Question about GPS
Downloaded webupdate, 750 unit will not power up. comes on and immediaely goes blank. appears to be locked
How do i download cameras
Posted on May 24, 2008
I have a Hisense led tv model F39V77C.
Yeah, replace the set since it appears to be trashed. But if you have a few bucks lying around you might want to try replacing the unit's power supply to see if that resolves the many issues you have.
Jan 03, 2017 | Hisense Televison & Video
When i switch on its starts then goes off on its own what can be the problem
Same problem with me, i turn Garmin Dakota10 on and them after the Garmin show up he goes off... i made what JS424 said and worked 100%!
JS424 said "I found out what the problem is with the GPS. I had the same problem and searched for solutions. Your dakota needs an update. Very easy, took me 10 min. Goto Garmin,com and download webupdate. Plug in your dakota and power on. click on check for updates in webupdate. It will search and find your GPS. Follow all the promps and leave plugged in until completely done. After update installed and you power unit you will see the GPS downloading the update. After that your good 2 go. I just powered my dakota up 12 times and comes right on. Good Luck!!!" Maybe solve your problem too
Aug 05, 2012 | Garmin Dakota 10 Handheld GPS Receiver
2002 Honda VT 750 C2 Shadow no lights come on when the ignition switch is turned on
Hi, Gary if some or all of your instrument cluster goes dark/blank immediately upon startup or a few minutes later riding down the road the usual suspects are:
1. Blown instrument fuse.
2. A bad ground in the instrument circuit.
3. Faulty wiring before or after the fuse.
4. Faulty wiring or connector between the fuse and the instrument cluster.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
VT 750 has no electrical power
Honda shadow fuse box
Honda 1998 VT750C Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda VT750C Owner Manual
Nov 10, 2011 | 2002 Honda VT 750 C2 Shadow
When i turn my nuvi on, the screen goes blank and says "press dot"
Keep pressing the dot, its in calibration mode....
if you need to re-calibrate it this is how...
Turn unit off then back on
Slide Power Key to the right ( lock )
Hold your finger on the screen for 30 seconds until the calibration screen appears
Follow on screen instructions
( this may be where you see more dots)
Oct 30, 2010 | Garmin nuvi 255W GPS Receiver
Reloading map Screen blank
A Garmin Nuvi 1300 that won't start, or is acting erratically is symptomatic of having corrupt firmware.
To correct this, I recommend backing up your favorites, clearing all user data, and if it still is stuck, then updating your Nuvi firmware.
Follow these three steps to take to get your Garmin Nuvi 1300 running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_______________________________________
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
Garmin Nuvi 1300 Webupdate
May 04, 2010 | Garmin nuvi 1300 Car GPS Receiver
Sometimes the screen goes blank and after 5 -10 min will let you turn the unit back on
A Garmin Nuvi 1300 that won't start, freezes on 'loading maps,' or is acting erratically is symptomatic of having corrupt firmware.
I hope that helps.
Feb 21, 2010 | Garmin nuvi 1300 Car GPS Receiver
Tv goes blank while viewing
It seems that your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done. It is that re-starting that gives it away, this is a typical switchmode Power Supply problem.
Jan 24, 2010 | Televison & Video
When I turn on my Nuvi 1300 the Garmin logo appears. But after that, nothing happens. It appears that the unit freezes up Thanks, Curtis
A Garmin Nuvi 1300 that won't start, freezes, or is acting erratically is symptomatic of having corrupt firmware.
I hope that helps.
Jan 06, 2010 | Garmin nuvi 1300 Car GPS Receiver
IBM r40e startup problem
press the power button continously while powering on .
check batteries is working or not put the power adapter and start
otherwise call me for better try 9440346646
Mar 11, 2008 | CMB T43 750 Notebook
GPS Logo
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
