Question about Linksys Wireless-G WRT54G Router
Cable modem internet works when directly plugged into desktop, but when run through the router, no connectivity
    Novelist:
  • 108 Answers
Most cable Internet Service Providers (ISP) use a Media Access Control (MAC) Authentication to establish Internet connections for end-users. A MAC address is a unique 48-bit (6-byte) integer that is attached to an Ethernet NIC for each computer. To set-up your Linksys router to a Cable ISP, you have to do MAC Cloning. MAC Cloning is a procedure which enables a router to copy the MAC address of the PC that's registered with the ISP.
To setup a Linksys router with Cable connection you need to perform five steps:
  1. Verifying Internet Connection
  2. Connecting the Devices Together
  3. Checking the Router's LEDs
  4. Configuring a Linksys Router for a Cable Connection
  5. Power Cycling
NOTE: Before proceeding, use the computer that can go online when connected to the modem and follow the steps below.
Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If it is not, contact your ISP. If it can go online, the PC connected to the modem is the one that's registered with the ISP.
cable modem internet works when - kb4682-001_en.png NOTE: The image may vary depending on the computer and modem you're using.
Once an active Internet connection is established through the modem, connect the modem and the computer to the router by following the instructions below.
After ensuring that you have an active Internet connection, connect the modem to the router's Internet port and the computer to any of the four Ethernet ports. For instructions, click here.
After connecting the devices, check the LEDs by following the instructions below.
The Linksys router's front panel will indicate the status of the connection. After connecting the broadband modem to the WAN or Internet port, the computer to an available numbered port and powering on the router check the lights on the front panel of the router. For instructions, click here.
After checking the router's LEDs, configure the router for cable Internet. For instructions, follow the steps below.
kb4682-002_en.png For Telstra Cable internet users, please contact Telstra to confirm if your internet connection is using DHCP or HB (Heart Beat) signal. There should be no other machine running HB client upon doing this procedure.
Step 1:
Access the router's web-based setup page. For instructions, click here.
NOTE
: If you are using Mac to access the router's web-based setup page, click here. If you forgot your IP address, click here. If you forgot your router's password, click here.
Step 2:
When the router's web-based setup page appears, click the drop-down arrow under the Internet Connection Type field and select Automatic Configuration - DHCP.
(a) If you are NOT using Telstra HB, proceed with DHCP setup.
cable modem internet works when - kb4682-003_en.pngi.fixya.net/uploads/images/kb4682-003_en.png" alt="kb4682-003_en.png" class="h_mi" />
NOTE: If you are a Telstra Cable internet user and you're using WRT120N, WRT160N v1, WRT320N or WRT610N, please select Telstra Cable.
(b) If you are using Telstra Cable, proceed with the following setup. Obtain your user name and password from Telstra. Please disable any HB client that might have been previously running on the PC after thcable modem internet works when - kb4682-004_en.pnggured.
kb4682-004_ecable modem internet works when - kb4682-005_en.pngi
Step 3:
Click kb4682-005_en.pngStep 4:
Click MAC Address Clone.
Step 5:
Select Enabled and click Clone My PC's MAC.
Step 6:
Click kb4682-012_en.png.
Step 7:
Click Status. Check the value of the Internet IP Address. If the Internet IP Address has numbers, this means the router has been properly configured. You should now be able to access the Internet. If you're not online, perform a power cycle to synchronize the router with the modem. For instructions, clicable modem internet works when - kb3687-005_en.png//www6.nohold.net/Cisco2/GetArticle.aspx?docid=54c700b23cable modem internet works when - kb3687-006_en.pngad0725_4682.xml&pid=96&converted=0#5" target="_blank" rel="nofollow" >here.
NOTE:
If the Internet IP Address is all zeroes (0.0.0.0) click kb4682-008_en.png first then click kb4682-009_en.png. If the Internet IP Address is still all zeroes (0.0.0.0) perform a power cycle. For instructions, click here.
If the IP Address starts with 192.168.1.xxx or if it has the same first three numbers (octets) as the router's IP address, change the router's LAN IP address to a different LAN segment. For instructions, click here.
Once the router is configured, perform a power cycle. For instructions, follow the steps below.
Power Cycling
Step 1:
Shutdown the computer.
Step 2:
Unplug the router's power cable.
Step 3:
Unplug the Broadband modem's power cable and wait for 30 seconds.
Step 4:
Plug in the Broadband modem's power cable and wait for its lights to appear stable.
Step 5:
Plug in the router's power cable once the modem's lights appear stable.
Step 6:
Power on the computer on and test the Internet connection.
NOTE: If you're not online after performing this procedure, you may need to upgrade the firmware of the router.
Posted on Sep 28, 2010
HAAi
  • 77 Answers
SOURCE: Can't connect via my wireless router to the internet - but my cable modem is fine!
Hi!
Do you know how to check the IP address of your computer?
Maybe you need to reconfigure the router.
Posted on May 05, 2008
SOURCE: Internet Connection
I'm just trying to figure out why I can get an excellant signal, but can't connect to the internet, why?
