Question about Philips 190B7CB LCD Monitor
USB and speakers not working.
The usb port and speakers on my philips 190b7cb monitor won't work.  When I got into Display -> Settings -> Advanced an error message saying "Philips Smart Control could not be displayed".  I have the drivers installed and i can't figure out what's wrong.
  • 472 Answers
Have you got..
  1. A USB cable from the computer connected to the USB input on the monitor? It needs that cable to supply USB outputs from the monitor. The monitor acts as a USB hub.
  2. The speakers on the monitor also require a cable from the soundcard on your computer to the sound input of the monitor.
Posted on May 24, 2008
I can't find the location to plug the speakers in on my acer monitor.
is it an acer monitor or
Acer (90.00012.30B) Computer Speakers Reviews
are you sure they need to be connected to a monitor if they have a usb connection they will plug into a usb port or if they have plugs the speakers into the speaker outlet usually at the back of a computer then
control panel sounds and audio,volume,advanced,speakers select the appropriate speakers
hope this helps
Jun 25, 2011 | Acer 90.00012.30B Computer Speakers
GPX MW3836 1GB MP3 Player Need driver for Windows7 Where?
The driver for this should be part of the Windows 7 OS. Just plug the USB cable into the computer with the MP3 player in USB mode. This is confirmed in the Windows 7 Compatibility Center.
The only driver on the GPX website: http://www.gpx.com/store/p/186-MW3836.aspx is for Win98. See the Downloads section.
I suspect if the unit is not registering with the computer, you may have a port issue or cable issue. Try a different USB cable; it looks like a 4 pin mini-B to A USB cable. Make sure that the ports work on the computer and that they aren't disabled for security or power saviings. (The first is under Device Manager (Start > Control Panel > Hardware and Sound > Device Manager); the second is part of the advanced settings for the screen saver (right click on the Display where there are no running programs or icons and choose Personalize > Screen Saver > Change Power Settings > Change Plan Settings > Change Advanced Settings) Try a direct connection if using a USB hub.
I hope this helps.
Mar 27, 2011 | GPX MW3836 MP3 Player
My LCD monitor blinks after switch on the power. display appear and go blank again appears and go blank and again and again.......................
1. Make sure the computer is switched on.
2. Check to see if the monitor cable has bent pins.
3. Make sure the signal cable is properly connected to your computer.
4. The energy saving feature may be activated.
Thanks for choosing FixYa
Oct 11, 2010 | Philips 190B7CB LCD Monitor
I continue to get Printer disconnected with vista. I can not no maatter what I try get it to connect.
Try a new USB cable and/or a different port. (If you are using a print server or USB hub, try a direct connection.) Make sure the USB ports aren't disabled for security or power savings. (Check the device manager from the Control Panel in Windows and the advanced settings from the Screen Saver settings.) Check if a known working device works in the USB port.
Some of these printers have monitoring software as part of their full-featured software, so check that this software is running.
http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=9103/9104/9106&product=EKN033540&operatingSystem=windows_vista if you want to reinstall the software (uninstall the old version then disconnect the USB cable before reinstalling.)
The worst case scenario is to try the firmware update from the above link. Try everything else first, the firmware update can cause more problems.
I hope this helps.
May 04, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
I can not hear anything with it on
the speakers might be muffeled from the felt cover
Dec 20, 2009 | Microsoft LifeChat™ LX-3000 Headset
USB ports do not work. No sound from Speakers
Hi I am Vortash ... .. if you have your audio drivers re-install them after you Check the sound settings in advanced and make sure the speakers are not disabled .. As for the usb ports check in device manager that the usb is installed and enabled and that your drivers are working if not update if it asks search web say yes if your on the web where you are and get the latest ones ... hope this helps Vortash
May 02, 2009 | Dell Inspiron 1100 Notebook
No sound from headset plugged into monitor
From the manual I found, this model does NOT support ANY audio connections.
http://www.p4c.philips.com/files/1/170b1a/170b1a_dfu_aen.pdf
170B Product Features
- 17" color LCD monitor with excellent display performance.
