Question about 1995-1997 Chevy Tahoe Ignition Starter Alarm Switch
Turn the key and the battery drains down to not enough to kick over motor, motor barely turns. Does it especially when hot. Starts OK in the morning, but still sluggish to start. After short trip, difficult to start, sometimes doesn't start. Battery is 500CCA, checked OK. Starter checked ok. Alternator is new. What else should I check?
    President:
  • 1,450 Answers
Sounds like your starter is dragging when hot. check cables for corrosion. have you had starter draw done with it on car and ehgine hot?
Posted on Sep 28, 2010
Pullcord starts my 1995 250 quadrunner suzuki electric start turns it over but it won't kick in
battery / starter motor problem
the starter or start circuit is not getting enough power to run the ignition system when the starter is in use
have a load rest done on the battery and if ok have the starter bench tested
Jul 04, 2017 | Suzuki Motorcycles
Temp gauge stuck past hot mark
The stepper motor that controls the gauge is bad , gm had problems with 03 to 06 vehicles . Here watch the video !
How to repair GM Instrument Cluster Speedometer Gauge Stepper
Apr 20, 2017 | Pontiac Aztek Cars & Trucks
2008 PT Cruiser: battery dead each morning, new battery, alernator & starter check ok. Starts after a boost each morning, starts at noon & at 5pm, but won't start the next morning. Been doing...
Put a test light on the negative battery cable with it unhooked from the battery touch the test light tester side to the negative terminal on the battery .. the test light will illuminate now start pulling fuses .. the test light will dim as u remove the drain ... check and see witch fuse dims the light the most .. check that circuit... its running your battery down
Jan 28, 2014 | 2008 Chrysler Pt Cruiser
Have 2005 nissan altima I replaced the starter positive battery terminal and fuse box on back of positive battery terminal. When I turn the key the engine barely turns over and will not start. What could...
Pull one spark plug at a time and check for oil along with turning key and seeing if it kicks harder with one sparkplug out at a time. If no results, try with spark plugs out and see if it kicks harder. Be sure to have a battery charger or jumper cables hooked up while doing all this to insure equal battery amps along testing each one. Dont turn key more than a few second each time. If it starts or kicks up harder with one spark plug out and you find fluid, blown head gasket, if it kicks harder only once all spark plugs are out, could still be nlown head gasket, but good chance timing is either off, or broken timing chain/gear/belt is the issue.
Dec 01, 2013 | Cars & Trucks
Engine won't turn over. Wait a few seconds then starts fine. Of course, this is not all the time. Battery checks out ok. No codes on computer. But I have now noticed some noises coming from behind glove...
I am not sure as to why there would be noises coming out from behind your glove box, But i would suspect a lose wire. more than likely on the starter itself. I would trace the red or :hot" wire down from the batter to the starter and check them to make sure that they are all tight, also inspect them to be sure that there are no bare spots that might be touching the metal of the motor or frame.
Nov 29, 2010 | 1997 Plymouth Grand Voyager
KTM 950 sm won't start...starter tries to kick bike over but sounds like it is not getting enough juice...battery terminls and lead wires get very hot....battery is new..so I know that is not the...
The wiring should not be getting hot, but if you are trying to get the engine running with the starter motor and it is not turning the engine over, you need to investigate why the engine is not turning. Put the shifter in top gear and try to push the bike (key off) to see if the engine is free to turn. If ok, remove the starter motor and check the drive to the engine. It may be a broken chain or other interference trouble. Try running the starter with the chain disconnected. If it won't turn (make sure the body of the motor is touching the engine), the motor may be jammed in some way. The other possibility is that the wiring to the starter is grounding out somewhere--maybe the starter solenoid. Hope this helps!
Nov 21, 2010 | 2005 KTM 950 Supermoto
Have barely any compression at all but still starts after a lot of kicks.
turn off the key, hold the choke button and keep on kicking the crank handle for a few times but dont turn on the accellarator, After that turn on the key and release the choke button and slowly turn on the accellarator after every kick
Sep 13, 2010 | 2003 kawasaki KX 250
My cooling fan motor isn't turning on my 2004 Pontiac Sunfire. My car is running hot because of this. How can I change the motor myself without spending a tonne of money on a dealership.
first check if the motor is bad.We ran a hot wire from hot to hot on battery.The fan kicked on.Ours was an inline fuse so ran wire from the positive wire on fan to a wire (hot) to key switch.This way you turn on the key and fan comes on
Sep 24, 2009 | Pontiac Sunbird Cars & Trucks
Ktm 450 exc battery charged but will not turn over quick enough to start valve clearence ok and kick starts easy please help
Starter motor check for worn out carbon contacts.Also it's wiring and the starter relay.The regulator/rectifier is charging efficiently the battery?
Jun 06, 2009 | 2004 KTM EXC 450 Racing
1994jeep cherokee will not start
it may be your crank position sensor
Jan 14, 2009 | 1994 Jeep Cherokee Country
1995-1997 Chevy Tahoe Ignition Starter Alarm Switch Logo
173 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
