Question about Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum
Water tank valve is leaking out of the bottom of the tank. The water leaks on the floor.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 100 Answers
It could be a cheap fix. There should be a rubber o ring that's worn or ate away by chemicals.
I'm hoping the tank isn't cracked.
Remove o ring. Contact repair place. O ring shouldn't be more than 5.00.
Posted on Sep 28, 2010
How do I cycle the valves on the bottom with the eraser end of a pencil on my hoover dual vac shampooer
The center part of the valve (stem) pushes up (spring loaded) to release liquid. If it leaks it can (and should) be replaced. Also, check the black valve seal (conical shaped ring around the outside) for cracks or splits as this can contribute to leaks. The entire valve assembly (similar to photo) should be replaced to solve both issues.
Oct 09, 2014 | Hoover SteamVac F5914-900 SpinScrub...
Hoover f7458-900 leaking when placing tank on
Hello! Test the clean water tank to see if it is leaking. Fill the clean water tank with water on both sides. Hold the tank up and observe if water leaks from the valves underneath the tank. If either of the valves are leaking the clean water tank will need to be replaced. To order a replacement tank follow this link > Search Results. If the tank is not leaking, but the cleaner leaks when the tank is placed on it, this may indicate an internal issue with your pump. We would recommend taking the cleaner to a Hoover authorized service center. Follow the link to locate the nearest service center to you. > Service Center Locator Hope this helps!
Jul 26, 2014 | Hoover F7458900 Max Extract All Terrain...
I have a bissell steam and sweep. when I am finished using it water still leaks from the bottom leaving water?
  • Drain the tank after each use.
  • It either has no shut off valve or a broken one when not in use.
  • If its new return it and see if new one leaks or not.
Nov 13, 2013 | Bissell Steam and Sweep Hard Surface...
My Bissell proheat2x leaks water from bottom of machine, if you have the water tank full and cleaner and leave it sit it drains out onto the floor, it leaks when you are using it to, is this a seal or...
Nope, not a seal problem, just natural good old fashioned natural gravity. I know it doesn\'t take long for it to start leaking after use but Bissell covers this in the manual. Thoroughly clean the unit, run clean rinse water through every cycle and empty all tanks and cavities after use. Do not leave water in any of the tanks when not in use. What doesn\'t leak on your floor (which doesn\'t take long) could cause permanent blockages in the lines. It\'s a pain, I know, but I use the garage or back deck to park and prep mine after use.
Aug 15, 2013 | Vacuums
Hoover steamvac
Let me start out with an apology. I did not ask my question very well - and you did not answer it as I needed.
If you wish, we MAY be able to communicate in your native language. We can do most indian languages, Turkish, Ukranian and some Russian - as well as Spanish. If any of those are easier for you - please feel free to use any of them.
The Machine storage tanks are 2 - one clean water, one dirty water.
I understand that, when OFF, no leaks happen.
I understand that when on a leak comes from "the side". Also, water comes from the bottom.
So, water comes out near the bottom brushes (even without trigger). Then, with trigger, MUCH water comes out near bottom brushes. Am I correct so far?
Water out the side concerns me. I am guessing that the bottom of the clean storage tank may have a small leak.
I am also guessing that the trigger valve (located in the small opening behind the black rubber seal that the clean water tank rests on) is not closing all of the way - or is broken (cracked).
Can you please remove the clean water tank and inspect the trigger valve with a torch (flash light). Can you see it open/close as you operate the trigger? Is it broken, cracked, or dirty?
If yes then it must be replaced. If no, the the storage tank is bad and must be repaired.
You inspect all of these things and you should be able to determine the failure. THEN, I an help you repair the failed item.
-Jim (Raleigh, NC - USA)
Nov 23, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Leaking tank
(1) Does water or chemical leak from the tank when filled, but before it is installed? If not, then the tank is OK.
(2) If the tank is not properly aligned to the lower handle when assembled and latched, the black rubber seals on the handle will not seal to the tank. You may wish to look at this. Also, make sure both round black rubber seals are present on the flat mount where the tank valves will sit.
Oct 05, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover Steam Vac V2 Deep Cleaner leaking clean water
Fill the tank and determine if the plastic is leaking, or if the valves are leaking. if the tank is cracked, it would need replaced. There is an improved design now available.
You may cycle the valves on the bottom with the eraser end of a pencil.
Sep 24, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Steamvac drips when tilt to pull back
May have a problem with the seal at the bottom of the tank, the valve and seal sometimes go back and need to be replaced(#43513026).
Feb 22, 2008 | Hoover F7431-900 SteamVac Vacuum
Spotbot is leaking...
Mine constantly leaked as well but I found that if I remove the container will the solution in it after every use it doesn't leak anymore. I store my container (upright - nozzle face up) under the sink with my other cleaning products and when I need to use the machine I pull it back out, pop it in and clean.
HTH
Dec 28, 2007 | Bissell SpotBot Robotic Wet/Dry Vacuum
Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum Logo
192 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
