Question about Maytag (MFI2568AEW) Bottom Freezer French Door Refrigerator
CAN THE ENTIRE ICE MAKER BE REPLACED ON A MAYTAG MFI2568AEW MODEL REFRIGERATOR WITH BOTTOM FRENCH DOOR? THIS INCLUDES THE PORTION WITH TABS TO HOLD THE COVER IN PLACE.
  • Maytag Master
  • 1,606 Answers
Yes it can . Part # Y13068002 . It runs about $ 120.00 .
Posted on Sep 28, 2010
Water will not dispense.
have you try replacing the water filter if that does not help check your water solenoid valve.
Feb 22, 2015 | Maytag (MFI2568AEW) Bottom Freezer French...
Is there a filter behind my ice drawer in MFI2568AEW refridgerator
yes there should be but don't try to fix it yourself. you will create yourself a lot of problems. get it fixed from a white goods repairer
Jan 28, 2014 | Maytag (MFI2568AEW) Bottom Freezer French...
How do you disconnect the wire harness to remove the ice maker from the fridge mfi2568aew?
on left hand side of track you will find a cover with a slot in it. stick a screwdriver in slot and pop off cover. there you will a gang plug. unplug and remove ice maker assembly. also there is a tech sheet under freezer and behind grill if this helps
Aug 07, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
I have a Maytag MFI2568AEW refrig. and the ice maker is not filling up. I checked the dual water valve and it is not getting power to open the solenoid valve with the ice maker switch on and the ice bin...
On typical ice makers that signal comes from within the ice maker. It sends a signal from the ice makers thermostat and the ice maker begins to pre-heat the ice cube slots and the ice rake begins turning to push the ice out of the slot's and into the ice bin. The last function is to refill the water with a signal to the dual water control valve that last about 7.5 seconds. Once the ice maker senses the water is frozen again it begins this cycle again. Here is a refrigerator parts PDF for your model=> MFI2568AEW and on page 10 you will see part=> 627985 Pin Style Icemaker Thermostat
Adhesive - Alumilastic (Cement)
That is just silicone rubber you can also get locally. If you have any other questions please let me know, Thanks, Sea Breeze
Y13068002 or Repair Clinic 1266731 Ice Maker Assembly
Feb 17, 2011 | Maytag (MFI2568AEW) Bottom Freezer French...
Icemaker isnt making ice but the water is coming out fine.
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Aug 26, 2010 | Maytag (MFI2568AEW) Bottom Freezer French...
Ice maker does not shut off makes ice rill jammed then water goes everywhere
It sounds like you have a malfunctioning ice maker that could lead to future problems. The start device on some models of refridgerator for maytag and whirlpool have been recalled. If your appliance was manufactured in the last 5-10 years you may be having an issue with this component. Mine recently caught on fire at this device that is located near the compressor. If you would like to be a part of the petition for a recall on this appliance contact me at jboooor@hotmail.com
Jun 08, 2010 | Maytag (MFI2568AEW) Bottom Freezer French...
Maytag refrig (french door) water and ice on door stopped working at the same time.
1) Electric Water valve check up.
2) Water/Ice dispenser control check up
3) frozen plastic pipe inside door or/and chilled water container frozen
4) old water filter (clogged)
Dec 07, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Maytag mfd2561 water dispencer and ice maker issues
ther first refrig id have to see for better idea of problem but hte second with the flaps open and closing is going to need a high voltage board part num(12920710)---thats the part number i get wehn i look it up with the model MFI2568AEW. dont know where you got 12002608(that to is a h.v. board. which ever itssan easy enough repair to do yourself, its mounted on the rear of refrig and comes with programming instructions in the box
Mar 12, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Maytag (MFI2568AEW) Bottom Freezer French Door Refrigerator Logo
265 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
