How to delete jiaayulx.scr virus? my computer converted all folders in my USB drives into a shortcut folders and cannot be opened.
3 Suggested Answers
SOURCE: folder options no working
Hello Friend..
Today we have a huge database of viruses across the internet. Most common is autorun.inf which directly attack to the folder option. It permanetly disable the folder option. None of a anti-virus have its defination to remove it. So i research for it and find the very good solution for it. Here is the solution.
1. Format your windows Drive which is C:\ Drive.
2. After installation don't install any item include drivers.
3. go to My computer--> Tools--> Folder Option now select the show hidden files.
4. Uncheck next two option Hide extensions for known file types & Hide protected opetating system files (Recommended)
5. Now click on apply and Ok.
6. Now open my computer in explorer mode by simply click on folder button near to search button.
7. select evey drive and delete files named autorun.inf, u.bat, microsoftpowerpoint.exe, recycle bin or $recycle bin.
8. After deleting from every drive just restart your computer and check your drive.
9. Now your computer is ready and free from that stupid viruses.
If you have any trouble in this solution then just contect me on amit_jodhpur2005@yahoo.co.in or atal852002@gmail.com Enjoy with your work and PC.
Posted on Jan 28, 2008
  • 2976 Answers
SOURCE: recycler folder virus
You don't have a virus, you have the folders without an executeable link. Use windows explorer to delete the files you want to get rid of.
Posted on Sep 07, 2009
How to Remove Shortcut Virus on Windows?
Connect the affected USB drive to your computer. When the files on your USB drive have been changed to shortcuts, your files are actually still there in a hidden location. This process will restore the files so that you can see them again.
  • Do not run any of the shortcuts on the USB drive, or you risk spreading the infection.
Determine the drive letter of the USB drive. You'll need to know the drive letter for the USB drive or memory card that has been affected by the virus. The quickest way to find this is to open the "Computer"/"This PC" window. The drive letter for the USB drive will be listed next to the drive label.
  • Press Win+E to open the window on any version of Windows.
  • Click the Folder button in your taskbar to open the window.
  • Click "Computer" in the Start menu if you're using Windows 7 or Vista.
Open the Command Prompt. You'll be performing the fix using a few quick Command Prompt commands. The process for opening the Command Prompt varies depending on the version of Windows you are using:
  • Any version - Press Win+R and type "cmd" to launch the Command Prompt.
  • Windows 8 and newer - Right-click the Windows button and select "Command Prompt."
  • Windows 7 and older - Open the Start menu and select "Command Prompt."
Type .attrib -h -r -s /s /d X:\*.*and press? Enter. Replace Xwith your USB drive's letter. For example, if your USB drive's letter is E, typeattrib -h -r -s /s /d E:\*.* and press ? Enter.[1]
  • This will unhide the files, remove any read-only attributes, and remove the shortcuts.
  • The process may take a while to complete, depending on how much data is on the USB drive.
Open the unnamed folder created on your USB drive. This folder will contain all of the data that was previously hidden by the infection.
26319209-bxzhjmonsmllydp0qa2riq2g-2-20.jpg Copy the recovered data to a safe location on your computer. This is a temporary location while you finish cleaning the drive. You can create a folder on your desktop to hold the files for now. Just drag the files from your USB drive to whichever folder you choose.
  • It may take a while to copy large amounts of data.
Right-click on your drive in "Computer"/"This PC" and select "Format." This will open the Format window.
  • The formatting process will completely erase the drive, so make sure that you've copied your data off of it first.
Uncheck "Quick Format" and click "Start." Unchecking "Quick Format" will scan for and remove the infection on the USB drive. The format process will likely take a while to complete. 26319209-bxzhjmonsmllydp0qa2riq2g-2-44.jpg
Oct 20, 2016 | Microsoft Computers & Internet
Hidden Folder virus in PC not in USB
I have faced same problem. Shortcuts everywhere.
Not once, many times.
I tried many solutions.
Shortcut Virus Remover is the best solution I found.
