Question about Mitsubishi WS-55511 55" Rear Projection Television
Where is DM board on WS-55511 - Mitsubishi WS-55511 55" Rear Projection Television
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
As you look from the back of the set it is inside the large metal box on the far left of the set. Several plugs and a few screws and it (the entire box pulls out-it is plugged into a large set of sockets.
Before you remove it let me know what problem you have.
If this told you something you did not know rate this solution as very helpful as I do this here for free.
SD TECH
Posted on Sep 28, 2010
Where is the dm board for ws-55511 located
The dm power board is the small board shown in the illustration below it has the 7 capacitors on it and its located inside the metal box on the far left side of the TV when looking in the rear cover. The metal box stands up vertically2_12_2013_9_52_00_am.jpg
Feb 12, 2013 | Mitsubishi WS-55511 55" Rear Projection...
Ws-55511 green light changed caps. where is pico fuse located ?
There are at least two pico fuses in the DM unit along with the caps; DM is large metal box on left as you look from behind.
Blinking green light that does not stop means problem is in DM unit that is not booting up.
If you have questions let me know.
SD TECH
Sep 29, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Need to know where capacitors are on mitsubishi ws 55511 tv are located at have back of tv off and cant locate them please help thanx
they are located inside the DM modules case( Metal Case on far left side ) open the metal case and you will see 7 caps on the DM power board. I am posting a pic of the board with the 7 caps that need replacement use 1000UF 25V caps to replace the 1000UF 16V caps that are currently installed.
Aug 08, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Ws-55511 red color will not converge, got part
Remove the three screws from the main chassis than release up the two chassis lock on the right and left hand side than slide out you might have to move the DM module on the left side to get the chassis out.
Nov 09, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Ws-55511 replaced all 7 caps in the dm, still wont power on
I have seen this only 2 times----you may be able to unsolder and remove the reset micro switch---you have to remove the whole screen to get at it---the micro switch board may not be available---the switches can be tested with a ohmmeter set to high end and of course should not have a reading across them--I bet the reset switch is bad--you can remove it and put the keyboard back---most of the Mitsubishi sets use the same type of switches--Only other thing is leave the keyboard disconnected and just use the remote.
Glad you found the problem.
Regards, SD TECH
Sep 14, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Got a Mitsubishi ws-55511 as a freebie a few weeks ago. Once plugged in it does nothing but flash the power light. Prior owner removed access panel but went no further. I am an audio engineer with lots of...
Thats an easy fix. The capacitors on the DM are known to fail . You can get the WS48511 - WS65511 DM repair kit at the following link which contains the replacement capacitors and the instructions on how to do the repair on CD which also contains the Service Manual
www.tvrepairkits.net
Jun 25, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Ws-55511 DM 5volts draged down blinking led
Did you check the caps on the DM board? They usually go bad after a period of time. Remove the DM board and the metallic cover and there should be 4 to 7 capacitors (There are different revisions of the DM board). Check these caps also, replace if needed.
Thank you,
Shuttle83
http://www.electron-age-technologies-llc
Apr 05, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Help my ws-55511 can anyone help me with this.
Changing caps on DM board is good prevent maintenance,
 but does not represent the solution...DM caps symptom is
 Continuos blinking light.
 See    " problem 351"    On 10/20   WS 55908  comments.
  Let me know....T.
May 16, 2007 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WS-55511 55" Rear Projection Television Logo
150 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
