Question about Gateway Computers & Internet
Hello I have a Gateway NV54 and I have been having trouble trying to get through to the internet. I need assistance of how to unblock it so that I can get in.
    Sergeant:
  • 270 Answers
Hi, this is a common problem, but can be a little trouble some.
I want you to try to connect to your modem or router using a wire (cat5, came with your modem) Take it out of your router (if you have one) and connect it directly to your computer's Ethernet port.
I want to first make sure an internet path is coming to your house and working.
If the wired works, then you at least have it that far, and we can go on.
If you have a wireless router, (it would help to know which one) then disconnect the cat5 connector from your computer and plug it back into the router's port (the one that is set off by itself)
Back to your computer, If there is a switch to turn on "wifi" (represented by a ((i)) then switch it to the on position.
In a standard windows configuration, the system tray is at the bottom of your screen with all the other icons. Look for an icon that either looks like and antenna or two computers with a bouncing red or green block between them.
If you have such an icon, double left click on it.
A new window should open up to reveal available wireless networks in your area.
Select the one at the top (generally the strongest signal will be in your house.) and select "Connect" at the bottom of the screen.
At this point you may have to enter a password, (check with who set the system up) or it will log you on.
This scenario is for a windows environment. It should work with most systems.
good luck and don't forget to vote!!!
Posted on Sep 28, 2010
  • travisheim98 Oct 21, 2010
    i have a nv54 the wifi button is above the keyboard, above the F9 key. the lights above the keyboard are touch sensitive.
Help my NV54
Most laptops have the ability to operate with just the power cord. Have you tried it? If it won't work, then that's another issue.
Apr 16, 2014 | Gateway Nv54
Gateway nv54 no soundcard
Hello you can download the driver here at gateway:
http://support.gateway.com/product/default.aspx?modelid=2376
First make sure it`s the right model.
But first select your windows system 32 or 64 bit system.
Download the sound driver and unzip the file before you install.
Reboot after the install is done.
Install the other drivers if any missing.
Hope this will help you.
Dec 07, 2012 | Gateway /Creative SoundBlaster Sound Card
Download cd driver for a gateway nv54 laptop
Your operating system shouldn't need a new driver for that. CD drives are recognized configured automatically. You can try cleaning the laser lens on the CD Drive with a CD/DVD laser lens cleaning kit. If that doesn't work then you'll need to replace the drive.
Jun 23, 2012 | Computers & Internet
I cannot get my Gateway NV54 to turn on. I press the power button but nothing happens.
check your power adapter first..try to remove your battery..turn on your laptop.maybe your battery is busted,most probably.
Sep 14, 2011 | Gateway Computers & Internet
Can't connect to internet the internet. My modem is working okay on another pc.Previously I could connect. I'm using GATEWAY NV54 laptop on Windows 7 Home premium
Have you received Windows 7 installed at the time of purchase? If not, check the compatibility with Windows 7. Check your Ethernet adapter with LAN for its proper functioning. Try using latest driver for Ethernet adapter from the laptop manufacturer. If the adapter is OK, restore the system to previous date on which it used to work or reinstall the operating system as a last resort.
sonsunny
Jun 14, 2011 | Microsoft Ethernet MN-120 Network Adapter
I own a Gateway NV54 computer that operates Windows 7. Recently my computer will only work when plugged in and my battery is not charging.
This is a sign that you need to purchase a new battery. The old one will not hold a charge anymore.
Good Luck
C2Solutions
Feb 17, 2011 | Computers & Internet
How do I rebot my nv54
the power button on the nv54 is located on the right side of the laptop, on the hinge
Feb 04, 2011 | Gateway Computers & Internet
My gateway nv54 laptop battery is ok, I've checked it in lap-top tech service. But the system gives me a message "consider replacing your battery" or something like that. With a full-charged...
Unfortunately there isnt much you can do, the only real solution that has ever been known to work is to completely drain the battery (I mean keep trying to turn it on even after its died, many many times) and then put in on charge for 8hrs.
Other than that, regardless of what people say, there isnt much else you can do. And I wouldnt put too much faith in any tests these techs have run, its almost impossible to really see what state the battery cells are in.
For future reference, when you are using your laptop plugged into the mains, take the battery out, that wil help prolong its life, and never let it get too hot or charge it longer than it needs (can bend the cell walls)
Oct 30, 2010 | Gateway Computers & Internet
Can't activate touch pad
Try pressing the Fn and F9 keys simultaneously.
Jan 08, 2010 | Gateway 450ROG Notebook
Computers & Internet Logo
574 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
