Question about Kenmore 24032\24036 Top Load Washer
Sears Kenmore 80 series washing machine Model 110.26832691
How do I remove the agitator on that? The tub doesn't turn by hand or during the spin cycle.
  • 2 more comments
  • pixel_cutter May 24, 2008
    Sorry for the double post didn't think it went through.
  • tdoden Jun 20, 2008
    i did not see a reply to the tearing of the shirts. my kenmore 80series model #11029852991 is tearing my shirts too! HELP!
  • jrratty Jul 17, 2008
    I'm trying to find out how to remove agitator so I can replace "dogs". The info I could find online says to remove top cover and then remove nut in the center of agitator, but that is not a nut, only the top of a shaft.
    Help!
  • Anonymous Mar 06, 2009
    the 2nd agitator wont come off and the rinse cycle will not rinse out the soap and dirt. Even if you run the "second rinse cycle" several times, you cannot get the soap and dirt out of the clothes and water. When the machine was new, I called Sears about the problem. The appliance repairman said it was ok and did not seem to know anything about washers.
How do you remove the top of a kenmore washing machine? I have a mouse stuck in the lid and can not get the top off.
Posted on Apr 30, 2009
Model 11020922990 Kenmore Three speed is tearing shirts. Sear is no help at all. All they want to do is send a $75 service call or sell a warrenty. I just need an answer to the question, Why are my shirts being ripped up. The owners manual has some suggestion none of which fit this situation.
If I have to rely on Sear a rock at stream side sould like a better solution!
Posted on Jun 02, 2008
I changed my Agitator but it seems like something is missing cuz the top has a lot of play and the whole tub wont spin at all i would check the belt but I have no idea were it is can some one help?
Posted on Jul 29, 2010
I did find out how to remove the agitator. It was going to be more then I could dig into cause the tub wasn't turning at all. I went on down and bought a new washer for $314.68 total for a new one with a 10 year warranty. A quick headache over with.
Posted on May 24, 2008
4 Suggested Answers
  • 4 Answers
SOURCE: my 80 series 110-23812-100 type
It's more than likely the clutch. Since you already replaced the motor coupling, it can only be the trans or the clutch and my guess is the clutch since the clutch and motor coupling are the weak links in the system.
Posted on Dec 08, 2008
  • 1122 Answers
SOURCE: Washer won't spin,rinse,or drain
BAD LID SWITCH,YOU CAN REPLACE IT OR BY PASS IT,REMOVE THE 2 CONSOLE HEAD SCREWS ONE ON EACH SIDE,FLIP THE TOP UP,YOU WILL SEE THE LID SWITCH JACK,YOU CAN CUT THE 2 OUTSIDE WIRES AND PUT THEM TOGETHER WITH A WIRE NUT AND PLUG BACK IN,YOU HAVE NOW BY PASSED THE LID SWITCH AND YOUR GOOD TO GO-MIKE
Posted on Mar 03, 2009
SOURCE: Kenmore washing machine 80 Series 110 20802 990 Will not agitate or spin"
You need to replace the Kenmore Washer Lid Switch. I had the same problem so being lazy I would just push down on the washer's lid and it would push the lid switch further down. making the water drain. after a while I just replaced the lid switch.
Posted on Jun 17, 2011
The agitator is slipping on our Kenmore 80 series toploader. I'm not sure how to remove it.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Look at the section on the Sears site for Agitator, basket and tub.
Assuming that only the top section of the agitator is "slipping, the problem points to the Agitator "Dogs"
See the following for how to replace them.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=8878c06f855a89c90959d53553cf9ab8
If it's not the "Dogs" see the following that has a section on how to remove the agitators and check the splines.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Mar 02, 2010 | Kenmore Washing Machines
Trying to remove spin basket (inner tub) from Washing Machine
See the Sears parts site for washer 82372110.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.82372110
The following may also help.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=146
Jan 25, 2010 | Kenmore 22422 Top Load Washer
My ken,ore 80 series washer agitates ok and seems
Two things to check.
It sounds as if the tub isn't getting full power from the transmission for spinning and/or the pump/hoses are damaged or blocked.
1. Remove the cabinet.
See the following.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=134&osCsid=7777818c689b6ece38ca9884721fffc7
and check the hoses / pump.
2. If they are OK, the problem may point to the Motor Coupler. See the following for how to check it.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135
3. If the pump and Motor Coupler are OK, the problem could point to the clutch.
See the following for how to pull the pump, motor and transmission.
You don't have to remove the tub!!
If the clutch bands are worn, you don't have to replace the entire clutch. Sears / Whirlpool have a band replacement kit, a lot less expensive and easier to install than a new clutch.
Jan 17, 2010 | Kenmore Washing Machines
Series 80 Agitator top dosent work
If the bottom agitates and not the top, the problem is likely the 4 "agitator dogs" designed to allow the top agitator to turn only one way.
I assume that your model number starts with a 110 instead of 100.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.26842692
See the part "Dog, agitator "
Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of the top agitator with a 1/2" square drive.
Remove the drive and lift off the top agitator. Turning it over you should see the 4 "dogs", replace these and the top agitator should turn in one direction only.
Replace the 1/2" drive, the cap and fabric softener unit and the top agitator should work.
Following is an illustrated description of the above.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=0da65cea0e338fe930b1fde153a243f0
Jan 09, 2010 | Kenmore Washing Machines
The upper portion of the agitator (Kenmore Series 80 top load)stopped spinning as if the thread has stripped. What parts need to be replaced?
Basic top load, direct drive Whirlpool / Kenmore washers with two piece agitators use "agitator dogs" to allow the top section of the agitator to turn in one direction only.
These are plastic pieces and over time can wear.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=71493d5cab3d7784ad8aa7cde8e5e5d4
Nov 17, 2009 | Kenmore 24032\24036 Top Load Washer
I have a Kenmore Series 80 washer and the tub
i would check the motor coupler
it sits behind the motor before the transmission
this model
thre piece part that drives the transmission
Oct 15, 2009 | Washing Machines
Kenmore 80 series, model 110-2781690, won't spin or agitate. loud clicking from lower portion of machine. fills & drains ok. transmission failure?
hi,
Unfortunately, it sounds like a transmission/gearcase problem, mainly because you stated the motor would run, but would not agitate or spin.
With the motor removed from the gearcase, try to turn the coupler on the gearcase side one way for many turns, and see if your agitator moves back and forth, then turn the coupler on the gearcase the other way many turns to see if the tub starts to move
thank you,
vijay
Sep 29, 2009 | Kenmore Washing Machines
Kenmore 80 series washer stopped during unbalanced spin cycle
lid switch is broke lever probley broke off or screw holes broke out due to off balance load forcing tub over against switch lever
Apr 29, 2008 | Kenmore 20172 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
2,967 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
