Question about Toro Garden
How do you change the electric clutch on a toro proline 118 lawn mower?
4 Suggested Answers
  • 1129 Answers
SOURCE: Toro lawn mower. Have trouble starting(starts and
Remove the float bowl located under the carburetor it is a 1/2 bolt some gas will poor out so put a rag under the carb to soak up the gas, you actually may want to use a small container to collect the gas or make sure the gas tank is empty, remove the float bowl after removing the bolt by grasping it and turning, the bowl will most likely have debree and water in it clean with a rag and solvent and reinstall, becareful of the ruuber ring gasket when reinstalling the float bowl, one some movers there is no float bowl if you have this type of engine the tank and carb must be removed disassembled and clean out. Do not store mowers uncovered they must be covered when not in use, water gets into the fuel system and causes this problem.
Posted on Jul 14, 2009
harlan301
  • 205 Answers
SOURCE: Toro Proline 400 blades fall out of engage
if your unit desengages have the clutch gap checked. also you should check for shorts in your safty wiring. the other would be a bad switch. finely your under warranty this my be warranted.take it to a toro dealer or call one to make sure
Posted on Oct 13, 2009
RonInFla
  • 86 Answers
SOURCE: Toro Lawn Mower 20017 serial # 250000001 shaked and smoked while
drain the oil...the gas seeped into the cylinder and into the crankcase...fresh oil, a clean plug, should do the trick...
Posted on May 02, 2010
How do I remove electric pto clutch from my 1998 toro walk behind mower
take the bolt off that holds it on. if it doesn't slide off, then it's rusted on. then it's elbow grease time.
Jul 22, 2015 | Toro Garden
Toro proline hydro 15 horsepower with 44 inch
turn on the key, if the hour meter has a push button on it push and hold for 10 seconds
Sep 25, 2014 | Garden
How to repair a clutch cable on a toro recycler mower
Did the cable break? Or did it just stop working? In general you have to figure if it came off, break or did the adjustment slip. Readjust if necessary or replace the hole cable or re install it correctly. Simple Question, so many answers. And if all else fails, take it to a lawn mower repair shop.
Aug 21, 2014 | Toro Lawn Mower With Toro Power Tools
Electric clutch will not engage
clutch burned out if it is push mower if pto clutch check fuse and relay also could be burned out clutch or safty switch is bad
Aug 19, 2014 | Toro Garden
How to change the belts on toro timemaster
Type toro.com and the model of your mower they have schematics that will help you.
Jun 17, 2014 | Toro TimeMaster 30" Self-Propelled Lawn...
Proline toro commercial 32 inch won't run
try starting fluid that will see if its a fuel problem then check for spark
Apr 19, 2012 | Toro Garden
Toro 52 inch walk behind blades won't engage
if it has a electric clutch check for power to the clutch if no check the safety switches
Apr 10, 2012 | Toro 52" Cut Wide Area Walk Behind Lawn...
I have a 05 Toro 44in ZTR with a 19HP Kawasaki engine with under 300 hours the main 30amp fuse keeps blowing when I turn on the ignition switch on. I noticed when I disconect the PTO switch the fuse dousnt...
sounds like your electric clutch is prob bad check to make sure wires are not bare touching something, the clutches do go bad eventually like any other electrical part, disc the pigtail and try fuse, if it blows then I would consider a clutch
Jul 27, 2011 | Toro Zero Turn Rider 74833 Lawn Mower...
Sep 07, 2009 | Toro Co M/R Blwr/Trmmr Rear Bag Kit
Garden Logo
315 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
