Question about MagLite Mag-Lite& Largehead Flashlight
How to remove bulb from Maglite (3-D-cell flashlight about a foot long)
  • 2,100 Answers
Twist the front bell off, unscrew the bulb.
Posted on Sep 28, 2010
  • 1 more comment
  • mscanlon113 Sep 28, 2010
    Thanks for the reply, but it is not helpful. The bulb does not unscrew. Maybe someone has actually done this repair before, and could share the actual procedure.
  • Ned  White
    Ned White Sep 28, 2010
    Wait a minute, I have the exact same flashlight in my hand, It unscrews in the front like I said, and the bulb unscrews, it is held in by a little chrome thing with teeth on the top for your fingers to grip. The little maglites have bulbs with 2 pins on them, they don't screw in. I have put high intensity bulbs in my maglites, I have about 10 of them kicking around here and a drawer full of bulbs. Now unless you got something different there, I don't know, but mine are Maglites, 3 "D" cell, and 4 "D" cell. and 2"AA" cell lites.
  • specialed292 Dec 04, 2010
    I have the same problem with my 2 D cell maglite with an LED bulb. No way to unscrew the bulb or grasp it to pull it out.
I need the small tool to be able to get into the outer cover( the black button )to be able to change the bulb. where I can replace the bulb.
I believe you have to take the rubber cover over the button off, then push on the edges of the button, it's attached to the light assembly so you can pull it out, call Maglite tech, they'll help. Good luck.
Mar 30, 2015 | Other MAG-3D-LED - Maglite 3 D-Cell LED...
My 6d maglite keeps blowing the bulb
6D Maglite? As in 6 D cell batteries?
1-1/2 Volts (Each battery), times 6 = 9 Volts.
Using the proper bulb?
The original is a Krypton bulb. (No, I didn't make the name up)
http://www.toolup.com/maglite_lmsa601_mag-num-star-6d-relacement-bulb.aspx
http://www.batteryjunction.com/maglite6c.html
Guess what happens if you put a 3 Volt bulb with 9 Volts?
Regards,
joecoolvette
Nov 27, 2012 | MagLite Mag-Lite& Flashlight
2 D-cell maglite bulb lights up only when I press it down after removing lense. Everything else appears to work ok
Make sure you have the MagLite bulb with the flange, it is integral to the operation of the light.
Sep 06, 2011 | MagLite Mag-Lite& Flashlight
Removable of switch on a 3 d cell maglite
Maglite sells a switch removal tool or you can buy it from a MagLite supplier. See website below
http://maglitesales.com/maglitestore/Replacement-Parts/Maglite-parts/Switch-Removal-Tool-for-D-Cell-maglite-Flashlight
Good luck, Gary
Jun 26, 2011 | MagLite Mag-Lite& Flashlight
I have a 3AA LED mini maglite with stuck batteries. The best I can tell they have not leaked. I tried freezing the unit as well as heating the barrel to no avail. Is there a way of removing the bulb...
well, I have a 3 cell mini maglite AA with a corroded battery stuck up next to the LED. I have searched but not found a way to remove the LED to push out the battery with a dowel. The best solution I read about was to drill a hole in the battery and insert a large screw and pull it all out.
(My Maglite is from 2009 or 2010, but I think they made this model in 2011, 2012 and 2013- this is for SEO!)
Sep 13, 2010 | MagLite Mag Lite Led 2 Cell Aa Flashlight...
I have a five D cell Maglite. Seems to always
There are diffferent mag lite bulbs made for different amounts of batteries. Be sure that you have the 5 cell light bulb. Also try to keep your fingers off the glass. if you get any oils on it, wipe it off before turning it on.
Also you can get mag lite specific bulbs...they cost more but they're worth it.
Feb 03, 2010 | MagLite Flashlight Type: Black D Cell 5:...
How to get the bulb out of a 3-D battery maglite
Unscrew the head of the flashlight and take it off. There is a metal ring around the bulb that you have to unscrew to remove the bulb.
Jan 01, 2010 | MagLite 3 Cell D Blue Flashlight S3D116
I can't get the bulb out of my 3 D cell MgaLite?
After unscrewing and removing the reflector/lens housing just push in lightly on the bulb twist counter clockwise and it should pop right out.
Sep 11, 2009 | Camping, Backpacking & Hiking
MagLite Mag-Lite& Largehead Flashlight Logo
804 people viewed this question
Top MagLite Electrical Supplies Experts
ken skalski
Karl Kittsteiner
ray gallant
Are you a MagLite Electrical Supply Expert? Answer questions, earn points and help others
