Question about Canon imageRUNNER 5000 Copier
When I turn the copier she asked for ID and password. How do I cancel? because it only works as a printer.
  • 6 Answers
Enter service mode by pressing the "additional functions" button, then the "2" and "8" buttons together, then the "additional functions" button again.
You will then go to Copier
Posted on Oct 09, 2010
  • Kylesolid Oct 09, 2010
    sorry. The post got cut off
    You will then go to Copier>Function>Clear and select PWD-CLR. Hit "ok".
    Hit the yellow reset button a few times to get back to the regular screen, and power down the machine. When it comes back up, you will be able to do anything.
  • Josias Soares
    Josias Soares Oct 09, 2010
    Already got it, using the same steps. Anyway I am grateful for the attention.
I cannot find my Canon C2550 system manager ID, can it be reset manually?
1. Turn off printer.
2. retaining button Resume/Cancel press button POWER - indicator it will catch fire by green color.
3. let go button Resume/Cancel, continuing to retain POWER.
4. press button Resume/Cancel of 2 times, retaining POWER, after which let go all buttons.
5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times.
6. turn off printer by button POWER. Power on again
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Canon Printer Support
Feb 26, 2014 | Canon imageRUNNER C2550 Color Copier
I have a Canon immagerunner 22706. How do I bypass the user id and password to begin printing without entering the user id and password. Thank you
To be able to bypass the user id and password and start printing. You have to first uninstall the printer/hardware from the control panel of your computer.
Install the printer back, then while it is running it asks if you want to use a user id and password, do not accept the user id and password mode, select the option that does not require a user id and password.
After doing this, you will be able to print without user id and password.
Take care
Sep 13, 2010 | Office Equipment & Supplies
I inherited a Canon imagerunner 2018. The unit is asking me to enter a System Manager id and Password. Please advise where I may be able to find that.
under service mode: * 2 8 *
with cursor key right, go to clear and press ok, select ALL, and press OK, these will "roll back" copiers settings to factory default, and also cancel the ID management password.
Hope that helped!
Jun 25, 2010 | Canon imageRUNNER 5000 Copier
It is asking for a password, but i never set one
nv ram. Hold down the down arrow and the cancel button. turn the printer back while still holding.
Al
Mar 12, 2010 | HP LaserJet M1522nf Multifunction Printer...
How do I cancel a print job - Panasonic DP-C354?
Go to controll panel touch the print button on the left bottom, touch print queue, it will ask for password which is 8 zeros. touch print job and hit cancel
Sep 27, 2009 | Panasonic DP-C354 Copier
Startuo ask for Depart ID and password
You need to turn dept id off but to do this you'll need to clear the system password. You need the service mdode to do this. Press the head key once (the key with a head and star inside) then the 2+8 keys at the same time, then the head key again. This will get you into service mode. Now select 'COPIER' then 'FUNCTION' then 'CLEAR' now look for the option the reads 'PSW-CLR' select it and press OK. Now turn off the machine by the control panel and then the power switch. Now turn the machine back on and you should be ok.
Jun 17, 2009 | Canon Office Equipment & Supplies
Canon iR2016J
Dept. ID is activated that is why it is asking you to enter it. If you are not needing the function you can ask the local service provider to check the settings of your machine.
Feb 21, 2009 | Canon iR 2016i Black and White Copier
How to Remove IR400 Dept. ID and Password
Hello, did you try the Clear MMI function ? , it should reset all passwords if my memory is good ( and all settings like ip, language etc ... )
Regards, Mug.
Nov 15, 2008 | Canon imageRUNNER 400S Copier
When printing to IP address a pop up asks for user id and pass
I can definately help with your ID code problem, and maybe with your vista problem.
The ID problem is very simple. Normally when this happens, the copier is set up to use ID codes for copying. When you install the driver, it connects to the machine and collects these type of settings, and configures the driver to the same state as the copier. You have two options to solve this problem. you can either turn off the ID codes in the driver completely, but then your copier must be set to allow print jobs without ID codes, or you can configure the driver with your code, and set it so that it does not ask you again.
both of the options are done by going to the printer driver properties. Click on the "device setting" tab at the top.
If you want to disable the ID codes completely, simply untick the "job accounting" box. click on "Apply" and then on "OK"
If you know your code and you want to configure the driver with your ID code and set it to never ask you for the code again do the following:
Make sure that the "Job accounting" box is ticked. Click on the "settings" button to the right of "job accounting". In the window that appears tick "Allow password setting". Enter your ID code and password (If you have a password), and untick "Confirm ID/password when printing". If you like you can click on the "verify" button. This will check that the ID and password that you've entered is valid or not. This is very handy feature if you are unsure if you've entered the correct info. When you're done with the afore mentioned settings, click on "ok", "Apply" (If active), and then on "OK"
Now for your vista problem. I'm not too sure of the exact problem that you're experiencing, but from what I can make out from your description it sounds like its a driver issue. I would say go to the canon software site and download the x64 driver for your product. The URL for the site is : http://software.canon-europe.com. once you are on the site all you need to do is specify your model, the operating system (In your case Windows Vista) and the language that you want the software to be in. The site will supply you with a list of different software that you can download, make sure that you download the Vista x64 driver. The site will clearly state that the driver is compatible with x64.
Hope all this info is helpful. Have fun, and don't forget to rate me.
Jun 04, 2008 | Canon imageRUNNER C3220 Color Copier
Canon imageRUNNER 5000 Copier Logo
75 people viewed this question
old marine
old marine
