Question about Frigidaire FTF530FS Front Load Washer
Good day...i have a 2 yr old electrolux ftf530fs1 washer and i am begining to notice a clunking noise as the washer is coming to a slow down after spinning and also as it starts to spin again (not final spin mode) The clunking noise lasts only 3 to 5 revolutions during both slowing and acceleration of spin cycle.. could it be out of balance? Am I doing damage if I continue using the washer? If it is out of balance, can I reset it myself? Other than the clunking noises, Perhaps maybe 70% of the time, not always, it works great!! Thank you for your time and much appreciated
  • 878 Answers
SOURCE: 5 yr old washer is leaking
Ellbee, remove the two screws at the bottom of the front panel and lift it towards you. Two clips on the top that hold it will release. You can now get a good look at the pump. back.
Posted on Sep 19, 2006
  • 213 Answers
SOURCE: Frigidaire top-load washer Loud noise during spin
its either the upper spin bearing or lower spin bearing. the upper can be replaced by itself but the lower requires the transmission the be replaced
Posted on Nov 20, 2007
  • 903 Answers
SOURCE: noise when ge washer put in spin mode
this could be one of two problems.
The first which is fairly cheap to repair would be to check the carbon brushes in the motor, they may need replacing, especially if your washing comes out wetter then it should.
The second is the bearings on the drum which is more expensive to replace and would need to be done by an engineer.
Posted on Nov 16, 2008
SOURCE: Clunking noise and vibration during final spin cycle
For all those who say they recently bought the machine, the cause of the machine "walking across the floor" and vibrating violently is the packaging bolts on the back of the machine that were supposed to be removed when the machine was installed (why it says remove packaging bolts in the installation manual). These packaging bolts hold the suspension steady and firm during shipping but MUST be removed before operating the machine. When these packaging bolts (I think there are four total, some up to 6 inches long penetrate the rear of the machine) are removed, they allow the suspesion to absorb the vibration.
Posted on May 25, 2009
  • 143 Answers
SOURCE: I am getting a vibrating noise from my washer
It sounds like you could have multiple issues but a possible cause of the vibrating right before the final spin is a broken shock absorber if one or both are gone it will throw off the center of gravity inside the machine and allow it to move freely and at high speed or even low speed this is not good. part number for both shocks is 134560400. If your machine just stops before the spin cycle and only drains, you could have a faulty door switch. the washer will not spin for safety reasons if this is gone. part number for the door lock switch is 131763245. as well the striker that hits this door switch can be broken and sometime pieces will be left inside the mechanism. part number for the striker is 134456640. The last cause of your washer not spinning could be a motor speed control board, if this is faulty, the motor will not receive the proper amperage to send the motor into spin cycle. speed control board part number is 134409904. Hope this helps.
Posted on Oct 12, 2009
sounds to me to be the programmer (mine went down last week) i bought a new machine as the part was a joke cost wise. if its old your probably find that other things will go wrong soon. now i have a fresh 3 yr warranty. would advise the same for you
Mar 08, 2014 | Maytag Neptune MAH5500B Front Load Washer
Strong Odor, almost organic smelling, coming from my Fridgidaire Energy Star stacked Front Load Washing Machine, 5 cycle, Heavy Duty Model# FTF530FS1, Serial # XC90201067. It is in the townhouse that we...
This smell usually comes from items caught in the hose. If you can remove the bottom front panel, (usually 2 screws holding this down) then you will see a rubber acordian piece attached to the water pump. If you remove and clean this the smell should not remian. I just removed mine and found many coins and a huge ball of stinky lint, hence the smell. Good Luck!
Jul 21, 2011 | Frigidaire FTF530FS Front Load Washer
Clunking/thumping with spin cycle, reduces as spin speed increase
It's hard to tell without looking at the washer. But my first response would be that the transmission is wearing out. Inside the plastic cover for the adgitator is a metal drive stem. This assembly has a pulley on the bottom where your motor attaches to; inside the bottom of your washer. It is quite common after many years that these go bad. Have you ever noticed unexplained grease or other stains on your clothes after they came out of the wash?
Apr 22, 2010 | Maytag Washing Machines
Rear end
clunking or grinding noises, wont accelerate to full potential,
May 07, 2009 | 2001 Ford Ranger Regular Cab
Hearing clunk noises after going over bumps on the road..
Check the front struts ( shock absorber ) If original or very old, they are doing no good. Also check the front TORSION BAR rubber bushings. In low temps will groan and creak, on up and down motions.
Apr 21, 2009 | 1995 Pontiac Sunfire
It sounds like a spn down noise. I would check to see if the brake spring was changed when the brake and stator was. They had some problems with weak springs.
Apr 24, 2008 | Washing Machines
Loud cliunking noise in beginning of spin then won't spin
get a flashlight and see if a foreign object has fallen down through one of the tub holes and is jamming the tub you have to look real close
Jan 11, 2008 | GE WJSE3110A Top Load Washer
Frigidaire FTF530FS Front Load Washer Logo
44 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
