Question about Whirlpool WTW5700S
We've replaced the Invensys timer in our whirlpool washing machine 3 times in the last 3.5 yrs. Should we just buy a new washing machine?
  • Whirlpool Master
  • 3,740 Answers
This may not be what you wish to hear but... I suspect that the reason you have had to change timers is that a user is turning the dial counterclockwise. This will ruin the timer in one fell swoop as it bends over the contacts inside the timer and caused immediate failure. I have seen this in a few homes where the home owner had mentioned that this is the 3rd timer we have changed in as many years. In every one of the cases I asked them to select various cycles as I watched on the OLD timer. All of them at least once turned the timer CCW. Once I explained that they never turn the timer CCW.... the repeated failures stopped. Some people just never knew that it was bad to turn the timer CCW. That may be the case here. So timer rotation is ALWAYS Clockwise to avoid repeated timer changes.
I would not give up on it yet... You have barely reached mid life for the washing machine you own. At roughly $125.00 for the replacement part I can understand your concern.
http://www.appliancepartspros.com/part_details.aspx?part_id=3890467
It is your decision as to where to go from here. As a repair / tech I would not shoot it in the head just yet. I would look into how people are using the machine controls.
Thanks for choosing FixYa.
Kelly
Posted on Sep 28, 2010
Invensys s86
Most likely clogged or worn out diaphragm. Replace valve is only solution. Take your model number and go to your local appliance parts store or go to www.searspartsdirect.com
Sep 25, 2013 | Whirlpool Washing Machines
Trying to replace timer on Kenmore 700 washing machine (model 110.28727200). The existing timer is an Invensys model W10129602. Where can I find replacement or substitute parts?
Here is the timer to order. To remove the knob on the old timer, from the back of the timer there is the knob pin that you push in and it will release the the knob.
The part comes with a 365 day, any part, any reason return policy.
Nov 10, 2012 | Kenmore Washing Machines
I have a Whirlpool Washer (Model: LXR6232EQ0). It will start washing & then stop. After pulling the timer out & pushing back in, the washer resumes operation. This happen 3-4 times per cycle. ...
You are correct in assuming that the timer is going out. It is fairly easy to replace, you simply take the upper back part off of the washer and remove the screws that hold the timer in place and reinstall the new one.
Mar 02, 2011 | Whirlpool Washing Machines
I have a whirlpool washer & need a new timer....how can i find one?
I use RepairClinic.com
http://www.repairclinic.com/Whirlpool-Washing-Machine-Parts
Get model and serial number off nameplate, usually located on back at top of washing machine.
A lot of folks think timer is bad, when problem is another part.
Timers usually last longer than most other parts.
Call their live chat: 1-800-269-2609
Feb 22, 2011 | Whirlpool Hardware & Accessories
I have only had my washer for 3 years and have not paid it off yet. My machine has stopped draining and spinning and showing a F50 error. I have been reading alot of reviews that other people are having...
call wirlpool and demand they replace the water p/p if its only 3 yrs old its there duty under trade law to fix it remember there warrenty covers them but fair trade laws say a washer must last at least five yrs or the company must repair the unit thats why us teachs laugh at peoiple that buy extendid waqrrentys the government covers all goods under law for 5 yrs minimum
Jun 24, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer- when it spins it makes horrible, LOUD, grinding and rubbing noises, yet nothing is leaking and the machine is in balance so it doesn't "travel". What's wrong...
Hello,Most likely this will be the drum bearings.
Bearings normally last quite a long time but some will fail sooner than others. Quite often bearing failure is due to a faulty drum shaft seal which allows a small amount of water through and in to the bearings. The bearings then start to rust, which then accelerates the wear on the bearings.
Replacing the bearings needs well above average DIY skills to do, so unless you feel confident to tackle the job, can get hold of a tech manual, and can get hold of new bearings, it's time to call an engineer for a quote and then draw your own conclusions as to whether it's worth it.
Thanks
May 23, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Timer type
Give your parts distributer your model and serial number and they can get you the proper timer.
Oct 03, 2008 | GE WCCB1030 Top Load Washer
Open Questions:
See all Whirlpool WTW5700S Questions
Whirlpool WTW5700S Logo
618 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
