Question about Health & Beauty
I have a M&S MC350A. Problem is that the door chime does not ring even after I changed the door unit to a new one. We can speak through door listen button. Only problem is the door chime.
  • 944 Answers
Have you tries resetting the unit:?If there is any corrupted setting will be erased in this process.
Try unplugging the unit for 60 minutes, then plug back in and try it again. This will reset the processor and hopefully the unit will operate normally. Check all the speaker wiring for shorts, make sure they're also not touching the chassis of the receiver.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 28, 2010
My bell ring everytime my next door neighbor's bell ring & even the neighbor three doors down. What is up with that?
They're all set to seeing frequency you need to go into your owners manual and check how to change wireless frequency
May 12, 2014 | Heath Zenith SL-6144 Specialty Series,...
Phantom bell rings on Siemens wirreless door bell chime jsjs-204, I do not have instructions
You may need to change the frequency of the chime. In this model, you need to remove the batteries from the receiver unit and wait for a while. Then replace the batteries. The doorbell unit should automatically set itself to a different frequency once you press the button, which will(hopefully) solve the problem.
It seems impossible to find the instruction manual for the doorbell. But see http://oddsnsods.net/blog/?p=68 who had a similar problem with a different Siemens model, which works on the same principles. (I can't seem to be able to remove the battery from the door bell unit on the jsjs204, but it reset itself after changing the batteries in the receiver).
Nov 01, 2011 | Desa International White Wireless Plug In...
How to change ring tone? Model #RC8233R Carlton wireless door chime
Mary, there is a small button on the face of the face of the pusher. With the unit plugged in, push that little button and it will play the next available ring tone. When you find one that you want to use, simply stop and that one will be what you hear when someone comes to the door.
Aug 20, 2010 | Audio Players & Recorders
M & S Systems MC350A - intercom dial if rotated will squeal
no, but I have exactly the same issue - did the original poster get a solution?
Jan 18, 2010 | Audio Players & Recorders
M&S Systems, #MC350A, central intercom system, malfunctioning
I'm having the same problem. I think LIST means it is in LISTen mode, listening to the outside door station. Why it is doing that is unclear.
Oct 18, 2009 | Audio Players & Recorders
I have a byron SX85R plug in wireless door bell, i need to change the frequency/ or code, keep false alarming, cant find the instructions , also with the alarm, is a batterie alarm no. SX81R, which came...
From User Guide: Interference from a similar unit operating nearby: a) simply remove the batteries from the push button and door chime units and rest for 10 seconds, this will erase memory b) Insert the batteries into the push button and door chime units, the door chime unit will give 2-beeps to indicate that it is ready for the new registration code. Press the Push Button once, it will generate a new operation code randomly and send a wireless ignal to the door chime unit and it will sound to indicate that new operation code is registered and memorised.
(Note with this unit SX85R the door chime is mains powered, not battery powered, but above instructions are the same)
Oct 10, 2009 | Bell Cocoon Child Carrier
Wireless doorbell rings by itself
Doorbell button is sticking or slightly pressed in. Check to see if cover is installed correctly. It may be on on one side.
Aug 31, 2009 | Desa International White Wireless Plug In...
I have two door chimes with the same frequemcy, but different codes. I need to place the chimes in different rooms as I am hard of hearing. How do I match both codes so that they ring at the same time when...
You need to change the pin configuration in both the remote buttons to match each other, (as well as the bell unit) just make sure they match on both bell units. Also, since one works just use that configuration and change the button pin configuration that does not work to the button that does on the other button unit.
Mar 03, 2009 | Desa International White Wireless Plug In...
We lost are chime
Check to make sure you don't have anything that would impede the connection at the battery terminal
Jan 18, 2009 | Desa International White Wireless Plug In...
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
