Question about Sony BRAVIA KDL-52W3000 52 in. LCD Television
Power light comes on for 2-4 sec, and then jumps to standby.
  • 130 Answers
Hi
first you have to check for blinking lights on front panel it goes from 2 to 9 that will indicate the source of the problem if no blinking the power suply board is defective
Posted on Sep 28, 2010
PS3 wont power up
try another outlet if the light still will not turn green you will need to contact sony,
if the light does turn green let me know and we will get this fixed
Dec 24, 2011 | Sony Playstation 3 (PS3) Console
The SRS light will go off. Tell how to turn it off.
Hi, you cannot turn it off rather you have to reset it by following the instruction below...
  1. Turn ignition switch off, remove service connector cover.
  2. Connect (jump) the MES (Memory Erase Signal) connector (this is 2 pin connector wrapped on yellow plugged in the front of the under dash fuse box).
  3. Turn ignition switch on.
  4. SRS light will come on for 6 secs then go out, remove the jumper within 4 secs after the light goes out..
  5. The SRS light will come on again, reconnect the jumper within 4 secs after the light has come on.
  6. The SRS light will go off, remove the jumper with in 4 secs after the light has gone off.
  7. The SRS light will blink 2 times indicating the memory is reset.
  8. Turn the ignition switch to off and wait for 10 seconds.
May 25, 2011 | 1994 Honda Civic
The picture comes for 2 secs on the screen and immediately goes to stand by and red LED Sony bravia standby mode blinks 8 times
the picture comes for 2 secs on the screen and immediately goes to stand by and red LED Sony bravia standby mode blinks 8 times
Nov 19, 2010 | Televison & Video
Ps2 does not come off standby!
The problem is with your power flex and it needs to be changed. i advise that to avoid this occurrence you give your console time to rest.
Dec 23, 2009 | Sony PlayStation 2 Slimline Console
My Toshiba 32wlt58 wont start up. The standby light works and it appears to have power but I do not have the remote, and cannot work out how to start it up. I have tried te power button at the top but only...
it problem on power supply its demage may be some of components are demage such as capacitor or rectifire demage or mosfac please you go to a service center and repear it by a good technician in your area.
Nov 22, 2009 | Toshiba 32WLT58 32 in. LCD Television
HELLO I HAVE A SONY 40XBR800 TV. WHEN I POWER THE TV ON THE STAND BY LIGHT STARTS BLINKING AND THE TV DOES NOT COME ON
My Sony XBR800 won't start and the standby light blinks 7 times with a 3 sec. interval before blinking again.
Aug 30, 2009 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
My sony tv will not stay on
If you replace the lamp and need to reset the Lamp Timer Reset procedure is: With The Set In Standby Press Display, 5, Vol Up, Power on the remote control Press Jump 3. Or, To Display The Lamp Time Press 2 Nine Times. To Reset Press 3, Mute, Enter. One of these should work on your model. Make sure you replace the bulb first. There is a possibility that the ballast could be damaged by a defective bulb as well.
Jan 18, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
TX-51GF85H
Did you every get a solution to your problem?
Dec 21, 2006 | Panasonic PT-51G63 51" Rear Projection...
Sony BRAVIA KDL-52W3000 52 in. LCD Television Logo
229 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
