Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
It throws a code oL it means over load and there's nothing it it but water so how can it be reset please
  • 20 Answers
Tilt the unit back & shine a flash light through the clear inner basket & see if there is any clothing stuck in between the inner basket & outer basket. Open the lid & lift up on the inner basket It should move up & down.
Posted on Sep 29, 2010
When machine goes into final spin cycle it gives me a OL code
OL means the washer is overloaded or there is excessive drive load. Go to the link for a full explanation of the OL code and its repair. What might be causing the OL error code on my Whirlpool Cabrio washer...
Oct 12, 2016 | Whirlpool Washing Machines
Getting oL code even after diagnostic check
OL, usually means Over Loaded. It is an error code thrown up by the on board computericon1.png.. generally when TOO much wet weight is in the bowl.
This condition is could be caused by faulty solenoid or solenoids at the water inlet valve. Unplug the machine, turn off the water, and remove the supply hoses. Check the solenoids at the water inlet valve. They can be tested using a multimeter or ohmmeter and checking for continuity. A lack of continuity will indicate a faulty solenoid and the inlet valve assy will need to be replaced.
Try unplugging for 12 hrs before reconnecting
If the problem continues then the controller board is damaged and will need to be replaced.
Jan 13, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
OL error code
Hi jbrundage1. I believe you have a UL error code on the washer. It means that the sensors in the washer are sensing the unit is unbalanced. When the washer is empty, set it to a spin or rinse and spin setting. Run the washer through the cycle empty, as it will help to remove any excess water in the tub. Also, make sure the washer is level, as it is balanced on springs, and that could be throwing the sensors off. I hope these suggestions prove helpful. Sincerely, Melanie, Maytag Social Media Representative.
Jun 03, 2012 | Maytag Bravos MTW6600T Top Load Washer
The oL warning comes on, just after the machine fills with water then it clicks through the cycles the water drains and the oL signal comes on. This even happenens when the clean cycle is operating.
oL Overloaded.
"oL" flashes when you got too dang many clothes in there. 18 pounds dry weight per load is what I go by. If the load is fine you could have an item of clothing in between tubs not allowing basket to engage.
Service Manual and codes HERE
Jun 20, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Our Neptune Washer won't start up. It shows a Code (ol). What does this mean? We;ve tried unplugging & and Re-loading it. Still OL code.
From the FAV6800A/FAV9800A Service Manual page 14 that error code = oL Machine Paused-Load Wedging
Google this "16022808 Revision 0 December 2003" to find the Service Manual if you are going to DIY the fix.
Mar 26, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Code ol
Hi
Error OL means overload. oL flashes when the machine/motor control detects a load size that exceeds the washer's capacity. To clear the error open the door lid and restart the cycle by removing excess laundry. If error doesn't clears then unplug the washer for 5-10 minutes and check. Hope this helps... Please post back if you need more information.
Daniel
Nov 16, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Screen says oL. Kenmore oasis elite he 110.2708,2709
OL, usually means Over Loaded. It is an error code thrown up by the on board computer.. generally when TOO much wet weight is in the bowl.
Jan 29, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Washer will not drain nor spin. Did have a OL IN THE INDICATION WINDOW WHEN PROBLEM FIRST OCCURRED
The OL means that the load was overloaded and shut itself off due to weight.
Dec 25, 2007 | Washing Machines
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
230 people viewed this question
Dan Webster
Dan Webster
Sal De
