Question about Toys
My tracks on my pc120 komatsu excavator will not tighten
3 Suggested Answers
  • 7 Answers
SOURCE: Excavator track needs to be put back on
after the idler is pushed all the way back into the frame.try to put some wood blocks under the track to remove all the slack.use the bucket to push as much of the bottom section under the bottom rollers.use a heavy chain and pull up and over the top of the roller.when you get close you can use the drive to walk it the rest of the way.if it still doesnt go you may have to break the track at the master pin. this is usually marked with a small hole drilled in the end of the pin.heat and beat the pin out,break the track.pull track over top rollers and make ends meet on top of the srocket.use a chainfall to pull two halfs together and line them up.drive pin back in and your all set.
Posted on Jul 02, 2009
Here is a solution for getting a track hoe track back on. 1)You can use the bucket to lift the track over the middle wheels (use chains with hooks). 2)Next, you need to use the bucket (push down on the ground) like a crutch and walk the tracks in one direction. Push the bucket up slightly until you start to get friction with the ground. The ground will cause the track that is off to begin to spin. 3)Moving in the direction will push the track towards the teeth. The teeth will begin to catch. 4)If you run out of room, walk the track hoe in the opposite direction, make sure you bucket down on the ground when going in the opposite direction to keep the position off the off track from sliding. 5)Repeat the process until the teeth finally catch. If you have questions call or email us
81inertlandfill@gmail.com
81 Inert Landfill in Loganville, GA 770-466-3676
Sent from my iPhone
Posted on Jan 05, 2010
PC 300 LC-3 serial #13848 what year would that be
Hi Gervin:
Your question appeared in the Washing Machines sections.
A Komatsu log loader would make one wild clothes washer, although somewhat overpowered.
- My excavators have the year stamped in the I.D. plate next to the serial number.
- If you can't find it I would suggest that you contact your nearest Komatsu dealer and ask them.
Cheers.
May 15, 2016 | Washing Machines
Need repair manual for Komatsu CK30-1 Compact Track Loader
Download Komatsu CK30-1 Compact Track Loader Workshop Service Repair Manual Download A30001 and up
https://sellfy.com/p/gq3Q
Nov 23, 2015 | Cars & Trucks
Komatsu excavator
Could be a bad starter motor the brushes get worn out inside the starter motor try tapping on the starter with a hammer not to hard if it starts after you tap on the starter toward the back were the brushes are then you have a bad starter or you could have a bad starter solonoid hope this helps
Jan 29, 2014 | Toys
Replacement tracks needed for my 1;32 scale pc450lc !
Try reconnecting the tracks togeather it may not be easy but my Komatsu toy model excavator has the same problem one of the tracks got jammed while i was playing with it so I'm trying to put them back togeather i also have the PC 450 LC model.. I managed to reconnect some of the tracks togeather but its not easy and be careful not to loose and parts
Sep 06, 2011 | Joal 1/32 Komatsu PC 450 LC-6 Excavator
Can any body tell me how to refit the rubber on komatsu 36 digger
There is going to be a track adjuster-sort of looks like a nut with a grese zerk in the middle of it. You back this nut off to let grease escape from the adjuster, and using the bucket on the machine try to force the idler back into the trackframe. This will give you the clearance you need to reinstall the track ( with the help of a bar). Once the track is back in position, tighten the nut you loosened, then pump the zerk back up with grease until you reach the desired tension. The location of that nut and zerk is listed in your owners manual under track maintenance. Hope this helps. Marvin
Jan 19, 2010 | Garden
Control levers some wilnot move komatsu pc50uu-1excavator
pressure reliefe valve is malfunctioning as this can be one to several you need special hydraulic meters to know (best bet take it to the dealer) I know that stinks but as they become more complicated so does the repair process
If I helped at all please give me a response negative or positive ( i can handle it ,thanks )
Dec 05, 2009 | Garden
Possible problem of slow movement of Hydraulic cylinder and Travel of Komatsu excavator
hi, have u checked ur fluid and filter, if so u need to check the pressure.
u can buy a normal guage and and get a bit of pipe made up to suit ur job.
you might be able to get away by increasing the spool valve. but if ran low on hydraulic then it is a new pump.
Aug 29, 2009 | Norscot Group/Cat Norscot Group 1/87 Ho...
Toys Logo
133 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
