Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Roller does not work. My vacume works fine , but the roller does not work. How can i fix that/
    Brigadier General:
  • 4,088 Answers
Remove the brush assembly, and clean/oil (3in1 or similar) the end bearings. If the belt is broken/damaged, replace same. Install the belt on the roller and motor shaft, then install the brush into the vacuum base--make sure the belt is half twisted (if required) in the correct direction. Hope this helps!
Posted on Sep 28, 2010
When the vacum is set on the bare floor mode, the on/off light blinks and the roller brushes stop working
This is normal. The roller brushes aren't needes on bare floors. They are used to brush lint, hair, etc. from the carpet that the suction itself wouldn't get.
Jan 28, 2011 | Dyson DC28 Animal Bagless Upright Vacuum
The roller brush stop working
the fuse in the plug may have blow so replace it any ways
Jul 12, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
Belt problem - when we began to vacum, we heard a sound, the rollers stopped moving
Sounds like your belt may have broken, or you have something jammed in there preventing the brush roller to spin. But most likely you're problem is a broken belt which is a simple fix that takes no time to fix
Aug 25, 2009 | Vacuums
The vacuum wont **** up anything anymore, and a rubber belt is now visible. What can I do to fix it?
i presume the vacume is a upright type. if the belt is visible i am also presuming the belt has broken, so turn the vacume up on its end so you can see the roller, you may have to take out a few srews to tak the base plate off which is covering the roller, take this off and you should see how the system works, the belt attaches to the moter spindle and then around the brush to turn it. take the brush out you should only need to pull it clean it and then go toyour local spares shop with the model number of your vacume and get a new belt, they cost about £1.00 each, put it back together and it should work....good luck.
Aug 22, 2009 | Vacuums
Brush on vacum wont make contact with rug, no pick up
if you take off the brush then reorientate the ends of the brush this will adjust height ends have a block depending on orientation they will set brush height This is common for many brush assemblies and should work for dirt devil
Jan 16, 2009 | Dirt Devil Vacuums
Roller
is the headlight working,if not there is a circuit board inside the base that is probably burned up.i have the same thing now i need to find the circuit board
Oct 18, 2008 | Hoover U8145-900 Savvy Bagless Upright...
We have the Eureka EZ Kleen upright. We have suction through the hoses but not the main vacuum. The brush turns fine but the vacume does not **** anything up.
THE HOSE BETWEEN THE DETACHABLE WAND AND THE BRUSH ROLLER AREA MUST BE CLOGGED WITH CARPET FIBERS. CLEAN IT OUT AND IT SHOULD WORK.
SFC ANDERSON, RICHARD T US ARMY
Jul 08, 2008 | Eureka Vacuums
Fantom cyclone belt status light
The belt may have stretched to the point that it won't turn the brush roll, you might try a new belt and hope that fixes it. Parts for these older Fathoms are scarce and are obsolete.
Apr 22, 2008 | Fantom Vacums Cyclone XT Upright Vacuum
Dyson DC07, too much suction...?
sounds like one of the filters is either damaged IE a hole or tear or is not seated correctly
Jun 09, 2007 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
223 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
