Question about Briggs & Stratton Power Products 5,550 Watt Portable Generator #30241
No spark. alpha numeric code: 6BSXS.3422HT 276454. Original problem is no compression. Removed valve cover and exhaust valve stem is way low...figure bent valve. but decided to check for spark and none. Removed stop switch and disconnected leads and connected leads. No avail. Has oil. Does system have safety kill switch? low oil, no spark?? engine damage, no spark?? thank u.
2 Suggested Answers
H2_Brad
  • 425 Answers
SOURCE: 6bsxs.3422ht No spark and
It looks like it uses part #492341. I didn't see any other ones listed. It's item number 333 and they call it an armature even though most people, including myself, refer to it as the coil. Here is a link to the engine parts diagram that I found for it.
http://bsintek.basco.com/BriggsDocumentDisplay/default.aspx?filename=18npyLXCnfBhU7y
And here is the main page with the other diagrams and owners manuals that you can down load.
http://www.briggsandstratton.com/generators-pressure-washers/support/operators-manuals/?NTT=30241
Posted on Jul 19, 2011
Honda EG 1500C Gen. No compression on pulling rope. Opened valve access cover. No movement on exhaust valve. Push rod from crankcase does not move Is this normal for easy start engines?
As far as I know this generator has not a manual activated valve opener. Therefor the exhaust valve may be stuck in the open position. Spray the valve stem/shaft at both side where it enters the casing with penetrating oil and leave for a while. (Hour or so). Try then to get the valve to move freely by moving the valve up and down. Use pliers but the jaws must be covered with a thick cloth as not to damage or scrape the valve stem. Ps. if the inlet valve moves but the outlet doesn't then the outlet is just stuck and need to be loosened.
Jun 05, 2017 | Honda Electrical Supplies
1993 nissan pickup 12 valve running of 3 cyliners. Removed spark plug wires and found that one cylinder was dead, then removed the spark plug wire from this cylinder, grounded it and had spark.
Can you do a compression test?
There may be something amiss with the piston or valve.. and it's usually the exhaust valve that has burnt/split, allowing compression to be kicked straight out of the exhaust. The symptom of a burnt/split exhaust valve is akin to a misfiring spark plug
Apr 23, 2016 | 1993 Nissan Pickup
Cyl #7 dead miss
Do a running compression test. What you are experiencing IS mechanical. I would suspect a lifter collapsing at higher/faster rpm and you will not see it with the valvecover off.I have seen this numerous times and a running compression test will let you know
Apr 25, 2015 | Cars & Trucks
Having loud valve tick on 3rd cylinder compression test showed it was weak. took valve cover off and checked everything with feeler gauge to find
If you know how valves are installed in a head, then you know there is one traditional way to repair problem -- pull the head off.
The other is to replaced the seals and keepers while holding the valve up against the valve seat from the valve stem. Mess up and you pull the head to finish the repair. For someone who has not done engine work - take the car to the shop OR pull the head and take it in, Normally if there are 2 heads you do both at the same time, because repairing one side makes it stronger than the other and the can bring on other problems.
Apr 04, 2015 | Cars & Trucks
I have a honda gc160 and the engine exaust valves keep sticking and then I cam't start it because there is no compression. What can I do to correct this problem. I have had it in twice and always the same...
Just freeing up the valve isn't going to resolve the problem. Only replacing the bad valve and possibly the cylinder barrel if the valve guides are badly worn as they are non replaceable.
As the exhaust valve is probably sticking due carbon build on the stem which sometimes be simply removed.
Mar 03, 2015 | Honda Garden
How do i know if i bent my valve stems buy rotateing my engine to do ther next push rod before it bled down
remove rocker cover and watch the valves come to the top after each rotation and you will see one or more not come up as high as the others ! compression gauge will tell you which cylinder , a pressure drop tester will tell you how meany valves leak ( with carbs and exhaust removed so you can see and hear which valves ) first test no oil on top of pistons then secound test with oil covering piston top and if any pressures go up then rings are also leaking ! most garages can do this for you !
Apr 19, 2014 | Motorcycles
6bsxs.3422ht No spark and dealer can't identify which coil it uses
Jul 19, 2011 | Briggs & Stratton Power Products 5,550...
Im having a multiple or #5 misfire. I have replaced the spark plugs and still getting the same code
Is this a Ford 5.4 liter Engine (TRITON)?
There are 3 steps that you need to do, Do a Compression test of 1, 3, 5, 7 and annotate the compression but this is what you are going to find
There is ZERO COMPRESSION on #5 Cylinder. The problem you are having is common but not widely known. If this is the 5.4 Liter engine, you will find that the Valve Cam pushes on the Valve Stem and it has slipped off and causing your issue.
Other Issues can be
a. Coil Pack, Swap with another Cylinder and see if the problem follows
b. Clogged Fuel Injector, Swap with another Cylinder
Once you find out where the problem moves, you can repair or replace the problem. If it is the Cam/Valve Stem Rocker, then you have to pull the Valve Cover and put the Rocker back on, there are keepers now available to protect it from happening...
May 26, 2011 | Ford Explorer Cars & Trucks
I am blowing oil out of the vent from the valve cover on a 70's 6040. Any answers to this problem?
This is called blow-by. Start with compression test to find out is rings are ok. Need more information like gas diesel, model number of engine. So here is a general run down. Compression is getting into crank case. Several things can cause this. Possible causes are bad valve guides, rings, head gasket valve stem seals. Compression test will tell if low cylinder. If this is ok for your year model look to valve stem seals. If two cylinders next to each other low. Possible head gasket leak. Use compressed air 60-90 psi and listen were air is going. If blowing into crank case or intake exhaust manifolds. If crank case rings if not valves. I am going to assume your engine is burning oil or using more then normal. Possible white smoke from exhaust. If this is the case and compression is good valve stem seals should fix it. Hope this helps. Remember when compressing cylinders have both valves closed on top dead cylinder.
Mar 18, 2010 | B&C Allis Chalmers Tractor B,c,ca...
My 93 gmc vandura smokes from exaust when engine starts
You're burning oil, I've got the same problem with mine. It's not that big of a problem, just change the oil on time, mine has been doing it for years and there has never been a problem as a result.
Aug 03, 2008 | GMC V2500 Cars & Trucks
Briggs & Stratton Power Products 5,550 Watt Portable Generator #30241 Logo
1,514 people viewed this question
Top Briggs & Stratton Electrical Supplies Experts
John Trevino
Falcon52
Level 1 Expert
Are you a Briggs & Stratton Electrical Supply Expert? Answer questions, earn points and help others
