Question about Dell Inspiron Mini 10 Notebook
Welcome screen comes up but when I click on user name it goes to desktop screen background with no icons
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 132 Answers
This can be fixed..
Press and holt Control+Alt keys and then press Del key one...
Then you need to select the option task manager..
In task manager select file at the top...
Under file select new task and type explore.exe in lower case and push enter..
You must be able to see the start menu and the desktop icon...
If you still dont find the desktop icon - right on desktop and select show all desktop icons...
The problem should be fixed...
Posted on Sep 28, 2010
  • chriscash200 Sep 28, 2010
    Followed instructions but nothing changed on the screen. Was never given "option task manager."
Change background from black to white
Which operating system ??
Is it for computer background or a program ??..
Make a Black Background White
The desktop appearance of a computer equipped with Microsoft Windows XP, whether PC or laptop, can be customized easily.
Users can change background color, background image, frame color, font size and the arrangement of desktop icons.
Five easy steps how to change the desktop background color from black to white.
Changing Background Color
Right-click the mouse on any open portion (i.e., non-icon) of the desktop, which will open a menu. Select "Properties" at the menu's bottom, which will open the "Display Properties" application.
Click the "Desktop" tab at the application's top.
Click the down arrow next to the "Color" button, and select the white color.
Click the "Apply" button, then click "OK" to close the application.
http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/display_change_background_color.mspx?mfr=true
Aug 30, 2013 | Computers & Internet
Tip
Applying the settings to the logon desktop
Next, you need to apply the Screensaver settings to the Logon Desktop / Welcome Screen (Technically, HKEY_USERS\.Default registry key), so that the Screensaver is invoked when no user is logged on. Copying all the Screensaver settings to the Logon Desktop (or Welcome Screen) manually is a tough task. Use Tweak UI instead.
Download and install TweakUI.
Launch TweakUI and click Logon, click Settings.
Select Screensaver from the list box and choose Copy Now
The Screensaver settings are applied to the Logon Desktop
Restart Windows for the changes to take effect
Allow few minutes at the Logon screen, to test if the Screensaver is working properly. The Screensaver should launch after the timeout. It will look as if the Company Logo moves around.
Additional Tip
The User interface / slider allows the minimum value for picture change interval to 6 seconds only. To reduce the change interval to less than 6 seconds, alter the registry value named ChangeInterval (Set decimal value 1000 for 1 Second, and so forth) in this key:
HKEY_USERS \ .DEFAULT \ Control Panel \ Screen Saver.Slideshow
For Current user profile, make the change here:
HKEY_CURRENT_USER \ Control Panel \ Screen Saver.Slideshow
With no logon wallpaper set, Windows displays a pre-defined color for the logon desktop. ( If you have enabled Welcome Screen, press CTRL+ALT+DEL twice to see the logon screen background color. ) To change the logon background color to that of your choice, you need to alter the registry:
Click Start, Run and type REGEDIT and press Enter
Navigate to the following key:
HKEY_USERS\.DEFAULT\Control Panel\Colors
Backup the registry key by exporting to a REG file
In the right pane, double-click Background
In the Edit String dialog box, type the Color code in R G B format and then click OK.
Example: Type 0 0 0 if you want to see a Black background. You can choose any combination from 0-255
Points to ponder
If the logon Wallpaper is set, the background Color may not be visible. So, you must reset the Wallpaper value to a blank string in this key: HKEY_USERS\.DEFAULT\Control Panel\Desktop
If the Background value is set under the following Winlogon registry key, the above setting is ignored. In other words, the Winlogon\Background value takes precedence over the .DEFAULT..\Background value.
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Winlogon
on Mar 24, 2008 | Microsoft Windows Vista Ultimate Edition
Logon Change
Enable Log-On Screen
Windows, by default, is set to show the Welcome screen during startup.
To enable the log-on screen to show, go to "Start" menu and select "Control Panel".
In the control panel, click on "User Accounts".
In the "User Accounts" dialog-box, click "Change the way users log on or off" and uncheck the "Welcome Screen" option.
Click "Apply Options" to save the changes.
Change Log-On Screen Background Color
To change the log-on screen background color, go to the "Start" menu and click on "Run".
In the run dialog-box, type "mspaint" as the name of the program to "Open".
Click on "OK". In the "Paint" window that opens, select "Colors" from the main menu and click on "Edit Colors". In the "Edit Colors" dialog-box, select "Define custom colors".
Here pick the color of your choice and note down the "Red", "Green" and "Blue" values.
Write down these values somewhere.
Click "Cancel" and close the paint window without saving. Now, go to the "Start" menu, click "Run" and enter "regedit" as the name of the program to "Open".
