Question about Panasonic PT-LB10E Multimedia Projector
Cannot start after new Lamp changed - Panasonic PT-LB10E Multimedia Projector
  • 442 Answers
Press the MENU button to display the "MAIN MENU", and then select "OPTION".
Press the ENTER button to display the "OPTION" menu, and then select "LAMP RUNTIME".
Press and hold the ENTER button for approximately 3 seconds.
The "LAMP RUNTIME" will change to "TIME RESET [POWER OFF]".
Turn off the power and disconnect the power cord.
This will reset the cumulative usage time for the lamp unit to "0".
Posted on Feb 28, 2011
Have a Samsung HLP6163wx problem
Hey friend:
most probably' 1) either your lamp was NOT installed correctly, or
2) lamp is bad - (it happened to me once, so no sweat!) - in this case you need to return the lamp in exchange for a new one.
Please watch any of the 'how to change the lamp on a dlp tv' video demo available on YouTube. Its not difficult. I already changed mine 3 or 4 times. Thanks
Jun 12, 2014 | Samsung HLN617W 61" Rear Projection HDTV
Thomson tv projector 61DSZ644 schematic diagram power supply board
Thompson 61DSZ644...Hello,I have a big problem with this tv.When i start it,the sound is good,but the image is very ,very dark.I buy a new lamp,i change it,but i must change the two wires from the lamp because the new lamp have it change.It came from china and is the same lamp,with the same specifications,just the polarity wires is different.so i change it and when i start the tv,i can see the image better but not normaly,the image is like in the white fog,even if the lamp is new...and after 20 seconds,the ventilator from lamp is stop and TV enter in stand by.Can anyone help me about this problem?
Mar 21, 2013 | Thomson 61DSZ644 Rear Projection Lamp...
JUST PURCHASED A NEW LAMP HOW DO I CHANGE IT
Lamp are pretty easy to change. Your lamp is mounted in the front of the TV.
On the back side of the T by the screen you will have 2 big plastic screws. You need to unscrew them. You might need to use a quarter to get them started.
Once the screws are loose then you need to go to the front of the TV and pop out the bottom front panel. This is where the power light is. Don't be afraid to apply pressure when trying to pop it out.
Once the panel is off you will see a door with another plastic screw.
Open the door and you will see the lamp. The lamp will either be screwed in or held in by a latch.
Remove the lamp and insatlee the new lamp.
Reassemble everything and turn the TV on
Go into the user menu and reset your lamp timer and you are done.
Good luck to you.
Mar 20, 2013 | Sony Lamp/bulb For Kf-50we620, W/housing,...
Flashes change lamp after a couple of hours run
Reset the lamp timer.
1,Connect the power cord.
2,While simultaneously holding down "menu","enter" and "down" on the projector, press "standby/On" on the projector and keep all four buttons pressed down until the lamp indicator starts blinking green.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Oct 02, 2009 | Sharp ANXR1LP Projector Lamp for XR1X,XR1
Can't start infocus sp7200 after changing lamp.
The end of lamp timer has reached it's limit and won't let the new lamp strike. What you need to do is Reset the end of life timer. To do this, with the projector switched off press and hold both the up and down Brightness buttons on the projector. while holding them in turn on the projector. Continue holding the buttons in for 10 to 15 seconds This will reset the end of life timer in the projector.
Cheers
Sep 25, 2009 | InFocus ScreenPlay 7200 Multimedia...
Optoma EP755 new lamp when power standby button
you need to reset the lamp timer, usually done by holding some buttons while turning on
Mar 10, 2009 | Optoma EP750 Multimedia Projector
HOW TO RESET TOSHIBA TDP-S8 LAMP
after installing the new lamp, hold the volume top & bottom key simulteniously, when green light indicate at panel start the projector & go to service there you may found reset lamp ? press yes the lamp will reset.
Feb 01, 2009 | Toshiba TDP-S8 Multimedia Projector
Panasonic PT-AE900U Projector Lamp stops working (intermittent)
since it has worked 1200 hours or even more since u have been resetting the counter! just change the lamp, resetting the counter does not make the lamp work or not work , it is only a reminder for the user to change the bulb when it should be & that u have some balance hours left to procure a new lamp!
if the brightness is adequate, then it is a ballast problem & not lamp problem!
buy a new lamp as u will anyway need to , fit it & it may solve ur problems permanently!
Jan 27, 2009 | Panasonic PT-AE900U Multimedia Projector
I have a Samsung 61 inch DLP tv. Was very happy with it for the past 3 years. Lamp went out in Feb. Got a new one and replaced. A few weeks ago, it started making a screeching noise. Fans were ok,...
It is b.s. but it's not only samsung that have poor reliability. At least they have some customer service. Some new brands are a nightmare. I would suggest changing the ballast first, and if that doesn't do it, you're probably looking at a dmd board which is very expensive. Only other thing I can say is to try removing and reseating the lamp switch again. Also listen for the color wheel to start up a few seconds after you push power on. Color wheel is started by dmd board, lamp is driven by ballast.
Jun 12, 2008 | Samsung Televison & Video
Hd50lpw175x7
Ballast Verification Process
1. Short out door switch (SP001)
2. Apply AC power and wait till DM module boots
3. Press power switch and observe spark gap on ballast
4. If spark gap arcs, suspect Lamp. If color wheel starts but ballast won’t strike
lamp, go to next step.
5. Measure BP252 on AC IN CBA for +300Vdc. If missing check door switch, cable
from AC IN CBA to switch and AC IN PCB. If correct go to next step.
6. Monitor pin 2 of BT251 for Ballast ON command from Light Engine. If present
suspect Ballast. If missing suspect Light Engine. Pin 5 of BT251 starts at 3.3V
after power switch is pressed and drops to .18V when the Light Engine sends the
start command. No change on pin 5 indicates Light Engine is suspect, change
on pin 5 with no ballast start, ballast is suspect.
Note: Lamp may arc but not start. Pin 5 of BT251 is "LAMP LIT" and goes to 1.48V
when lamp is lit. If ballast strikes lamp but lamp won’t stay lit, suspect Lamp.
Jun 09, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
Panasonic PT-LB10E Multimedia Projector Logo
117 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
