner is functioning (receiving the weather band), try a quick RESET. use a paperclip or pen point to press the recessed RESET button on the back of the scanner.
Make sure that you have programmed local active frequencies into the scanner. For a comprehensive database, and a lot of other useful scanning information, visit:
www.RadioReference.com
After all of the above, if you are receiving weather but no local transmissions, I recommend that you try an external antenna.
If you need the manual for your scanner, you can download and print it, at no cost, here:
http://support.radioshack.com/support_electronics/doc69/69290.pdf
Bill B
Listening in since the 60's
Posted on Sep 28, 2010
Need an replacement antenna for my radio shack pro-508 scanner. Radio shack does not carry them anymore
Hi.
Check on eBay. You need a standard BNC connector antenna for this scanner. Radio Shack scanners are made by Uniden so a Uniden BNC antenna will fit your unit.
Here's a link for an antenna on eBay:
http://cgi.ebay.com/UNIDEN-DESKTOP-SCANNER-ANTENNA-BNC-SCAN-3-/220734104369?pt=LH_DefaultDomain_0&hash=item3364c72331
Feb 08, 2011 | Radio Shack Pro-2018 Scanner
My scanner (radioshack Pro 2018) doesn't receive signals from local poloce, ambulance and so on. What do I need to do?
First, try scanning the Weather band to see if you scanner is working properly. If you don't pick up anything, your scanner likely needs some professional help. If the Weather broadcasts come in, then you just don't have the correct frequencies programmed for your local services, and it's possible that your area is using a trunked system - which your scanner is not capable of receiving. For a comprehensive database of active frequencies and systems in your area, Visit:
The site will tell you if trunking systems are in use, and it will also provide a wealth of other useful scanning info.
Bill B
Aug 10, 2010 | Radio Shack Pro-2018 Scanner
Need an antennea that is for pro 508 scanner
The screw-in antenna for your scanner is Radio Shack Catalog number 10538353. You should be able to purchase one, or order one, from your local Radio Shack. Also check eBay - but make sure that it's the correct antenna for you scanner. Not all screw-in antennas have the same thread size. Check prices closely. Considering the age and limited capability of your scanner, you might be better off purchasing a new or used scanner rather than an antenna for the 508.
Bill B
Jun 05, 2010 | Radio Shack Pro-2018 Scanner
Need to find replacement padapter no. JoD-41U-02 for pro-2018. Can't locate one. Do you know where I can buy one.
The exact replacement power adapter for your scanner is out of production. Power requirement for the PRO-2018 is 12 volts with a minimum of 300 mA. Radio Shack has a universal power supply that will work, or you can pick one up on eBay for under $20, including shipment. You can also pick up a voltage-specific power adapter on eBay or elsewhere, but you may have to change the DC plug to match your scanner.
Bill B
May 21, 2010 | Radio Shack Pro-2018 Scanner
I have this scanner and it will scan but it wont pick nothin up
A couple of things could be involved in your problem. You need to be listening to the frequencies that are being used in your area, but most of them will not be transmitting all of the time. Something you can try is if you live maybe about 10-20 miles from an airport and your scanner picks up aircraft frequencies you can look up the airport and find the automated beacon frequency and tune that in. The automated beacon should be transmitting 24/7 the weather conditions of the airport.
Another thing to check is weather you have the correct antenna attached to your scanner and that it is connected properly, the circuits in your scanner may need that antenna to be connected for the circuit to function properly.
If you are using the scanner to listen to your local Fire Dispatch there can be days when there isn't anything happening.
Another problem could be that your local Dispatch has moved over to a new Digital System and your scanner isn't equipped to recieve that System.
Apr 16, 2010 | Uniden Hand Held Scanner - BC-246T 2-Way...
Antenna for radio shack pro 2018
Hello, Radio Shack would be the first place i'd try for a replacement. Mechanic
Oct 09, 2008 | Radio Shack Pro-2018 Scanner
Radio shack pro-95 scanner
Radio Shack scanners are not as sensitive as others, but the problem may be your location, especially if you're in a valley with mountains between you & the town that you're trying to receive, or if you have aluminum siding on your home, as metal blocks radio signals.
If either of these is the case, the best solution might be to erect a scanner antenna on your roof or the highest place possible (above metal siding) & connect its cable to your scanner.
Sep 21, 2008 | Radio Shack Pro-95 Handheld Scanner
Pro-97
I, too, recently experienced the same difficulty with my two year old Pro97 scanner and was able to correct the problem. I removed the back cover and followed the center wire from the antennae connection to the top board that has the green resistor. With a magnifying glass, I looked at the connection, and as it makes the bend onto the top board, the connection was broken. I carefully soldered the connection from the green resistor to the wire from the center antennae connection. Everything works like new now. If your scanner is still under warranty, you may want to have it replaced.
May 14, 2008 | Radio Shack Pro-97 Handheld Scanner
My pro-2018 won't scan anymore.
you may need to re program it and get a external antenna.i recommend that you get a scanner pc programming kit.
Jan 31, 2008 | Radio Shack Pro-2018 Scanner
Radio Shack Pro-2018 Scanner Logo
191 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