In the registry editor, navigate to HKEY_USERS\.DEFAULT\CONTROL PANEL\COLORS and double-click the "Background" string.
In the "Edit String" dialog-box that opens up, change the values in the "Value data" field to the red, green and blue color values that you wrote down (e.g. 75 78 173).
The default value will be 0 78 152. Enter the values in the correct red-green-blue order, separated by a space. Close the registry editor and log off to see the changes.
Put Image in Log-On Screen Background
To put your favorite picture in the background of the log-on screen, click "Start", then "Run", and type in "regedit". In the registry editor, navigate to HKEY_USERS\.DEFAULT\CONTROL PANEL\DESKTOP and double-click the string "Wallpaper". In the "Edit String" dialog-box that opens up, enter the full path and filename of the image that you want to use as the background. The image must be in .bmp format. Click "OK" and close the registry editor. Log off to see the changes. hope this helps
Oct 03, 2012 | Microsoft Windows XP Home Edition for PC
2 MIN ICON ON WELCOME SCREEN ACER
My dad fixed this problem by changing the background on his computer. I know this sounds like a strange fix, but apparently certain backgrounds just affect the load time and I think that's what this "2 min" icon was representing. His icon has now disappeared.
Feb 26, 2012 | Computers & Internet
How do i change my desktop background in my sony vaio y series?
Hello, I am the technician that will be assisting you today. My name is Norman-Wynne Damstra.
Welcome to Fixya, Sef Noel.
To change your background, simply Right click the picture that you would like your desktop background set to and select the option to "set as desktop background"
Alternatively you may right click on your desktop and select properties.
Then click the desktop tab.
Now select the desired background from the list and click Apply then Ok.
Take care!
Nov 06, 2011 | Sony VAIO VPCY216GXV Y Series Notebook PC
I need help changing my background on my Gateway LT20 Series
Hi there and welcome to Fixya!
I'm guessing you're referring to the Windows desktop background. But if not, please provide additional information.
The Windows desktop background is the image on the desktop that appears behind the shortcuts. To change the background, please follow the steps below:
1. Open the "Display Properties" screen by placing the mouse cursor over a blank area of the desktop. Click the right mouse button to access the context menu and choose "Properties". You can also access the "Display Properties" screen by clicking on Start, select Control Panel, and then Appearances and Themes. Open the "Display" shortcut.
2. Select the "Desktop" tab from the "Display Properties" screen.
3. Pick a picture from the Background list by clicking on it and click on "Center, Tile or Stretch" to select the position. Personal pictures in the "My Pictures" folder are listed by name in the Background list.
4. Choose a background picture in another location by clicking on the "Browse" button. You can use any files with the following extensions: .bmp, .dib, .gif, .htm or .jpg. Click on "Center, Tile or Stretch" to select the position.
Jun 28, 2011 | Gateway LT2001u Netbook
Went to change profile photo, It came up on my des...
Somehow it looks you have set the photo as desktop background.
Assuming it to be XP.
To remove desktop background you can right click on open space on Desktop-> click on "Properties" -> click on tab Desktop, On background scroll to top and select none. and click "Apply" this will remove your photo from desktop.
For others follow the link on how to remove desktop background.
http://www.online-tech-tips.com/computer-tips/how-remove-wallpaper/
Hope this helps
May 19, 2010 | Computers & Internet
My screen is stuck on the WELCOME screen, when I click my name to log in, my desktop is visible with no icons, then immediately logs off and returns to the WELCOME screen...
I think some of booting files missing..... due to virus affected . so insert the Xp os cd and repair it... after that scan ur computer with good antivirus .......
Feb 21, 2010 | Dell Dimension E521 PC Desktop
My Toshiba Satelite A105-S4211 wont log in
I recently ran into a computer doing this.
Try what jmagnu said, hopefully it will work for you (safe mode didn't help me).
I basically had to remove the hard drive from the computer, install it into another computer and run a ton of virus, malware, spyware scans on the drive.
I used a combination of AVG, superantispyware, malwarebyte's malware remover, hijackthis, ccleaner, and a few others who's names escape me.
Best of luck :)
Dec 16, 2008 | Toshiba Satellite A105 Notebook
Desktop icons and start button issue
Hit CTRL-ALT-DEL
Task manager will come up.
Then click File, New Task.
Then type explorer.exe
This will load the things that you're missing. These things are probably missing because you have a virus. Make sure you do a scan.
May 20, 2008 | E-Machines eMachines Desktop PC
Dell Inspiron Mini 10 Notebook Logo
61 people viewed this question
Alun Cox
