FixYa.com
Tags:
1995 Honda Civic
1995 HONDA CIVIC HARD TO START
posted by GOLFNUTT on May 24, 2008
I have a 1995 Honda Civic that when cold is hard to start. The Car had been sitting for about 6 months and have since replaced the timing belt, plugs, wires, cap and rotor. Once it starts it sounds like it is flooded and takes a minute or two to clear out the system then it runs GREAT. I do not want to just throw stuff at it to see what sticks however would like to hear if anyone is familiar with the problem. The Check Engine light does not come on and as I mentioned I can drive it all day without a problem however once the car its off for a few hours the tough starting conditions raises its ugly head. I basically have to press the pedal all the way to the flood while cranking over the engine before it fires up and again as mentioned above it sounds flooded and takes a minute or two for the motor to smooth itself out.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 24, 2008
Not Rated (0)
night71
Rank:Guru Guru
Rating: 90%, 522 votes
Get the fuel injectors checked, the rubber seal may be eroded from sitting. When the seals are dry, it will run rough until the gasoline soaks them which causes them to expand. Although you may not see an error message on the dash, the computer itself may signal a problem in particular. It may be an Oxygen or MAF Sensor too.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Cars problems?
Acura CL
Sorry this is not correct
Sorry this is not correct... Answer This...
Ford F-150
03 ford f 150 misfire
03 ford f 150 misfire under... Answer This...
Ford Fairmont
hi, i have a eb
hi, i have a eb falcon sedan,... Answer This...
Pontiac Vibe
no high beams
have low beams but no high... Answer This...
1995 Honda Civic
honda civic 95 dx
hi,I just replace expansion... Answer This...
Repair Service
Find Car Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
