Question about Bosch Tools & Hardware - Others
Can't pull bit out of chuck. This problem has gotten gradually worse. the bit that is stuck is short - so that it is almost impossible to grasp. Have done all the obvious maneuvers.
  • Bosch Master
  • 12,061 Answers
Spray and soak with a common rust dissolver available from your local automotive place. Let it set overnight. In the morning, invert the drill and clean it with seltzer water (lemon or lime flavored). This cleans off the corrosion. Then, put a few drops of WD40 in there, and crank that baby off. Worked for me in the past... hope it works for you.
Or try this... you MUST be able to get a good grip on the shaft behind the attached chuck . Obtain a very thin generic 11/16 flat wrench then clamp the generic 11/16 wrench in a bench vise, stuck it in between the shaft and the chuck (with the shaft nut resting securely in the wrench jaws), and then use a monster pipe wrench on the *inner* chuck ring (the one with the 3 holes for the chuck key, not the geared ring). After a bit of (literally) wrenching on it with the pipe wrench, it should finally came loose.
Or apply heat and cool do this a couple of times and then it may come free.
Posted on Sep 28, 2010
Dewalt instruction manual
The black thing at the end is the "keyless chuck". Grasp it just behind the silvery tip of the chuck with one hand, and grasp the knurled ring just behind THAT area with the other hand. Twist the "front" hand counterclockwise while you twise the "rear" hand clockwise. That will loosen the chuck so you can change bits.
Aug 06, 2014 | Dewalt Dc987k2 Xrp 18volt 12 Drilldriver...
Hello... I've rented a Bosch 11318 Hammer drill and it did not come with a manual......could you please tell me how to insert the bit. thank you.
You should only need to push the bit in. If that does not work grasp the chuck and pull back towards the handle than insert the bit and release the chuck. You remove the bit by doing the same pulling the chuck back and taking the bit out
May 09, 2011 | Bosch 11318evs 11 Amp Sds Max Demolition...
I have a de Walt 14.4 v XRP drill and cannot for the life of me change the drill bit! cheating Ex husband took the drill i am used to and cannot get this drill bit out! LOL help!
Assuming that the chuck has no gear teeth for a chuck key, put a leather glove on one hand, grasp the outer chuck case with drill set for reverse, and apply power which should loosen the chuck. Normally, you just grasp the outer chuck and turn it in a CW (looking at it from the handle end) direction to loosen. Hope this helps!
Oct 24, 2010 | Garden
How does the chuck go on
You grasp the chuck with the bit end in the palm of your hand, With your fingers pull back the plastic sleeve on the other end. slide the chuck on the shaft. Release the sleeve and turn the chuck until you feel it lock into place.
Aug 28, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
Keyless drill has locked in a closed position with the drill bit
I just put mine in reverse and grasp the chuck with a pair of channel locks. Pull the trigger and hold the channel locks tightly. The chuck will release the bit.
Jun 04, 2010 | Craftsman 3/8" Corded Drill
How to remove bit retainer or chuck from drill
Grasp the chuck and twist the sleeve counter clockwise and pull up.It will come off. To replace the chuck slide it back onto the drill shaft, grasp the chuck collar, twist it counter clockwise and push down on it, it will slid back onto the shaft and lock into place.
Nov 20, 2009 | Bosch 11222EVS 1 1/8" Sds Plus Rotary...
My rattle gun 18V LXT Impact Driver BTD141 has a double ended Philips stuck in it? how do i get it out?
There are a couple of ways to try to free the bit from the drill chuck. But slow and steady is the key, don't hit anything too hard, so as to not damage the chuck in the process, nor break off the bit in the chuck.
You'll need to put the bit into a bench vise and reverse the drill slowly and carefully. Make sure the bit is tightly secured in the vise and that the drill won't spin your hand around and slam it into the bench when you pull the trigger.
As a last resort, you can try tapping the bit sideways, to get it loose. With chuck opened up all the way possible, gently tap the bit sideways. This should also free the bit, but be very careful not to snap the bit off in the chuck, or you'll have a worse situation trying to get a broken bit out of the chuck.
If none of these work, you can attempt to secure the stuck bit in the bench vise and try to tap the drill chuck using a hammer and a flat brass bar resting against the drill chuck, so you don't damage the chuck. Just tap the brass bar to drive the chuck free of the stuck bit. You have to watch the bit in the vise to make certain it's not slipping and that the chuck is getting free.
Hope you find this Very Helful and best regards!
Jul 12, 2009 | Drills
Drill bit Stuck (and then broke off)!
Keyless chucks have two parts (see pictures) when the drill is in operation both parts spin. Assuming you put the drill bit in and tightened the keyless chuck by hand, put on a work glove and grasp the part of the chuck at the front of the drill, grasp the other part and twist the front part anti clockwise.
If this does not work you can hold the front of the chuck and reverse the direction of the motor as if you were unscrewing something, then pull the trigger. If your hand does not grasp the chuck tight enough it will slip, hence the glove. If this does not work you may have to hold the front of the chuck in a vice or with caliper pliers and again the pull the trigger with the drill in reverse.
All this depends on what you used to put the drill bit in with your hand tight or held onto it with something else. Whatever was used should be enough to loosen the chuck
Hope this helps.
If it does let fix ya know.
Cheers
Les
Feb 02, 2009 | Dewalt DW056 18 Volt Cordless Impact...
Bit stuck in Bosch PS20 keyless chuck
These units have only been out for a short while and most are on warranty. Take it to a Bosch Service center in your area and they will replace the front of the unit. Unfortunatly this is a problem with this type of unit. The bit will deform slightly from the impacting action and lock itself in the chuck.
Jan 17, 2009 | Bosch PS20 2 Factory Reconditioned 10.8V...
Drill bit came out, won't go back in. Dewalt 12v XRP
grasp the chuck and put drill in reverse position and pull trigger gently this will open chuck and re-insert bit do same in forward to tighten bit into chuck
Jan 10, 2009 | Dewalt 18 Volt Compact Drill Kit
Tools & Hardware - Others Logo
83 people viewed this question
Top Bosch Tools & Hardware - Others Experts
Awesome12
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Bosch Tool and Hardware - Other Expert? Answer questions, earn points and help others
