Question about Hobart D300 Stand Mixer
We have a Hobart D-300 mixer, and want it to run in both directions. How can we modify the gearbox so that the mixer can be rotated in the opposite direction to the normal direction without damaging the brass gear? BTW We are using the mixer for a laboratory experiment.
  • 2 more comments
  • gary_sroka Sep 29, 2010
    I need this mixer to run in both directions for my experiment to work. It will operate under medium loading. I understand that there will be an axial thrust on the first stage of the gearbox. Can I just install a thrust bearing on top to keep the shaft in place? Or is there something else that I am missing? I need to operate the mixer at low speed only, and if it only lasts for one half of its expected life, I would be satisfied.
    I know how to reverse the electrical to run the motor in reverse. I am concerned with damaging the gearbox since the manual specifies that the mixer must be run in the proper direction. Therefore, I need to know why the gearbox will be damaged if inreverse the direction, and how can I modify the gearbox so that the damage will not occur
  • gary_sroka Sep 30, 2010
    Again, the mixer is connected to a 220v supply whereby the rotation of the motor can be easily reversed. The problem is that when the mixer is reversed the axial thrust on the brass gear that meshes with the worm gear is up instead of down. Under load, the shaft and/or brass gear will move upward damaging the brass gear. I am working on solving this problem, but need assurance that there is not something else that will present a problem
    Please read my. Omments before responding. This is not a question a out how to make the motor run in the reverse direction. I need to know why the gearbox itself will be damaged when run in the reverse direction. Is it only the fact that the axial force on the shaft that holds the brass gear will be reversed. Or is there something else that I am overlooking. Is there a chance that the worm gear that meshes with the brass gear cannot carry the load when the motor is run in the opposite direction?
  • 10,319 Answers
The gearing is degreed so if it ran in a reversed mode the gears will bind in a small amount of time. That could lead into a expensive repair. Best to leave it run as it was designed to be ran
Posted on Oct 01, 2010
  • 3,153 Answers
Whilst devices designed to run in one direction are often done that way for a reason you may be able to fit a phase reversal switch
This takes the positive and negative and by use of a switch swaps them over
http://www.kpsec.freeuk.com/components/switch.htm
Use example number 6 for the concept. Be aware that you are playing with potentially lethal voltage so take the required care !
Also test with only short bursts before running for long perids to make sure the mixer does not have any ANTI REVERSE system installed (not likely but possible)
Also keep the reverse runnin times down to a minimum and monitor motor heat etc.
You can also do this with a suitable contactor for industrail voltages and maybe add "de-bounce" components to ai switching. avoid rapid switching without de-bounce
Bob
Posted on Sep 30, 2010
  • Project NOMAD
    Project NOMAD Oct 01, 2010
    I only just saw you comment as the system on here is pretty pooched.
    Some gearboxes do indeed have a "floating gear" this may disengage the drive when forced into reverse.
    As far as actually running in reverse then as I did state that could only be checked by trial. Many mixers even of the same model tend to have differences during the manufacturing life of the product so there is no simple YES or NO.
    The fact that the manufacturer suggests against it is your first clue. as an engineer I would have to physically see the gearing layout for myself to be sure. The limitations imposed on this website preclude that possibility.
    Even now I cannot see the comment as the moment I hit the add comment button it wiped out your comment.
    I answered based upon your original question so I am sorry that you did not consider it any good for your needs even though it did and have gone above and beyond the query.
    If you really want a 3 or 4 tumbs up answer then you should be taking it to an engineer or engineering department of a suitable college for them to view and make a final yes no.
    Genius:
  • 1,340 Answers
You do not really need to mess with the gearbox.Do you have it apart?All it should require is 2 wires,the same thickness as what is hooked up from motor to switch or larger,and a 3 position switch(1 off position and 2 on positions).If you are in USA you can call me at 727-584-2554 anytime after 10AM until about midnight.It would be much easier to describe and explain and exchange information.Greg
Posted on Sep 29, 2010
  • 3,083 Answers
I couldn't find any report of anyone having done this, but I know a way that would work, possibly, but I'm not sure what would be required for the modification. A motor has to run the gear assembly, so the easiest way to modify the gearbox to run in reverse would be to make the motor that runs it switched polarity to run it backwards, which, in turn, should run the gearbox in reverse, depending on the ability of the gear teeth to do that without damage. Otherwise, you will have to have essentially two separate gearboxes to engage, but I guess since it's a lab, you could do that. Seems like the logical solution, although might be quite a project.
