Question about Sony 2GB Memory Stick PRO Duo Memory Card
Importing data from stick to computer - deleting data on stick
I have a 2GB Sony Memory Stick pro Duo which I used in my Sony Camera. I placed the stick into the adapter and in the appropriate slot in my 4-n-1 HP copier scanner printer fax. The pictures have been imported in my picture file on the computer. However when I place the stick into the digital camera I get an "out of memory" message. Is the data deletable and the stick reusable? What should I do?
    Problem Solver:
  • 41 Answers
Yeah, all you have to do is delete all the pictures on the card. It's easiest to do on your computer, not the camera. Just put the memory stick back into your computer and find all the pictures and select and delete them. If you've already transfered them to your computer then don't worry about it. If you delete the photos off the stick, they will NOT be deleted from your computer so just go ahead and do it.
Posted on May 24, 2008
Camera keeps telling me to reinsert the memory card. I've tried to new cards. When I put the memory card I was replacing because it is full, it goes back into the camera just fine.
As a last resort you could copy the full card to a computer and then delete the pictures on the card and use that again.
Here is the error list from the camera manual.
This is all I can suggest from here.
"Reinsert the Memory Stick Error"
Insert the "Memory Stick Duo" correctly.
The inserted "Memory Stick Duo"cannot be used in your camera
(See below).
The "Memory Stick Duo" is damaged.
The terminal section of the "Memory Stick Duo" is dirty
Compatible cards.
Memory Stick Duo (without MagicGate)
Memory Stick Duo (with MagicGate) *1 *2
MagicGate Memory Stick Duo *1
Memory Stick PRO Duo *1 *2
NOT compatible
Memory Stick (without MagicGate)
Memory Stick (with MagicGate)
Memory Stick PRO
Some Memory Stick Duo have a write protect switch on the back.
You cannot record, edit or delete images if you
slide the write-protect switch to LOCK with a
fine-tipped object
*1
"Memory Stick Duo", "MagicGate Memory
Stick Duo" and "Memory Stick PRO Duo" are
equipped with MagicGate functions.
MagicGate is copyright protection technology
that uses encryption technology. Data
recording/playback th
at requires MagicGate
functions cannot be performed with this
camera.
*2
Supports high-speed data transfer using a
parallel interface.
Oct 12, 2014 | Sony Cybershot S650 Digital Camera
Bought used camera Sony Cyber Shot Model DSC-P32. What Memory Stick do I need?
You can use Memory Stick standard, pro or pro duo up to 2GB with the Camera.
    A dedicated adapter (MSAC-M2) must be attached to use Memory Stick Duo™ or MagicGate Memory Stick Duo media.
I have provided the Memory Stick compatibility chart for your reference.
http://esupport.sony.com/US/perl/support-info.pl?&info_id=12&mdl=DSCP32
Feb 09, 2011 | Sony Cyber-Shot DSC-P72 Digital Camera
MY memory stick can be seen and read in my pc but doesnt work on my psp
  • Flash Storage:
  • Memory Stick PRO Duo Expansion Slot pspphatmodelnumber.gif pspslimmodelnumber.gif pspbritemodelnumber.gif
All flash storage, including Memory Sticks and internal flash, uses the FAT32 file system. http://us.playstation.com/support/answer/index.htm?a_id=1055
The above shows how to format the Memory Stick PRO Duo in the PSP so the correct file structure will be shown.
Be sure to back up any data on the Memory Stick PRO Duo before doing this as all data will be lost on the Memory Stick PRO Duo device.
Aug 06, 2010 | Sony Memory Stick PRO Duo (2GB) for PSP
I deleted Photos from my 2G Memory Stick Duo on my computer, now the camera says there are no images but has only 100mb memory space available
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format Memory Stick Duo
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Jan 25, 2010 | Sony 2GB Memory Stick PRO Duo Memory Card
I have a Memory Stick Pro Duo 8GB will not open on my computer or camera..was working then quit. Advice please
Problem for Sony Memory Stick PRO Duo (2GB) for PSP I have a Memory Stick Pro Duo 2GB will not open on pc &also not formated
Jan 02, 2010 | Sony Memory Stick PRO Duo (2GB) for PSP
2gb stick is the pits for me...
check your pc because your pc occur a risk of virus change your antivirus then format your sony pro duo 2gb.
ok
Jul 30, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
Memory Stick Pro Duo says it's full when not - photos to iMac
move the auto install file then reformat the flash drive as fat.
Apr 06, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
Memory stick pro duo won't record pictures
stick in computer and reformat the memory stick but dont let comp add anything to it
Dec 06, 2008 | Sony 2GB Memory Stick PRO Duo Memory Card
Format error
Format memory stick, if no data on it.
If there is data on memory stick, copy it on PC using any good card reader.
May 31, 2008 | Sony Cyber-shot DSC-W35 Digital Camera
Sony 2GB Memory Stick PRO Duo Memory Card Logo
191 people viewed this question
Top Sony Electronics - Others Experts
Sandy Moore
Sandy Moore
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