A 100% free simple application.
You can download it from this link - Shortcut Virus Remover
Place it in your pen drive and double click to run.
Press Enter to confirm its process.
That is all.
Shortcuts will remove and your data will be back in a second.
Jul 20, 2013 | Microsoft Security Essentials
ALL FOLDERS ON MY USB HAVE BEEN CHANGED TO SHORT CUTS
This is usually a signal that a virus is at work. Check that your computer has been checked and is clear. Then check your thumb drives-all of them including your external hard drives.
Apr 15, 2013 | Dane-Elec DaneElec 4GB USB Drive Red Hard...
All folders on usb flash memory card changed to be shortcuts , I can't display their contents directly , there is folder called recycler contain an index for the data inside my folders ... i want...
Hello there, sadly you have been attacked by a virus named - RECYCLER. This is a very common virus, I also had an encounter with it recently. What zou are going to do in order to delete is:
1.Look for all folders with shortcut arrow.
2.Right click then properties.
3. in the field TARGET delete everything before path to your usb (before eg. F:/Kobac usb).
4.Save settings. Open folder and copy it to harddrive
5. Do this for all folders.
6. When zou finish coping your data, format your USB.
7. To Format fo to My Computer, right click on USB and format.
8. Copy files from harddrive to your USB back
9. Enjoy!
Good luck, Kobac
May 24, 2011 | Computers & Internet
I installed vista sp 1 in my hp laptop and philips external harddrive was also plugged in and when i finished installing vista sp1 all folders showed E:\liuuv.scr.. i cant open any folders... all folders...
it seems viruses on your hard drive and the extension of viruses is .scr (it hides all files). Try this tips to un hide your files, you must show the hiden files on you pc by following these steps
1.open my computer
2. click on tools
3. click on folder option
4. on the advance setting find the category of hidden files and folder
5.
show choose hidden files and folder
6. click ok
the second step click run (you can find by left click start button )
type cmd
you will be in a command prompt and it will be C:\\
then type the path of your hard drive (for example F:)
after the path show your drive
(for example F:) type attrib -s -h -r -a /s /d
wait until the process finish
now you can see the original file of you with extension file folder not .exe or .scr
you can delete the file with extension .exe and .scr by one left click to the file and press shift and delete button on your keyboard.
don't forget to scan your drive with anti virus
May 23, 2011 | Philips Computers & Internet
I HAD Western Digital My Book Essential 1TB External USB 2.0 Hard Drive ON M PC AND I CONECT WESTERN DIGITAL MY PASSPORT AND RUN THE AUTO FROM THIS SOMETHING LIKE WD SMART.... AND NOW MY Western Digital My...
Your WD HDD have been attacted by viruses for your computer or outside computer where you used it last. Make sure that you have an up to date antivirus software, scan your computer or the external hard drive, explore your computer, go to tools - folder options under view files & folders select show hidden files and folders apply and ok it.
May 18, 2011 | Western Digital My Book Essential 1TB...
4 gb usb creating shortcuts folders
I think you are referring,that there are folders and shortcuts which are not created by you and its generating automatically?
if this so, Its an action of a virus. - Run full system scan using a up-to-date virus scanner.
Mar 04, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
My all folder in flash d change to be shortcut
Is this the Problem???
Don't format your Flash Drive.
Your data is still there.
Use Shortcut Virus Remover.
  • 100% free
  • Setup file to download 1.1 Mb
  • Installed file 2 Kb
It will recover your all data.
DOWNLOAD !!
http://shortcutvirusremover.blogspot.com
Oct 11, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
My folder's turned into 1 KB Shortcuts on my 500 GB WD Hard Drive
I believe this is a trojan. I have the same problem. I found by going into Properties-shortcut tab- you have to rename the shortcut to the correct shortcut. You should notice some wierd file name like "keuiku.scr." Simply rename it to the original name and it works for me.
Jul 18, 2010 | Western Digital My Book Essential Edition...
Computers & Internet Logo
177 people viewed this question
David Payne
David Payne
