Remote is working but the light and fan are not going on
    Habit-Forming:
  • 156 Answers
Is this a split system or a window unit? Are you able to use the controls on the face of the unit to get it to turn on?
Posted on Sep 28, 2010
Fan & light no longer work via remote. Light works by light switch only. I have tried new batteries in remote so its not that. Please help!!!!
this will not help everthing is working correct by the switch, so this tells me the remote box up in the fan went out there is a coulpe of diods in this box its like a circuit board these things go out pretty often you can go to lowes or home depot and get a new one for 45dollars good luck
Aug 07, 2011 | Hunter Dryers
The remote controls the fan speed but wont dim or control the light. the unit wont work if the light switch is off so I cant use the fan at all unless the light is turned on
mcdevito75 here, Generally the Ceiling fan motor is hooked up by-passing the wall switch but still to the hot laed going to the wall switch whlie the lights are hooked up to the hot lead after the wall switch, So without the remote, Manually operate your fan and lights. First with the wall switch off the fan should work and the lights no work. Now turn the fan off with the pull chain on the fan shroud close to the ceiling. Now turn wall switch on and lights should work with wall switch and the fan should also work. if so, re-program the remote or change the batteries or even re--place the remote.
Jul 26, 2010 | Hunter Ceiling Fan Light Remote Control
Hunter 52, fan works but light no longer works with remote or chain pull
mcdevito75 here, Don"t the fan lights work off the wall switch, The chain pull should be for fan speed. Check make sure electricity is going to the fan.
Jul 19, 2010 | Hunter 52" Ceiling Fan With Light And...
Light won't work on hunter fan with wireless remote
probably your lights are blown replace them.good luck.
Feb 28, 2010 | Hunter 27187 Remote Control
Fan remote nor lights work.
FIRST CHECK THE WIRE CONNECTIONS IN THE FAN ARE NOT LOOSE ,IF ALL CONNECTIONS ARE GOOD THEN I WOULD SUGGEST YOU REPLACE REMOTE.
Nov 08, 2009 | Dryers
10.27.09 - Ceiling Fan Light Kit not Working.
the remote does control the light. i think it's the bottom button, once to turn it on, again to turn it off. there should have been a blue wire connected in to the wires in the ceiling, this is power for the light. if only the white, black, and copper are connected, the light part won't work but the fan will (usually)
Oct 28, 2009 | Hunter 52" Ceiling Fan With Light And...
Remote wont' work after changing battery
Seem like you have a bad lectronic control circuit in that fan.
Jun 29, 2009 | Oasis Hunter 54' Ceiling Fan
Lights are on all the time, fan doesnt work, remote does not work
I have changed the remotes on 5 Hunter fans in the last 3 months. They have a problem with how some of them mount, that makes them drop down and vibrate loose. If you do not have a wall switch for it, you may want to go to pull chains, or just replace the remote. It is NOT the controller you hold in your hand, but the part in the fan. (never the easy way right?) The remote is not hard to change, but you DO have to let the fan hang from the holder on the ceiling bracket, It gets too heavy to hold while you change the remote.
All but one of the remotes I have changed, came from a mass market type of builder/handyman store, and they have just replaced the part at no charge.
Dec 21, 2008 | Hunter 52" Ceiling Fan With Light And...
Remote control fan hampton bay
Just insalled a hamptonbay fan and everything works except the dimmer. Light comes on on wall switch but remote won't dimm lights
Apr 04, 2008 | Hampton Bay 52 In. Brushed Nickel Romano...
Heating & Cooling Logo
22 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
