Question about Electrolux Guardian Bagged Canister Vacuum
Just replaced bag. Turned on and pop and now nothing.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 100 Answers
Pop as in the bag flew off and hit the back of the bag holder compartment?
or pop as in the a circuit 'sploded?
Posted on Sep 28, 2010
I just replaced the bag (used recommended Miele bag). When I turned on the machine the red "bag full" indicator comes on and the suction seems poor. I tried reinserting bag. ?
Good afternoon Kristen.
Vacuum cleaners usually pop the 'bag full' indicator when they lose suction due to the load of dirt in the bag impeding the motor pulling air through.
If you are still getting the indicator with a new bag, and already did the prudent re-seating of the bag, the next thing is likely a clog or blockage elsewhere in the vacuum. You don't specify the model, so I can't be too specific.
Safety first. Please please please make sure the unit is unplugged before you start disassembling.
As you are able, detach hoses, look in the back of the brush unit, see if there's a blockage. Wads of crumpled paper are particularly good at wedging themselves into corrugated flex lines. Depending on location, I've found that a wire coat hanger, bent into marshmallow-roaster configuration, with the old hook bent with some pliers into a long straight section with a small half-loop at the end, can be a good probe for the long sections of tube to see if it runs into anything, and then perhaps hook it and pull it out. Be careful if you do this to not hook the tubing walls and tear them.
Hoping this helps!
D
Nov 18, 2015 | Miele Vacuums
How do I access the motor and replace the brushes on compact tristar vacuum cleaner?
I need the actual model number for that vacuum and then I can give you the correct/specific instructions.
Feb 03, 2015 | Tristar Vacuums
My oreck xl just turned off by itself while I was vacuuming. Now it won't turn back on.
This is a BS site - I look for answers and just get Pop-ups and Ads@#%$#@&^%$##
Nov 11, 2010 | Oreck XL2200 Bagged Upright Vacuum
When turned on caused, caused a pop at the outlet and don't know if the if the power cord went bad or short somewhere else in the sustem. what do i do and how
Hi, that pop sound you heard at the outlet simply implies that the fuse blew off. What you just need to do is too replace the fuse and if the power cord is having a burn smell, then i will also advise you to change the power cord..
Take care
Apr 03, 2010 | Kenmore 23313 Whispertone Bagged Canister...
I have a model 116.35922 beltless drive vacuum. The agitator brush will not turn with the vacuum running and the handle down. The brush turns by hand and the reset button has not popped. Ther is nothing...
I just had the same problem. The roller will not turn if the unit is overheated. I discovered that my bag was too full. I changed the bag then the roller started turning again. I don't know if this is true cause and effect, but it couldn't hurt to try.
Aug 23, 2009 | Kenmore Vacuums
Drive and brushes stopped
Look for a missing belt that may have burned off or broken. Was there a burning smell at some point before the roller quit turning? If so, the belt must be replaced. I would also look at the ends of the roller to see if there is any string, hair, etc. that might be binding the roller that needs to be removed.
Jan 24, 2009 | Hoover U8125-900 Savvy Bagged Upright...
Not picking up dirt.
There is a Clog in the machine...
Somewhere between the motor and the bag.
When you use the machine, the dirt picked up by the roller has no place to go but backwards.
You will need to disassemble it and look for the clog.
Nov 22, 2008 | Oreck XL2200 Bagged Upright Vacuum
Electrolux Renaissance canister
there are a couple situations to this issue. one is the bag that was replaced is a incorrect one and it is not meeting the switch for the bag pop circuit. some over the counter bags cause this issue. another problem could be the switch itself. or the bag door not being tight enoug to make contact with the bag.
Aug 07, 2008 | Electrolux Lux 5500 Canister Vacuum
Hello, My Electrolux Renaissance is about 12 years old. It worked great for years, but now it keeps turning itself off...about every 15 seconds or so. The bag was just changed recently, too. Is there...
Odds are you have an obstruction somewhere. Check all of the hoses and the power head to ensure that there is nothing blocking your airflow.
Also note that if it keeps popping the front bag door open, that's usually indicative of either the bag being full or not being installed properly, which can give you the same results, so try taking the bag out and popping it back in just to make sure everything is aligned correctly.
-R
Jul 31, 2008 | Electrolux Vacuums
Off/on switch does not work
The on/off switch in Hoover Windtunnel upright vacuum cleaners is operated by a lever in the handle assembly.  remove the two screws on the back ovf the vacuum and see if the lever has bypassed the switch assembly.  if so, re-assembly should fix the problem.  It is also possible that the switch activating lever has broken.  If so, replace the activating lever.
Oct 24, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Electrolux Guardian Bagged Canister Vacuum Logo
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
