Question about NetGear DG834G Router
Netgear DG834G Router
I have 4 computers either with wireless or LAN connectivity to the netgear DG834 wireless/router and for some unknown reason some programs such as Windows live messenger and an online Bridge game intermittently freeze from time to time. When this happens it is still posssible to open other programs and use the internet for browsing. This has only just recently happened and it happens on any of the connected computers.- Has anyone any ideas what the cause would be.
    Scholar:
  • 187 Answers
It's not unknown for this to occur, and usually it's caused by Windows updates. In any case, try re-installing the programs themselves to rule out a corrupt file.
Posted on May 31, 2008
I have a Netgear DG834G v4. Wireless connection is fine, ISP is fine and Internet via wireless is perfect. Nothing via the LAn ports seems to work. Both XP and Win 7 machines see Lan as an undefined...
DHCP SERVER in Router and DHCP server in Wireless Conflicting - Set WI Fi DHCP router leases to say 192.168.0.10 to 192.168.0.100 and default gateway as 192.168.0.1 and on the router set the router's ip address to 192.168.0.1 make the Wi Fi router address 192,168.0.2 . Set in the router the DHCP address leases to 192.168.0.101 - 192.168.0.254 and default gateway 192.168.0.1 or deactivate one of the dhcp servers and rely on one dhcp server like the routers and then deactivate the wi fi's dhcp server.
Jul 28, 2017 | NetGear DG834G 54 Mbps 802.11g Wireless...
Netgear DG834 V4 constantly sending data
It means communication between computer LAN card and router is Ok and ready to use
you donot need to worry about that everything is ok
Please rate the service positively
Thanks for using fixya
Mar 27, 2010 | NetGear DG834G Router
How do I set NETGEAR DG834G v3 wireless router
Please follow the following link for any FAQ's on the NETGEAR DG834G v3 wireless router.
http://kbserver.netgear.com/products/DG834Gv3.asp
Nov 14, 2009 | Computers & Internet
How to put back internet browser?
Do you mean you want to restore the Netgear wireless router back to the factory defaults?
If so then :-
Power up the Netgear wireless router and use a sharp point and
press and hold the RESET button on the back of the router until the LEDs flash then release the button.
Then connect a LAN cable from the computer to the Netgear wireless router, then open IE browser and enter the configuration IP address, login and configure the wireless settings ie. SSID, encryption etc.
Take a note of these settings and configure the wireless cards in the computers with the router's settings.
Remove the LAN cable, the computers will now communicate with the wireless router.
Nov 12, 2009 | NetGear DG834G Router
Cant get online with ps3 since ive purchased a new NETGEAR dg834
Hi, please perform the steps below to configure settings on the router:
Please follow the steps on a computer connected to the router so as to check the network key:
1. Open the browser (Internet Explorer, Mozilla Firefox or Safari).
2. Access the router usually by typing 'http://192.168.1.1' or 'http://www.routerlogin.com' in the address bar.
3. Login to the router with the Username as "admin" and Password as "password" (please note that Username and Password are case sensitive).
4. Click on Wireless Settings (under Setup) from the left menu.
5. Check if WEP (Wired Equivalent Privacy) or WPA-PSK (Wi-Fi Protected Access Pre-Shared Key) is selected under 'Security Options'.
6. If WPA-PSK is selected, copy the code entered in the passphrase.
7. If WEP is selected, copy the code entered in the key that has been checked.
This is the code required for connecting the wireless computer to the router's wireless network.
In some cases, for security reasons the passphrase might show as asterisks. In this case type a new Password and click apply. You will then have to use the same Password for all the wireless devices connecting to the network.
Please scan for the wireless network on the PS3 and connect to the wireless network.
Let me know if you need any fruther help.
Sep 09, 2009 | NetGear DG834G Router
Netgear connection
is that wired connection or wireless? if it is wired, checked the cable and the port, make sure that the LAN connection is enabled.
if it is for wireless, checked the wireless settings of the router, enable the wireless card of the wireless computer and, verify the wireless settings of the netgear adapter and from there connect to it.
Jun 26, 2009 | NetGear DG834G Router
Netgear DG834 GT Router Set up issue
Enter 'admin' for user name and 'password' for password, these are the default login details.
May 31, 2009 | NetGear DG834G Router
LAN ports not working
make sure that the local area connection in the computer is enabled and that the drivers of the ethernet adapter are working properly.
try to reset the router by pressing the reset button for 30 seconds then if the problem still persist then that means the router should be replaced already.
Aug 09, 2008 | NetGear DG834G Router
Connecting to an existing wireless LAN
Hi there you can find the instructions for connecting your netgear DG8345G wireless router to your existing wireless router by configuring first your netgear router and click to help so that you can see the instructions by configuring it into your pc or you will go to the netgear support website so that you can find that model and look for instructions for your netgear router..
Jun 25, 2008 | NetGear DG834G 802.11G Wireless ADSL...
NetGear DG834G Router Logo
123 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