Posted on Oct 05, 2008
RickOz
  • 145 Answers
SOURCE: Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
Posted on Apr 10, 2009
kakee
  • 1268 Answers
SOURCE: Wireless computers work fine, wired desktop extremely slow
On your old desktop, go to Control Panel > Internet Options > Connections > LAN Settings make sure no check on boxes there. Click OK and Apply. Click on General tab, click on Delete File (delete all offline content), Clear History and Delete Cookies. Click Apply and OK.
Posted on Jun 30, 2009
  • 34 Answers
SOURCE: Belkin 54g Router won't connect to internet.
If you can access the configuration page of your belkin router you have to copy the MAC address of your computer to the router. The router has the capability to clone the MAC address. It's because if you have a cable internet connection the MAC address is registered in the server.
Posted on Jan 06, 2010
No internet when adding switch between modem and router
The router controls and assigns IPs. Configuration goes from ISP modem to router to switch.
Mar 20, 2013 | Zyxel Communications Zyxel GS105B Desktop...
Just installed win 7 and can't get internet on
Can't connect to the Internet using Windows 7 OS.
1. If you haven't already done so, run the Network troubleshooter to see if it can help diagnose and solve your problem.
Open the Network troubleshooter by right-clicking the network icon in the notification area, and then clicking Troubleshoot problems.
2. Make sure that all cables are connected (for example, make sure your modem is connected to a working phone jack or cable connection, either directly or through a router).
3. Restart your modem, and then restart your router. Remove the power cable from the modem and router. After all lights on the device have gone out, wait at least 10 seconds, and then plug the modem and router back in. Some modems have a battery backup that prevents the lights from going out. For this type of modem, press and quickly release the Reset button.
4. Check your router. Because of the new networking features in Windows Vista andWindows 7, some older network routers are not fully compatible with these versions of Windows and can cause problems. You can test your router to see whether it is fully compatible with Windows 7 by running the Internet Connectivity Evaluation Tool. Or, for a list of routers that are compatible with Windows Vista, go to the WindowsCompatibility Center website.
May 03, 2010 | Computers & Internet
Ethernet to router connectivity issue
The correct way to do the connection is by plugging the Desktop to one of the Ethernet ports and any wireless device over the wireless network.
Dec 01, 2009 | Zyxel P660HW-D1 Router
Jun 29, 2009 | Linksys Wireless-G WRT54G Router
Internet no longer working, but internal network is fine.
i agree with all the above.. it's definately clear as mud how the network is designed and or funtioning. The machines connected to the wireless d-link router.. are they via cat5 inthe wired ports or wireless ? is the server the machine thats connecting to the switch and wiress router and modem? i'd say reset all switches modems routers and machines.. shut them all down.. then fire the cable modem, then the wireless router then the desktop switch then the server, the workstations and the one lonely wireless.. run "ipconfig /all" on all machines and if they aren't all sharing common ips and access, provide the results here for further investigation.
May 20, 2009 | Dell Dimension 2400 PC Desktop
Vista desktop won't connect to internet cable modem eithernet
power down cable modem, router, and computer. Connect ethernet cable from modem to router/ and connect ethernet cable from router to PC. Power up cable modem first, after modem shows connectivity, plug in router. After router shows internet connectivity, start computer. Be sure that you LAN card operable
Apr 15, 2009 | Acer Computers & Internet
No internet signal between router and desktop pc.
have you plugged everything in with the modem off and the router off?
have you tried unplugging the linksys for a sec then plug it back in?
also have you checked the pin connection on the plug on both the computer and the router?
what are the lights indicating?
Oct 14, 2008 | Computers & Internet
Router won't log into it's IP address online
It appears to me that you have everything plugged into the desktop PC. This is not the way that it should be done. Plug the cable modem into the wireless router via the Internet/WAN port. Plug your desktop PC into one of the ports numbered 1-4. Now connect to the router via the wireless connection for the router and you should be able to now connect to the internet with your laptop.
If it still does not work, power down everything in this order: Laptop, Desktop, Router, Cable Modem. Bring everthing up in the reverse order (Cable Modem, Router, Desktop, Laptop) waiting for each device to stablize before moving to the next.
Once you get everything working, turn on your wireless security (WPA not WEP) asap to keep your computers and surfing safe, and to keep intruders off your network.
Jul 20, 2008 | NetGear RangeMax WPN824 Router
Connecting a modem and router to my desktop
When you connect all the devices make sure you reset them all after plugging them together. Also use a different ethernet cord and make sure your plugging the Modem into the WAN port on the router. If your still having same problem just let me know.
May 08, 2008 | Linksys Wireless-G WRT54GS Router...
Server not found} NetGear WGR614 Wireless Router doesn't connect me to the internet.
Dear Loud Nouises,
Your router must be connected properly to the cable modem. This must be to the wan port on the router.
Next, the router must be set-up accordingly to recognize the modem's internet connections. Please ask for the IP address.. and other relevant informations from your internet provider.
Set -up your computer using the internet connections wizard on each of your respective computer.
This should work fine if all connections were correctly configured.
Sidlahora
Nov 27, 2007 | NetGear WGR614 Wireless Router
Linksys Wireless-G WRT54G Router Logo
481 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
