Question about Toshiba Satellite L355D-S7825 Notebook
My toshiba laptop is very slow shutting down - Toshiba Satellite L355D-S7825 Notebook
My Toshiba c-55 wont turn on the white button light flashes 4 or 5 times and then stops but it never turns on.
I heard of many power issues with these models. Mostly concearning the battery, it sounds like this may well be the case from the 'light flashing' issue.
The other problem involving slow start up/ being laggy could be down to the machine running hot and Windows is using passive cooling in the power options, or a failing hard drive can also cause software problems.
Dec 25, 2014 | Toshiba Satellite Computers & Internet
Laptop goes on some few minutes after being shut down.
you cannot blame windows xp because according to me it is such OS that it removes many problems of windows 7 and vista.windows 7 and vista makes your pc much slow and many features dont work but windows xp is free from these errors.actually you hear the sound but nothing appears on the screen.this is because your cpu fan is running which takes somes time to stop.may be some problem of the hardware especially the mainboard.go to any repair shop and just get it checked.
Apr 02, 2012 | Toshiba Satellite Pro L300 Notebook
I have a Toshiba laptop with a Windows 7 operating system, a few years old. It recently started randomly shutting down - after 10 minutes or so of use, it would just go dead. It's also extremely slow,...
Hi.
the first thing i would check is to make sure there is no dirt or dust stopping the fan from running because if the fan is not running it will heat up and shut down or if the fan is running slow it will shut down.
and for running slow i would do a good clean up get rid off stuff thats not needed anymore.like music,pictures,the more your harddrive has on it the longer it will take to load and run.
Oct 21, 2017 | Toshiba Satellite L455-S5975 Series Laptop...
My Toshiba P35-S611 shuts down without warning a short time (2 min-45 min) after it boots up. The battery isn't hot but the heat dissipation fins in the back are very hot.
Indications of laptop overheating problem:
  1. The keyboard and the bottom of your laptop are very hot when the laptop is working.
  2. The CPU fans are working all the time at maximum rotation speed and operate much louder than before.
  3. The laptop suddenly shuts down by itself without warning. When it just started, the laptop was shutting down after 1-2 hours and how it shuts down after 5-10 minutes of operation.
  4. The laptop works fine when it runs idle, but shuts down as soon as you start using any memory demanding applications (DVD player, image editing software, video editing software, etc.).
Solution:
If the CPU heatsink is not clogged with dust and lint completely, you can use canned air and just blow it inside the laptop through the openings on the bottom and on the sides. It’s nice as a precaution measure, but it might not work if your laptop already has a problem and the heatsink is completely clogged.
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes (for example Toshiba Satellite A70/A75) you have to open the laptop case all the way down.
  2. Carefully disconnect the fan cables on the system board and remove the fan. If the fan makes unusual sound when it spins (grinding sound), I would recommend to replace the fan.
  3. Clean the fan and the heatsink with compressed air.
  4. I would also recommend removing old thermal grease from the CPU and applying new grease for better heat conductivity.
May 09, 2010 | Toshiba Satellite P35-S611 Notebook
Toshiba Tecra M3 Laptop keeps freezing and shutting down, Can't even do Fresh Install on New Hard Disk Without Freezing, Have Replaced CPU Heatsink Compound.
What made you suspect the compund? You're probably right though. The fan has died or is too slow. The CPU and the video chip are what the fan is protecting. It might require a new CPU chip and fan. If it's the video chip, then a new mother board is in your future.
Good Luck
Mar 21, 2009 | Toshiba Tecra M3 Notebook
Vista Slow Shut Down
is vista the original operating system
Oct 30, 2008 | Toshiba Satellite A135-S4527 Notebook
Toshiba Satellite L355D-S7825 Notebook Logo
37 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