- Dual input-accepts both DVI Digital and VGA Analog input.
- Advanced AUTO adjustment automatically optimizes picture quality.
- Wide viewing angle technology.
- 7.1 (181mm) small footpring with full detachable cables.
- USB Bay for upgrade to USB Hub.
- Optional protective cover to prevent LCD panel damage.
- Standard VESA mounting holes and optional tilt/swivel Wall Mount Kit.
But if yours does have these ports, I would suggest they are not for a headset, but for connection to the _PC_. I would suggest your model monitor has built in speakers, and the green port is the INPUT from the PC Speaker output. The pink goes back to the PC from the MIC which is built into the screen.
Apr 21, 2009 | Computers & Internet
Usb ports not working
  1. Checking USB device status in Device Manager
  1. Right-click My Computer on the Windows desktop and then click Properties.
  2. Click the Device Manager tab to display the Device Manager window as shown at the right. (For Windows 2000 systems, click the Hardware tab and then the Device Manager button.
  3. In the Device Manager list, click the + sign next to Universal serial bus controller.
  4. Verify that a USB host controller and a USB root hub are listed below Universal serial bus. image002.jpg
  5. If Universal serial bus controller, USB host controller or USB root hub are not listed, close the Device Manager and go to USB port incorrectly configured in BIOS
  6. If Universal serial bus controller, USB host controller and USB root hub are listed but one or more display a yellow exclamation point, go to USB controller IRQ conflict
  7. If you have Windows XP, right-click the Host Controller and select Properties from the drop-down menu. If you see this status message in the Properties window: The drivers for this device are not installed (code 28), go to Windows XP USB 2.0 driver not installed .
  8. If Universal serial bus controller, USB host controller and USB root hub are listed but one or more display a red X, go to USB controller or root hub disabled in Windows Device Manager.
USB port incorrectly configured in BIOS NOTE: The procedure in this section is intended for advanced users only. Incorrect BIOS settings could prevent your computer from starting or operating normally. If you are not experienced in making changes to your computer BIOS, consult your computer instructions or contact your computer manufacturer for assistance before attempting the steps below.
  1. Follow the instructions of your computer to view the BIOS settings. These settings are sometimes called CMOS settings or system setup.
  2. To view the BIOS settings, press a key, such as F2 or Delete, just after you turn on the computer. Instructions often appear on the screen briefly when you turn on the computer. Also check the instructions and manuals provided with your computer.
  3. Look for USB Interface or a similar setting in the Advanced Setup, Peripheral Configuration or another section of your computer BIOS settings.
  4. Follow the onscreen instructions or read the computer documentation to enable the USB port.
  5. Follow the onscreen instructions to save the new settings and restart the computer.
  1. USB controller or root hub disabled in Windows Device Manager
  2. Click the Device Manager tab. (On Windows 2000 and XP systems, click the Hardware tab and then the Device Manager button.)
  4. Click the line in the Device Manager containing the red X.
  5. Click the Properties button. (On Windows 2000 and XP systems, click Properties on the Action menu.)
  6. In the Communications Port Properties box, click the Resources tab.
  7. Re-enable the USB device by clicking the Enable Device button and follow the onscreen instructions.
Dec 28, 2008 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Connect Laptop to TV via USB
Hi i have only connected my laptop to the tv a few times. i did it through a scart lead connecting to the s-video-out socket on my laptop. then i when to display propertise , settings then selected screen 2, then extened to desktop monitor. it worked. i then opened a film in my player, dragged it accross, went full screen job done. hope this helps...
Nov 22, 2008 | Acer Aspire 5100 Notebook
Phillips voip321 duo phone drivers not compatible with vista even on phillips product support they do not work please help me
I had the same problem with a HP Pavilion PC running vista. The way I fixed this problem with to plug the USB into a USB port on the PC not using a ext USB Hub. I did have to go into the sound in the control panel and change the default so the other programs would use the correct sound.
Apr 20, 2008 | Lands Phones
Philips 190B7CB  LCD Monitor Logo
541 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
