Question about NAD T973 Amplifier
Nad t973 Help! My nad t973 blew one of its 22000uf electrolytic capacitors the other week. I am having a lot of trouble locating a replacement. Can anyone please advise me on where i may find the replacement. I notice one of the 15000uf capacitors is showing signs of failure so would like to replace all of the filter capacitors. There are two of each of 22,000 and 15,000 both 80 volt and rated at 105 degrees. They are also both 35mm diameter.
  • sparklessd May 26, 2008
    Thanks for your advice but the capacitance values are correct. They are the ripple filter capacitors used on the power supply directly after the full-wave bridge rectifier. The 22,000uf capacitor actually exploded and the 15,000uf capacitor is swollen- a clascis sympton of a failing electrolytic.
    I will try the supplier you suggested and again thanks for trying...
I have finally repaired the NAD T973 by a fair modification. Both 22,000uf electrolytic capacitors have been replaced by Mundorf Mlytic HC high current electrolytic. This involved relocating the relay power supply board to the side of the Torrid transformer. Then relocating the Torrid transformer slightly to the left of it's original position. The existing 15,000uf capacitor relocated to the RHS of the lower 15,000uf Capacitor. This gives sufficent room for the very large Mundorf capacitors to be mounted into the amp. One is mounted onto RHS of transformer enclosure and the other to the front panel. The caps are then cabled to the associated copper bus pads.
The result is an awsome improvement to the lower frequencies and mids. The highs seem unchanged. The quality of the Mundorf caps exceeds the original NAD caps and are rated at 100volt.
They are expensive, however, at $ 100 Australian each.
With an amplifier of this quality it worked out cheaper than the $670.00 Aus. quoted by an authorised NAD dealer.
Posted on Jun 19, 2008
  • Tony Numan Aug 07, 2013
    Hello there! I am having the same problem with capacitor 22,000uf, 80v. I would like to ask you why you had to replace four of them instead 2 of 22,000uf, 100v only. Thanks! Tony
  • Donal Kavanagh Sep 19, 2013
    Hi Tony. I didn't have to replace all four capacitors but did as noticed the 15,000uf capacitors were swollen and showing signs of failure. I didn't want to risk futher damage to other components. It is now 5 years since I did this repair and the amp hasn't missed a beat. It is also used daily too, so I am a very happy chappy....
I done a lot of electronic repairs over the past 30 years or so. This is something I haven't seen very much of. I wonder if
it might have been run on too high a mains voltage or something. You should check other parts like rectifiers and
output transistors also. There is Mouser, another one is
MCMElectronics, Digikey perhaps. Mouser offered free shipping
and good prices along with most things in stock the last time
I used them. I have no affiliation, just a customer. That's a good
amp, it should be worth fixing. Good luck with it.
Posted on May 26, 2008
Well, the values are much more likely, 2200 and 1500 microfarad, you might check on how many zeros there really are. Also, how do you know they are failing?
It is likely they are not failing unless
they are much older than 30 years. Sources of parts include
Mouser Electronics (www.mouser.com). There are many
sources. Knowing the correct value of the part, of course,
helps significantly. I think you might be off by a zero.
Transistors and diodes are a more likely suspect of failure. Even
these parts are quite reliable unless overloaded, then they tend to short circuit.
Nad t 973 repair manuel
Try http://hifiengine.com/
Feb 15, 2014 | NAD T973 Amplifier
I get no sound from my nad t175 preamp connected to a nad t973 (7 ch.) regardless of the media - rca, hdmi, et al. The fuse in the amp is fine, all the lights are working. Regarding the t175 i can see...
Possible that the amplifier has tripped and so gone to a protection mode. Remove power for few hours, press down all panel switches to drain off voltage from the processor. Also check for any short on the speakers before it is powered on.
Mar 13, 2012 | Audio Players & Recorders
The left speaker channel on my NAD T761 receiver is very weak. I can hear music coming out, but very soft and cracking... Please help me out!
Try to swap the input connector, Hook up the right to left input and then the left to right input. If the symptoms is still there then you have a faulty output IC on the left channel. This is not DIY and I've advice you to send it to repair shop to isolate the problem. Hope that you have only a dry joints on that area.
Thanks for using fixya.
Jan 19, 2011 | NAD T761 Receiver
NAD S300 Amplifer humming
You have either got a bad earth connection, or possibily there's a capacitor failed.
If you can't find a dodgy conection, I would replace the large Electrolytic Capacitors in the power section, they are used to take out 50hz hum in the mains electric, when they go you get that hum coming into your system.
Nov 15, 2009 | NAD S300 Amplifier
Myc370amp turns its self about 15seconds after turn on
Replace 3 capacitors on the protect printboard. (located near the outpt terminals) 50V electrolyt: 4,7uF, 47uf and 10uF. And move the big diode to the back of the printboard (the heat from the diode dries out the capacitors)
Work in 9/10 times ;)
Aug 12, 2009 | NAD C370 2-Channel Amplifier
NAD T973 amp had noise, overheated, and then blew fuse
Hi, Very unlikely your repair of the RCA caused any damaged as preamp shouldn't cause big issues in the amp and would say you right that the problem existed already. The resistor is 100 ohm 5% but there is almost definitely blown outputs to have caused it. Most electronic places should be fine to test advise and repair. Would suggest outputs and drivers, but unfortunately not always that simple. Best of luck
Jul 10, 2009 | Audio Players & Recorders
NAD C270 amp won't switch from red power/protection to green.
The AH may denote "slo-blo" style as opposed to Fast-acting
A fast-acting fuse will look like a single strand of wire ( maybe wiggly looking) ..A Slo-blo will have an element in it and a spring
Apr 11, 2009 | NAD C270 2-Channel Amplifier
Blown Mains Fuse
You should repleace the old transformer with the new one
Jun 13, 2008 | NAD C370 2-Channel Amplifier
Grounding noise
Pull bottom panel and get some canned air and spray around circuit board .May have a shorted capacitor to ground.Might have to use repair directory on this site.
Nov 18, 2007 | NAD T973 Amplifier
NAD T973 Amplifier Logo
817 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
