Question about Sony PVW-2800 VCR
The tapes doesn't run. They are loaded properly but I can't play, or rewind or rec. In the monitor I'm looking and steady frame with noise.
  • 130 Answers
Hi
looks like there is a broken or loose captsan drive belt
Posted on Sep 28, 2010
Recording problem
1. Press and hold down the ASSIGN A button (the light should be blinking) then (simultaneously) press the REC button above channel number 1. The light should blink when you do this.
2. Release the ASSIGN A and the REC button
3. Press the REC button above channel 1 (the light should be blinking by itself)
4. You should see the meters moving with in the display above Input A and Track 1 when you speak into the microphone.
5. Press the REWIND button twice until the display reads ABS 00.00.00.00
6. Press and hold the RECORD button and press the PLAY button. The REC light above channel one, the PLAY light and the RECORD light should become solid.
7. After recording press the STOP button.
8. Press the REWIND button twice until the display reads ABS 00.00.00.00
9. Press the PLAY button.
Apr 16, 2014 | Tascam DP 008 Digital Portastudio
3ccd tape gs35
the play button is at the back,were the REC button is.to play back you will pres the gear up and down to stop and back wared towards the left is the rewind button finally the forward is the other button towards rihgt handside
Aug 22, 2013 | Sony Dvcam DSR-390P DV Digital Camcorder
My AWIA HS-TX426 can't play cassette tapes
John Check if the capstan is rotating This is a shaft that touch the rubber wheel in the cassette Does the motor run properly? You say it is new then it should be under warranty take it back to the supplier and they should repair or replace it. If it was standing for a very long time i.e. 20 or more years then the mechanism is bound and if you know what you do then lubricate with sewing machine oil on all levers and shafts the motor can also do with a single drop ( 1 millimeter wire dipped for 25 mm in the oil and the oil that drops off, is the size of a measured drop of oil) I did get some Revox machines that were standing for such a long time and I had to use a pump pliers to get those wheel to turn they were BOUND but after playing it for a while they became working again
Apr 24, 2013 | Audio Players & Recorders
The DVD works fine but the VCR doesn't play, rewind or forward tape.
l would have a look inside to see if when a tape is inserted it loads and will ff and rew, if the transport that moves the tape has failed it will account for what is happening.
Aug 27, 2012 | Zenith XBV442 DVD Player/VCR
TV is on channel. VHS player has tape for playback loaded. Player is on but when PLAY is pressed 5 seconds later it turns off by itself. Model number is DVP3200V/37. Can anyone help, please.
Dirty magnetic head. Run a commercial tape head cleaner through it. You can get one at the box stores. Also, put your tape in a tape rewinder and rewind and fast forward the tape for about 30 seconds. Sometimes the tape ribbon gets wound too tight or is loose. If these fail, then you have to open the unit up and clean the magnetic head manually with some isopropyl alcohol and cotton q-tips. Also, look for capacitors on the power inboard chip that look burned and replace them.
Feb 04, 2010 | Philips VR621CAT VHS/S-VHS playback VCR
I have a Samsung SC-D381 Digital Video Camcorder that I would like to tansfer recorded video from to a PC. I bought the IEEE 1394 PC card with the FireWire 6/4 pin cable. I don't know what to do next. ...
You'll need a software able to capture and edit video. Your footage is on tape, right? First, you must have a firewire port on your pc, with the cam properly connected to. Then, all you have to do is make use of a program like Adobe Premiere Pro, Sony Vegas, or even the Windows Movie Makes, and find the capture window/mode/whatever, which will show you a console with play-pause-stop-rew-ff-rec buttons and a little monitor, to see where on the tape you are. Once on the capture console, you'll rewind the tape to the beginning of your footage and press rec ON THE CONSOLE, not on the camera. The software should ask you for a place to save the file and that's all.
Jan 14, 2010 | Cameras
Tape deck won't play
my machine not working problem is play, fd,rw, is not working all three led of rec,pause,play led is blinking
Nov 05, 2008 | Tascam Audio Players & Recorders
Loud noise on rewind
You may have an idler gear wheel which has been damaged- perhaps broken/worn gear teeth or something afoul in it's drive mechanisms. Check this idler which sits down in between the supply and take-up spindles. You should be able to see this with no tape loaded. This idler should also move freely from supply to takeup- if it is sticky in movement this could be the problem. If your idler is broken, you may be able to replace it. Check with a service center- or a parts supplier. MCM electronics is one such supplier- there are others.
Oct 01, 2007 | JVC HR-S3901 S-VHS VCR
VTR won't play
I would take a look at the loading machanism to see if it is properly loading the tape, usually on these type of machines if the tape is not being loaded properly the tape will not play. The rewind working indicates that the motor is still working so what you may also have is a gear problem, in which you will have to look at the gear system as the tape is loading and trying to go into play mode. This looks more like a mechanical problem then an electronics issue. However I would not rule out have to take voltage measurements to confirm that the electronics are ok (you will need a schematic for this, and a multimeter).
Sep 13, 2007 | JVC BR-DV600U Mini DV VCR
Video tape gets eaten on rewind
Does the machine play tapes well? Clear steady picture and all? No tracking bars? wavering sound? Tape chewing is generally a problem with a bad Capstan Pinch Roller, Associated symptoms are as above. Please do recheck or confirm if any of the above problems are also present.
Aug 30, 2006 | JVC HR-VP650 VHS VCR
Sony PVW-2800 VCR Logo
43 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