Anyway, those are my thoughts, however, not having the machine in front of me, I'm just taking the obvious guesses.
  • 11,896 Answers
Switch the wiring to the motor. If wires are reversed, then the motor should turn the opposite direction. If the gear doesn't allow it, then you will want a flat gear instead of beveled ones.
  • Nate Stansfield
    Nate Stansfield Sep 29, 2010
    You will have to flip your hear upside down so it turns the other way. You can't have go both ways, just one way or the other way.
  • 11,800 Answers
You can't modify the gearing , there is no space in the casing for that. The only thing you can try is to reverse the engine - you will need to modify the wiring in the engine, preferably by installing a manual switch that will select the turning direction.
  • Azrael SRL Sep 29, 2010
    The worm screw has only one thrust bearing - if you put the engine in reverse it will wear it a lot quicker. Since this isn't a problem for you - you will use it only at low speed and you accept the fact that it will be gome faster - then there is nothing stopping you to make the required modification. If you really want to be sure it will work until your experiment is finished then just weld/glue to the case a pointy support on which the shaft would **** if the bearing is worn out.
    President:
  • 2,777 Answers
This mixer's gearbox is definitely not made to operate that way, and it is inadvisable for you to try to do so. Noone will be able to tell you that information, as I can't imagine too many people in the world have ever tried to modify the gearbox in this method.
Thanks
Tim
Posted on Sep 28, 2010
How to pull auger drive shaft for Hobart 4346 mixer-grinder?
The oil seal is the resistance you feel. take a soft mallet or hammer with a soft drift and gently but firmly tap the stub shaft and it will drive out the oil seal in the hopper direction.The lower skirt of the tapered bearing is what contacts the seal so go slow.
Worked for me.
Jan 23, 2013 | Hobart 4346 Meat Grinder Mixer Chopper...
How do i put back togeather Hobart 300-d mixer
http://www.hobartservice.com/Parts/
Go to this page and click on Hobart Smartparts System. Select Food Machines, Floor Mixers, D300 and you will eventually find parts breakdowns.
Feb 25, 2010 | Hobart D300 Stand Mixer
I need diagram of gearbox for Hobart d330 mixer
Parts manuals are available for viewing and free download at www.hobartservice.com
Dec 23, 2009 | Hobart D300 Stand Mixer
The ball turns in opposite direction.
You have a 3 phase unit, it can run opposite direction if the main feed wires are not correct for the motor wiring. If you simply swap any two of the main electrical feed wires it will run in the opposite direction. This should correct your problem now. Enjoy.
Dec 29, 2008 | Hobart D300-6036 Mixer
D 300 hobart mixer
All that I could find for you is the manual
seems their website is not up and running at the momment sorry I Could be of any more assitance to you nice mixer by the way.
Aug 02, 2008 | Hobart D300 Stand Mixer
Hobart A-200 Motor Direction
No, do not swap hot and N.
First, verify rotation. As the attachment shaft rotates, it should push the engagement pin into the keeper slot. Looking down on top of the mixer, the planetary should rotate clockwise.
If the unit runs backwards, does it start slow? Can you get it to run either way by giving it a push start before turning on the power? If so, your start switch is not working properly. (Which is my guess) Check your capacitor.
There is mechanical and electronic start switches. (Metal arms and a contact or a little gold rectangular metal can.)
Check it out and let me know what you find -- Mike
May 19, 2008 | Hobart A200 Stand Mixer
Hobart d-300 mixer
To Whom it May Concer: At the school I work we have a Hobart D-300 Mixer. When we mix bread dough it pulls alot of current and trips the breaker. The max current draw on the name plate is 10.1 amps. I have seen the current go over 30 amps during the mixing process. Under no load the mixer pulls 7.8 amps. I dont have any information about this machine on paper and I can only go so far with troubleshooting.
My questions to you are: Is it normal for the mixer to draw 7.8 amps under no load? And is their a manual online I can look at so I can check the oil levels and make sure I do not have a low oil/needs greasing condition.
Thanks for your help and time,
Kenneth Clayton
Spartanburg Schools Dist#2
Apr 16, 2008 | Hobart D300 Stand Mixer
Hobart d300
http://www.food-equipment.com/parts_Hobart_mixers.htm About halfway down. Hope this helps :)
Aug 01, 2007 | Hobart D300 Stand Mixer
Hobart D300 Stand Mixer Logo
83 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
